Results 1 to 17 of 17
Thread: Godspeed Radiator with Stock Plastic Neck?
  1. Member FlyersFn32's Avatar
    May 14th, 2004
    Reading/Lancaster PA
    1991 VW Corrado VR6 (swapped), 1996 VW Jetta
    03-22-2012 05:27 PM #1
    I could have sworn I saw pictures of people using the stock radiator neck with a Godspeed radiator. I guess mine is just defective? When I align it so that the neck fits inside the hole in the Godspeed radiator, only one of bolt holes lines up...
    Anybody else have this problem? Looks like I'll be sending it back...
  2. Member NoCYet's Avatar
    Feb 10th, 2001
    Alameda, CA
    1994 Corrado
    03-22-2012 08:52 PM #2
    I agree totally, send that plastic neck back!
    My Build Thread http://forums.vwvortex.com/showthrea...c-Build-Thread
    Want a shiny new SLC Badge? PM me.
  3. Member PSUCorrado's Avatar
    Sep 10th, 2006
    PA
    1990 VW Corrado 2001 Audi S4
    03-22-2012 08:55 PM #3
    I drilled and tapped a 2nd hole on the rad to get it to work.
  4. Member
    Oct 18th, 2001
    CT
    '90 Corrado vr
    03-23-2012 05:56 AM #4
    just get an aluminum rad neck and be done with it. why upgrade the rad and leave the craptastic neck on there.
  5. Moderator Krazee's Avatar
    Jan 25th, 2003
    En Why Sea
    Blog Entries
    9
    Corrado
    03-23-2012 07:39 AM #5
    Recently, I have noticed alot of people having GodSpeed issues.
    Suggestion?
    1) Brand new stock
    2) PWR if aftermarket
    Project Corrado RS: Keep Up
    MSD 12v VR6 coilpack setup/components For Sale: Here
    Other items for sale: Sparco, VR6 HVAC box, VR6 radiators, Mocal Oil Cooler: Here
  6. Member BlueS14's Avatar
    Apr 5th, 2011
    2004 350z Track
    03-23-2012 06:52 PM #6
    I used a radneck from gruven. Nothing fits that radiator well....i actually made a gasket to seal 100%. The godspeed is off a little....but make it work as cooling is much better with that radiator. Well worth the hassle....i will post a pic if i get a chance. Had i to do it all again....i woukd by the radneck....take it to a welder and have it welded onto the radiator for a permanent solution.
  7. Member FlyersFn32's Avatar
    May 14th, 2004
    03-29-2012 10:33 PM #7
    Has anyone had a Godspeed radiator where the Gruven neck DIDN'T work?
    Pretty sure I'm just going to buy the Gruven neck. After a whole bunch of beating around the bush from the eBay seller I bought the Godspeed radiator from, they actually had a guy from Godspeed call me today and from talking to him, he seemed pretty sure my radiator was not "defective" (so I'm assuming they've had other people have the issue of the stock plastic neck not lining up with the bolt holes...or he just wanted to get me off the phone).
    I just wanted to make sure that nobody has had a problem with getting a Gruven neck to bolt onto a Godspeed radiator before I order one. There's always the possibility of getting it welded on, but should the radiator ever fail it would be nice to not have that $100 neck permanently attached...
  8. Member NoCYet's Avatar
    Feb 10th, 2001
    Alameda, CA
    1994 Corrado
    03-30-2012 09:22 AM #8
    Quote Originally Posted by FlyersFn32 View Post
    The gruven neck is designed to bolt up to a stock radiator, so the bolt holes will be in the same place as on your plastic neck. The only difference is the length of the bolts. If the plastic neck doesn't fit the gruven one probably won't either. Depending on the location of the holes in your radiator you may be able to drill another hole in the flange on the gruven neck to get it to line up.
    Feb 4th, 2005
    east tennessee
    1991 passat wagon
    05-06-2012 09:48 AM #9
    bought my godspeed from ebay. same issue the holes dont line up and where the neck pushes in looks like it waht cut with a hole saw and the hole is not lined up the oring would never seal. if you still got the radiator, cause they wanted me to pay to ship mine back. i found an aluminum elbow on ebay $11.00 bucks shipped and it will have to be welded in. but it will make it work and it's bitchin. http://www.ebay.com/itm/350308512278...84.m1423.l2649 thats the lnk. let me know i am sure it will make mine work!
  10. Member FlyersFn32's Avatar
    May 14th, 2004
    05-06-2012 10:37 AM #10
    Who was the seller? I would tell them the auction says (at least it probably does...they all say the same thing) that it's a 100% bolt on stock fit, blah blah blah. So tell them the item is not as advertised and you want them to email you a shipping label you can print out and use to ship it back.
  11. Member thevisualedge's Avatar
    Dec 31st, 2003
    Los Angeles, CA
    1993 Corrado VR6, 2004.5 Jetta GLI, 2004 Ford F150 :)
    05-07-2012 11:35 AM #11
    Guys, take it from someone who spent the last week making the Godspeed fit my car ...
    The bolt holes do NOT match. If you line up one, the other will be off and vice versa. I put a bolt in the hole closest to the engine bay, and then center-punched, drilled, and tapped a new hole into the radiator for the second bolt.
    You save a lot of $$ with the Godspeed, but you pay for it in labor.
    Feb 4th, 2005
    east tennessee
    1991 passat wagon
    05-13-2012 10:13 AM #12
    yes with much work and language some spare pieces and welding its in a 1991 passat wagon with g60 swap and i am very happy, cools much better than stock and looks good too...........pain and suffering pay off in the long run oh yeah the ebay elbow is the ticket only the fitting for the hose is 1 1/2 inch but you can force the hose on.
  13. Member 3 bar's Avatar
    Aug 16th, 2001
    Greensboro NC
    91 Corrado, 03 Jetta, 99.5 A4 TQM
    05-13-2012 09:24 PM #13
    Did you use the vr6 radiator? Dont see one listed for a g-60
  14. Member BlueS14's Avatar
    Apr 5th, 2011
    2004 350z Track
    05-13-2012 10:36 PM #14
    Man up and make it work.....make that radiator your bitch....lol. really though, its not that tough.
  15. 05-13-2012 10:43 PM #15
  16. Member
    Mar 20th, 2009
    Rochester, NY
    95 urS6, 91 golf, 84 rabbit, 09 hypermotard, corrados
    05-14-2012 11:05 AM #16
    i am using a stock elbow on a godspeed. bolt holes lined up perfect
    going on 2 years now
    there must be a new batch with chinese quality control...
  17. Member
    Feb 4th, 2005
    east tennessee
    1991 passat wagon
    05-14-2012 07:19 PM #17
    yep used the vr6 radiator , and an aluminum neck i found on ebay had it welded on and after much trial and error fitment it went in quite nice i am happy with it now. i posted the ebay link for the neck guy still had 61 left as of yesterday.
