Results 1 to 11 of 11
Thread: Throttle position with vagcom question
  1. Member sk8too's Avatar
    Dec 22nd, 2004
    Offutt AFB, NE
    97 Jetta VR swapped. 2010 CC VR Executive
    03-22-2012 01:01 PM #1
    So was playing around with vagcom today on my OBDI VR and checked the throttle angle position and when I push the pedal all the way down it reads 91.7% Is this normal? I know I can adjust my throttle cable and could probably get it to open to 100% But was wondering if anybody else has the same "issue"
    97 Jetta GL, OBDI VR swapped, 262 cams, GIAC chip, turn 2 style CAI, Magnaflow catback, 2.9 clone manifold, eurospec flywheel, B&G RS2 coilovers, MKIV front and rear seats
    Aug 11th, 2010
    SoCally
    97 Jetta GLX
    03-22-2012 03:15 PM #2
    i have the same issue.. mine reads 84% and i dont think it triggers the "WOT" map
    I survived epic thread 2011 never forget 11/11/11
  3. Member elief1's Avatar
    Apr 5th, 2009
    94 Golf VR
    03-22-2012 03:19 PM #3
    mine rest at 9.6 degree
    WOT 97.xx degree
    Elie.
  4. Member
    Aug 11th, 2010
    SoCally
    97 Jetta GLX
    03-22-2012 03:45 PM #4
    Quote Originally Posted by elief1 View Post
    WOT 97.xx degree
    what could be causing this ? a bad tps ?
  5. Member GTIVRon's Avatar
    Jul 24th, 2009
    Keller, Texas
    92 Corrado SLC, '12 Golf R
    03-22-2012 04:52 PM #5
    It's not %, it's degrees. Mine reads something like 9.7* closed and 94* at WOT. Car does it's job so I'm not worried about it. It is fully closed when I'm off the pedal and with slack in the cable, and when I floor it, it opens up all the way to against the stop, so I'm fine with that.
    2002.5 Jetta 1.8T - TOTALED (dodging deer)
    2002.5 24v GTI - TOTALED (rear-ended by a Jeep)
    1992 Corrado SLC - The toy & DD
    2012 Golf R - The weekender
  6. Junior Member
    Mar 26th, 2012
    Golf 3 VR6 1995
    03-26-2012 07:47 AM #6
    Just read that thread couple days ago, plugged my Cable and run some tests on VAG-COM:
    I have OBD-I 95 VR6.
    While warmed up, Throttle position angle was 9-10*...... then i pushed pedal to the floor till the max rev and the angle was hardly on 48*....
    what could that mean ??? i read people have 80-90*, but mine only does 48*..... what could be causing this???
    no DTC's on scan tool.... car runs good.... fuel consumption is high though......
    can someone please reply to me ? Thanks
  7. Member masterqaz's Avatar
    Oct 4th, 2007
    Oakville Ont
    94 JTI Vrt 60-1 .58ar exh obd2 440 racefile 20psi/meth
    03-26-2012 05:39 PM #7
    Quote Originally Posted by Tsiqara View Post
    If its actually wot and reading low (visually inspected) then theres an issue with the tps or a wire somewhere. tps is a pot so its varying a resistance to drop voltage, 0-5v i believe. Check it out with a volt meter.
    Forced convection.... Now we grillin.
    Some times she goes, some times she doesn't.... Way of the road
    Rem 870 super mag in max 4 camo for sale. Pm me
  8. Member masterqaz's Avatar
    Oct 4th, 2007
    Oakville Ont
    03-26-2012 05:40 PM #8
    Quote Originally Posted by sk8too View Post
    Last i checked mine it was at 84ish, it hits the wot map just fine. I would not worry about your 91.
  9. Junior Member
    Mar 26th, 2012
    Golf 3 VR6 1995
    03-27-2012 02:05 AM #9
    thx for reply, i have got 2 TPS, i swapped them and got same results.... dont think it's TPS fault, i have cleaned TB recently, and noticed some kind of "screws" which regulate something on TB. maybe it's mechanical fault and those screws need to be adjusted ??? is it related ?
    My Yellow MK-3
    http://www.youtube.com/watch?v=4M5UOza4jIM
    (_)(_)==W==(_)(_)
  10. Junior Member
    Mar 26th, 2012
    Golf 3 VR6 1995
    03-29-2012 02:39 AM #10
    BUMP
    My Yellow MK-3
    (_)(_)==W==(_)(_)
  11. Junior Member
    Mar 26th, 2012
    Golf 3 VR6 1995
    03-31-2012 11:21 AM #11
    Ok, looked at my TB today.... Still nothing.
    At WOT VAG-COM TB Angle still says 48*...... At Idle it's 10*....
    Since it's OBD1, and throttle body is mechanical, i mean when i push pedal Throttle body opens fully how the hell it's still 48* ??? i cant get it ???
    I would think my POT is faulty, but i have another one that i replaced with, but had same results. What can be causing this ? or since TB opens fully mechanically, does POT affect car's performance anyway ?
    My Yellow MK-3
    (_)(_)==W==(_)(_)
