Results 1 to 13 of 13
Thread: Frybrid WVO (Waste Veggie Oil) Kit- NEW and UNUSED
    Jan 21st, 2005
    '81 Diesel Caddy, '90 Corrado TDI, 2013 Passat TDI
    03-25-2012 02:53 PM #1
    Will NOT part this out.
    Located in RI/Eastern CT
    Will consider shipping.
    I purchased this kit to install into my Rabbit 'Caddy' Pickup that has a 1.6l Diesel engine- life has gotten in the way and I won't be having time to do WVO. The tank was custom made to go under the bed in the area where the spare tire is supposed to go. The kit is entirely brand new and unused and should easily go into a Pre-MKV Volkswagen TDI- the tank measures 26"LX21.5"Wx7"D with 1.5" mounting tabs on the edge of the tank- these tabs could be easily cut off if you're looking to put this in the trunk of your Jetta or Golf or Passat TDI.
    The benefits of the Frybrid over the Greasecar kit includes that there is NO copper in the tank and that the fittings are brass and that the coolant fittings are outside of the tank- there is over 30 square feet of heat exchanging area. The fuel lines are aluminum and there is a a purge warning cycle. The micro controller automatically switches over vegetable oil once the fuel comes up to temperature without buying the extra grease car computer.
    This kit includes:
    Heated Filter
    Controller
    Heat exchanger
    2x 3 port solenoid valve
    2x hose ends
    tube thread sealant
    20 small clamps
    7 3/4" clamps
    9 5/8" clamps
    5/4" and 3/4" T
    3/4 to 5/8 adapter
    Coolant Temp Switch
    Red/Green/Yellow Indicator lights
    Tottle Switch
    Buzzer
    Push Button
    10 Ring Connectors
    15 Spade Connectors
    6 butt connectors
    1 large ring connector
    1 inline fuse and holder
    20 Tec Screws
    10 1 1/4" P clamps
    10' Fuel line
    10' Aluminum Line
    50' Coolant line
    The tank- missing fuel level sender
    I'm basically taking a huge loss selling this kit without use, but such is life. $1500.
    Jan 21st, 2005
    04-03-2012 08:52 AM #2
    Up.
    Jan 21st, 2005
    04-08-2012 06:47 AM #3
    Up.
  4. Member
    Jan 21st, 2005
    04-12-2012 08:00 PM #4
    Bump.
    Jan 21st, 2005
    04-16-2012 09:46 PM #5
    Bamp.
  6. Member
    Jan 21st, 2005
    04-24-2012 09:56 AM #6
    CL lowball bump
    Jan 21st, 2005
    04-29-2012 02:03 PM #7
    Up.
    Jan 21st, 2005
    05-12-2012 09:43 PM #8
    Bump.
    Jan 21st, 2005
    05-15-2012 08:02 PM #9
  10. Member
    Jan 21st, 2005
    05-22-2012 09:16 PM #10
    Found some wvo locally but resisting the temptation... Up!
  11. Member
    Jan 21st, 2005
    05-26-2012 08:15 PM #11
    Started my corrado TDI conversion today, could use some project funds
  12. Junior Member
    Apr 23rd, 2011
    Maryland
    02 JETTA TDI 5 SPEED
    06-22-2012 08:42 PM #12
    Does this come with instructions or just what is shown? Also you say this will work on a 1.9 is that correct? What is the bottom dollar you will settle for?
    olharleyman@hotmail.com
  13. Member
    Jan 21st, 2005
    06-23-2012 08:05 PM #13
    Sold.
