Results 1 to 7 of 7
Thread: United Motorsports Ko4 software for Fsi
  1. 03-25-2012 12:12 PM #1
    Anyone using the United Motorsports Ko4 software for fsi? I wanted to try something different than the big three ko4 tunes. I checked their website. The state 280whp 280tq. That seems a little low. I'm looking for any end user input.
  2. Member ROH ECHT's Avatar
    Dec 9th, 2010
    auf asphalt
    `07 gti K04'd
    03-25-2012 04:27 PM #2
    Seems a bit low yes, but dyno readings are all over the place due to type. I got 285whp and 363ft*lb when I had lower actual boost with my giac remap though. BTW, there are 4 big tuners in the US not 3. REVO, UNITRONIC, GIAC, and APR.
    K04 PLAY...`07 GTI/AWE K04&DV/APR HPFP/S3 INJ's&fmic/RS4 fprv/FORGE fmic & T-B HOSE/TECH.TUNING TB/BSH PCV&MOUNT's/NSP BOOST GAGE/AP Lite-PULLEY/NEUS. P-FLO&BOOST PIPES/GIAC K04 H/O & DSG FILES/13.2"BBK/BILSTEIN DAMPERS/W.A.L.K./H&R SS SPRINGS+F&R-ARB's/TSW 8X18 NURB's...ZOOM DIS! 1/4 mi: 12.82 @ 112 mph
  3. 03-25-2012 07:17 PM #3
    Honestly, I wouldn't consider giac unless I had tsi ko4 or vr6. Everyone I know except for one that had the giac x file hated it. That is the reason I said big three.
  4. Member fastdubonbbs's Avatar
    Jul 10th, 2011
    Savannah
    08 K04 GTI, 04 .:R32
    04-16-2012 12:19 AM #4
    i'm running UM K04 file. the car runs hard as ****!!! i know the website says 280/280 with 20-21psi. i'm running solid 25psi WOT til about 4500rpm. then it drops off. Jeff REALLY knows what he's doing when it comes to VAG cars. basically what i'm saying is...forget the "big" 4 companies and give UM a call.
    ZeGERMAN deutschland am start...was geht!
    (Oo)GTI_\X/__(oO)
    (080).:R32=\X/===(080)
  5. Member fastdubonbbs's Avatar
    Jul 10th, 2011
    Savannah
    04-17-2012 01:58 PM #5
    also...UM will fully customize a tune for you. for example...when you get upgraded rods, lower CR pistins, cams and so on. the others only have cookie cutter tunes with little to no options
    (Oo)GTI_\X/__(oO)
  6. Member BaneGTI's Avatar
    Feb 25th, 2004
    Poconos PA
    08 GTI K04/04 JETTA TDI
    05-02-2012 07:34 PM #6
    i've met jeff and would go UM in a heart beat if i wasnt already running the Unitronic tune
    K04/UNITRONIC STAGE 2+/APR HPFP/42DD CATCHCAN/APR CATBACK/UNITRONIC CATLESS DP/BC RACING COILOVERS/APR INTERCOOLER/BSH TRU-SEAL/BSH BULLET PROOF DV/BSH MOUNT KIT/RH ZW4'S 18X8.5/9.5 BLACK W/GOLD BOLTS/VF SHORTSHIFT/AWE BOOST GAUGE/DIESEL GEEK PANZER SKIDPLATE/VOTEX KIT/ AEM WATER METH/ APR REAR SWAY W/ NEUSPEED END LINKS/TRIPLE GAUGEPOD W/AFR/OIL PRES/OILTEMP
  7. Member Jay-Bee's Avatar
    Sep 22nd, 2007
    North Alberta
    B7 A4 Avant 2.0T
    05-03-2012 04:25 PM #7
    Quote Originally Posted by BaneGTI View Post
    I followed his work with the 8 valves and VRs, and i'm following his work into the 2.0T world
    I read this in Samuel L. Jackson's voice to make it more interesting. That's all I got.
    2007 A4 Avant 2.0T Q/MT
    2000 VW Golf 2.0 [Sold]
