Page 7 of 9 FirstFirst ... 3 4 5 6 7 8 9 LastLast
Results 211 to 245 of 299
Thread: Corrado 20v 1.8T
    Sep 11th, 2009
    MN
    1990 Corrado AWP 20v 1.8T
    09-24-2012 10:57 PM #211
    Quote Originally Posted by dri0514 View Post
    #2, I ran the ecu inside the car.
    #3, I spliced in to the male side. I had to use the wiring diagram because some of the wire colors didn't match. I assumed it was mostly written from the female side. I might be wrong but I bounce all the information from the diagram and the Corrado Bently manual.
    For start up purposes I put the maf sensor where the throttle was at. It ran good.
    can you provide some pictures? you must of really cut and extended some of them, the hole for the engine harness to inside the bay cannot fit both those harnesses.
    it's not that I can't do it, it's that I don't know how yet...
  2. Member dri0514's Avatar
    Aug 21st, 2005
    Point Mugu
    1992 Corrado ATC 20V 1.8T, 2012 Durango R/T
    09-25-2012 12:51 AM #212
    Quote Originally Posted by 2OVT View Post
    It did fit my AEB harness and plugs. I did have to remove the back covers and some good pushing. I'll give you some pictures that would help.
    Sep 11th, 2009
    MN
    09-26-2012 02:25 AM #213
    about 60% done with the wiring. have quite a few extra wires for my t14a and t6/10 plugs. what should I do with them? tape them off and hide them in the loom or use some kind of wingnut and hide them in the loom?
    since my ECM harness was originally an auto, some things are slightly different. for instance:
    t10x Orange plug- I am missing pin 2 (green/red to ECU T121/81) to tach adapter to G1 pin 12.
    t10w White plug-Missing pin 4 (white/red to ECU T121/39) to clutch pedal switch.
    what should I do for these missing wires in my plugs?
    also pin 1 from my t10w White plug runs into the DLC, IIRC it is supposed to run to pin 2?
    It says t10x Orange plug pin 1 (grey/white to ecu T121/43 (229) to DLC. What wire on DLC? black/blue?
    for T14a (14 pin connector near battery) it says pin 4 (purple) CTS to G2 pin 3, what size resistor? I have 100ohm 5% tolerance.
    another T14a one. Pin 6 (yellow/black) fused 10amp to fuel pump relay (fuse shared with T6/6) to g2 pin 4. What does it mean when it says fuse shared with t6/6? I do have a t6/6 but I wasn't going to use it? Do I have too?
    how many inline fuses did everyone use to? I only used two?
    also for the ECM harness itself, there are quite a few wires that were cut as part of cleaning the auto trans/n80/vac. booster for the auto crap out. should I just cut them short and cap/tape them and hide them in the loom?
  4. Member bansheelos's Avatar
    Nov 29th, 2004
    Dirty Jer-Z
    94 Golf VR, 78 Bay Bus VR under const.
    09-26-2012 08:50 AM #214
  5. Member dri0514's Avatar
    Aug 21st, 2005
    Point Mugu
    09-26-2012 02:30 PM #215
    WOW! Thats a lot of wires. Can you take some pictures? Just trying to picture it.
  6. Member
    Sep 11th, 2009
    MN
    09-28-2012 05:57 PM #216
    Good news. Figured it out.
    I THOUGHT I was missing these wires:
    t10x Orange plug- Pin 6 blue/white ecu T121/54 to speed signal in dash wiring Y (Hall speed sensor on clocks W pin 1)
    t10x Orange pin 2- Runs from the ECM harness bulkhead to the orange t10x male connector, but not the female connector. The auto must not of used this.
    t10x Orange pin 6- On manual this wire goes from T121/54 to the t10x orange male connector. In the A/T version this wire runs to the TCM. I found it as I remembered I snipped one wire between both the ECM and TCM connectors. Looked at AWP wiring diagrams and I was right.
    t10w White plug- Pin 4, this wire also goes from the ECM harness bulkhead to t10w white connector, but not the female conenctor.
    so all in all, I have to repin the female t10x and 10w connectors to accept the two I thought I was missing.
    for the t10x pin 6, I will extend from ECM bulkhead and pin it to where it needs to be as the female end of the t10x has the wire in it.
    so now my fears of finding a m/t ECM harness are over. Just a manual ECM
    still-
    How about wiring in a CEL/MIL light? The early g60 didn't have any of this and it would be a nice feature.
    also, where is the starter interlock??? or am I just dumb with this
    should be finishing wiring tonight
  7. Member 3 bar's Avatar
    Aug 16th, 2001
    Greensboro NC
    91 Corrado, 03 Jetta, 99.5 A4 TQM
    09-30-2012 07:48 PM #217
    Quote Originally Posted by 3 bar View Post
    I'm doing a similar swap with a rebuilt AEB motor and a t3/t4 setup. Don't want to rattle my fillings out so i'm using the stock front mount. I have already converted my suspension on my car to 5 lug using a 95 Jetta GLX suspension with bigger axles and polyurethane and r32 bushings. Plan on doing a mk4 shifter conversion. Good luck with your swap!
    Correction: just bought and installed a BFI solid front motor mount on my g-60 after having my motor jump up and hit my hood. I will using this for my 1.8t swap.
    Sep 11th, 2009
    MN
    10-01-2012 02:16 AM #218
    My BFI mount I installed I accidentally stripped the bottom bolt cavity and am waiting on another, currently it is sitting on a BBM solid front mount (which is around 3/4's of an inch higher than the BFI mount). Using the BBM solid front mount, a regular catless 3" dp barley fits. Since the BBM mount is taller than the BFI one, the motor is at a bit more of an angle. Using the BFI mount, you'll have to get a custom DP made if it's in 3" to accommodate for the angle.
    with BFI front mount the stock g60 hood clears, with the taller BBM mount, it does not
    wiring is 96% done, finish tomorrow and hope for first start. FINALLY!
  9. Member turtledub's Avatar
    May 10th, 2006
    1990 20v Corrado(soon), 2001 Outback 250k strong!
    10-01-2012 07:10 AM #219
    Good to know on the motor mount. I have a BBM one. Glad to hear the wiring is almost done. I hope it starts on the first try for you.
    Women are gentle and soft, but they hit things...
    20v AEB Corrado Build thread.
    Parting a B4 ABA Passat?
  10. Member dri0514's Avatar
    Aug 21st, 2005
    Point Mugu
    10-02-2012 02:35 PM #220
    Any word?
  11. Member
    Sep 11th, 2009
    MN
    10-04-2012 11:01 PM #221
    everything has power now. but something happen to my t14 plug it won't fit itself, have to figure this out so I can crank this sucker over. One stupid thing after another
  12. 10-05-2012 12:46 AM #222
    waiting paitiently
    1990 G60
  13. Member EnIgMa '06's Avatar
    May 13th, 2004
    Minneapolis, MN
    1992 Volkswagen Corrado SLC, 1998 Jeep Wrangler SE
    10-05-2012 01:30 PM #223
    If it turns over, how close will you be to driving it? We should go for a drive before it gets too cold for my tires.
  14. Member
    Sep 11th, 2009
    MN
    10-05-2012 07:54 PM #224
    Just tabs, tires and an alignment. That would be awesome!
  15. Member
    Sep 11th, 2009
    MN
    10-05-2012 10:42 PM #225
  16. 10-05-2012 11:31 PM #226
    Congratulations
    Quote Originally Posted by gdoggmoney View Post
    There's been too much butt sniffing before this dog fight.
    GONZO tuning PagPartsTurbo www.speeding-g60.com INTEGRATEDengineering
  17. Member
    Sep 11th, 2009
    MN
    10-05-2012 11:47 PM #227
    Quote Originally Posted by Rod Ratio View Post
    Congratulations
    thanks man. found out my 5spd ecm I picked up already has immo defeated
    I am throwing two codes for manifold pressure. I have NO charge piping hooked up, MAP isn't hooked up, no pipe off the turbo(one that recirculates DV/n75) and the car dies after 5 seconds of running. Anyone help?
    here are my codes-
    p0238 - manifold pressure/boost sensor(g31): signal too high.
    p0106 - manifold/barometric pressure sensor (g71)/(f96) implausible signal.
  18. Member dri0514's Avatar
    Aug 21st, 2005
    Point Mugu
    10-07-2012 09:36 PM #228
    here are my codes-
    I'm so happy for you!!! Is everything hooked up?
  19. 10-07-2012 11:07 PM #229
    here are my codes-
    You just answered your own question.
    Get that MAP sensor in the loop.
    MAF, VVT, N112, N80, N75, N249, SAI, etc wont cause the car to not run when disconnected.
    MAP needs to be there to even run in open loop.
  20. Member dri0514's Avatar
    Aug 21st, 2005
    Point Mugu
    10-12-2012 02:41 AM #230
    How's the car going?
  21. Member
    Sep 11th, 2009
    MN
    10-14-2012 07:12 PM #231
    IMMO off.
    I think the turbo is bad.
  22. 10-14-2012 08:21 PM #232
    IMMO off.
    How do you figure?
  23. Member
    Sep 11th, 2009
    MN
    10-17-2012 10:14 AM #233
    the goofy wind during shut off.
    now I am fighting with a small coolant hose. this one to be exact.
    problem is; I am using the manual coolant flange with the auto hard pipes from the water pump. so the hose is literraly about a 1/4" too small. any ideas? Only thing I can think of is switching back to an automatic coolant flange then I'll be ok. Unless the manual one is slightly longer.
  24. 10-18-2012 01:39 PM #234
    Heat gun
    1.8T Performance parts for sale
    GLX Tails for sale $50, PM me
  25. Member turtledub's Avatar
    May 10th, 2006
    10-18-2012 01:55 PM #235
    Quote Originally Posted by WoLfBuRgJeTTa View Post
    Heat gun
    This plus a metal funnel or some other cone shape that you can jam in there while you heat it up. I don't know how much play you will get out of the hose if it is renforced. I had to do this to a coolant line once. The other problem is making sure it does not shrink back down.
  26. Member hallkbrd's Avatar
    Apr 8th, 2000
    Oklahoma
    '05 1.8T Corrado
    10-21-2012 12:37 PM #236
    Right. I have the BBM front mount and the old stock hood cleared - with a simple modification. I took the vac hose connection on the top of the intake manifold off, threaded the hole for a "flush" bolt, and then all was good.
    A life frittered away disgusts God; he loves those who run straight for the finish line.
    Never Ending 1.8T Corrado Project
  27. Member
    Sep 11th, 2009
    MN
    10-21-2012 05:39 PM #237
    good to know. did you have a problem with the oil cooler water lines hitting the fan using this mount?
  28. Member
    Sep 11th, 2009
    MN
    10-22-2012 04:12 PM #238
    so here it is...officially.
    using the automatic 1.8t water pipes and a manual coolant flange I needed another 1"-to-3/4" coolant hose in a 90 bend. VW doesn't sell the hose separate, so I attempted to cut and splice in a section of copper pipe to make it longer to work with the manual flange. wrong. VW wanted $160 for the water pipes with the manual coolant hoses. F-that. So I traveled up to the local Auto Value and they ordered me what I wanted for $12. Got it and cut it to fit and it barley fits. Slightly bends in where the bend is. So I will more than likely have to switch back to the auto coolant flange for it to work flawlessly.
    also found a local drag shop (that I didn't know existed) and they happen to have a few tach adapters on stock, so I picked up a MSD 8920 for $60. Seems pretty straight forward.
    black-ground; red-power; white-tach signal from ecm; purple-g1/12.
    done.
  29. 10-22-2012 05:08 PM #239
    You might want to spend a few bucks with these guys in the near future.
    http://www.jrmfabrication.com/?wpsc-...coolant-flange
  30. Member hallkbrd's Avatar
    Apr 8th, 2000
    Oklahoma
    '05 1.8T Corrado
    10-22-2012 05:20 PM #240
    Well, as I have no oil cooler water lines - that was not a problem. I use a sandwich adapter and a real oil cooler.
  31. Member
    Sep 11th, 2009
    MN
    10-22-2012 07:16 PM #241
    Nice. Will do. This will go good with my gruven bullet dipstick crap :p
  32. 10-22-2012 07:50 PM #242
    They have the coolant hardpipe with an fittings too
  33. Member dri0514's Avatar
    Aug 21st, 2005
    Point Mugu
    10-22-2012 10:33 PM #243
    Looking good!!!
  34. Member
    Sep 11th, 2009
    MN
    10-26-2012 12:11 PM #244
    Decided since I still need intercooler piping that I am going to rig up the stock side mount for now. It's going to be a long 850miles before the clutch is broken in anyway. Stock SMIC and stock tune should do the clutch good until break in. Then I'll put my FMIC in once I get more piping and a stage 2 tune. Hopefully by then I'll be stacking more big turbo goodies up.
    body work coming soon
  35. Member dri0514's Avatar
    Aug 21st, 2005
    Point Mugu
    10-29-2012 10:50 PM #245
    you can do this intercooler set up.
    http://forums.vwvortex.com/showthread.php?3007299
