Results 1 to 15 of 15
Thread: expected ET, numbers inside
  1. Member mrbikle's Avatar
    Jul 2nd, 2005
    Hagerstown, MD
    06 GTI BT, 95 BMW 740i
    03-22-2012 06:05 PM #1
    Last year I was running a consistent 11.6-11.7 at 119-120. These numbers were at roughly 390-400whp, dependent on conditions.
    Platform: 2006 mkv gti DSG
    Last years setup was as follows:
    -stock FSI engine with an ATP 3071r
    -DSG at 5k launch
    -24.5x9x15 MH slicks
    -400whp (dynoed)
    This years setup
    -fully built engine with a comp 5858
    -same DSG setup
    -same slicks
    -~520whp (dynoed on same dyno)
    Power band is a little later, but I am revving higher now so it is a moot point.
    Being as I was going mid 11s last year, would it be fair to assume 10s this year? I know there is only one way to find out for sure.... just trying to get an idea before I hit the track.
    Also, any thoughts on a decent harness to fit on stock seats?
    recent dyno :http://www.youtube.com/watch?v=1iAhD...eature=channel
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    03-22-2012 09:06 PM #2
    only 1 way to find out.
  3. 03-23-2012 12:00 AM #3
    Cant wait to see what you pull with the DSG unit. Is the DSG Auto all stock?
  4. Member mrbikle's Avatar
    Jul 2nd, 2005
    Hagerstown, MD
    03-23-2012 12:25 AM #4
    all stock with the exception of the software, all safety margins have been removed.
  5. 03-23-2012 02:32 AM #5
    Dang I didn't realize the DSG can hold that amount of power with a stock unit. That gives me some ideas since I have an extra turbo laying around and a Jetta just asking frr it.
    There's a guy in the Corrado forums that has a DSG in his Corrado.
    Nice to see other VW automatic's out there making a name fr itself. I can't wait to see some final results keep me/us updated.
  6. Member JoHnsVrT's Avatar
    Feb 1st, 2007
    union nj
    89 jetta carat, 90 gti vrt
    03-23-2012 12:59 PM #6
    what is the car weighing in at?
    67mm - vrt
    mad slow
  7. Member mrbikle's Avatar
    Jul 2nd, 2005
    Hagerstown, MD
    03-23-2012 01:25 PM #7
    2900ish, not sure on exact weight now with the cage.
  8. Member JoHnsVrT's Avatar
    Feb 1st, 2007
    union nj
    03-25-2012 03:17 PM #8
    low 11 high 10 should be the range your car is in at 2900 with 520ish
    67mm - vrt
    mad slow
  9. Member ALRDesign's Avatar
    Nov 5th, 2008
    NJ
    16V Turbo
    03-26-2012 12:44 AM #9
    Running stock axles? My turbo is starting to go bad, and this thread has given me a terrible idea.
    ALRDesign|ATP Turbo|FFE Racing|.doTuning
    Contact me for any custom CNC needs.
    Twitter- @iamALR87 | Instagram- alrdesign
  10. Former Advertiser Kenny@Eurojet's Avatar
    Nov 22nd, 2011
    Summit Point Raceway WV.
    Jazz blue Stroked Caged Fully Built Big Turbo 20th GTi on Air and 3 piece HRE's ,B5 Audi A4 quattro
    03-26-2012 10:47 AM #10
    Can't wait to see a local friend dip into the 10s with this car
  11. Member mrbikle's Avatar
    Jul 2nd, 2005
    Hagerstown, MD
    04-14-2012 03:15 PM #11
    running tomorrow... either gonna run 10s or 13s
  12. 04-23-2012 12:27 AM #12
    So how did it go for ya?
  13. Member mrbikle's Avatar
    Jul 2nd, 2005
    Hagerstown, MD
    04-23-2012 06:45 PM #13
    11.3@126 on a **** track.... 2.0 60 foot....and as the day went on the track got worse and worse. Started seeing 2.3 60's on 9 psi 9 inch slicks and my et's went to high 11s and even 12.0. The last run of the day, the car literally rolled smoke til 1/8th mile.
    trying again Wednesday at a better track. Also, added 2 step and hopefully will have my slicks screwed to the wheels by then...as I was getting nearly an inch of bead travel per pass
  14. Member mrbikle's Avatar
    Jul 2nd, 2005
    Hagerstown, MD
    04-23-2012 10:57 PM #14
    2 coats of 50/50 meth/vht
    1 coat of vht
  15. Former Advertiser Kenny@Eurojet's Avatar
    Nov 22nd, 2011
    04-24-2012 08:50 AM #15
    I see the whole problem........your wheels arn't 3 peice with stretch
