Results 1 to 13 of 13
Thread: HELP !!!!
  1. Junior Member pahjetta's Avatar
    Sep 25th, 2011
    Camp Pendleton
    2004 Jetta GLS 1.8 t
    03-27-2012 01:55 AM #1
    My mkiv is well completely dead right now. I had a small coolant leak and a failing abs module a week ago then all of a sudden poof whit smoke and dead. I did a compression and it is well within limits i tried resting the car with vag com but no luck here is the scan.
    Monday,26,March,2012,19:16:43:22930
    VCDS Version: Release 11.11.1 (x64)
    Data version: 20111209
    Chassis Type: 9M - VW Jetta IV
    Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
    75 76
    VIN: 3VWSE69M54M011790 Mileage: 128410km/79790miles
    Address 01: Engine Labels: 06A-906-032-AWP.lbl
    Part No: 06A 906 032 NL
    Component: 1.8L R4/5VT G 0003
    Coding: 07550
    Shop #: WSC 78901
    VCID: 75EBC26D4FDA16C
    3VWSE69M54M011790 VWZ7Z0C7936574
    6 Faults Found:
    18057 - Powertrain Data Bus
    P1649 - 35-00 - Missing Message from ABS Controller
    16501 - Engine Coolant Temp. Sensor (G62)
    P0117 - 35-00 - Signal too Low
    17511 - Oxygen (Lambda) Sensor Heating; B1 S1
    P1103 - 35-00 - Performance too Low
    16717 - Knock Sensor 2 (G66)
    P0333 - 35-10 - Signal too High - Intermittent
    17735 - Knock-Control: Cylinder 3
    P1327 - 35-00 - Regulation Limit Exceeded
    16712 - Knock Sensor 1 (G61)
    P0328 - 35-10 - Signal too High - Intermittent
    Readiness: 0000 1100
    Address 02: Auto Trans Labels: 09A-927-750.lbl
    Part No: 09A 927 750 BD
    Component: AG5 Getriebe 09A 0237
    VCID: 6ED9ED012A8C254
    3 Faults Found:
    00300 - Transmission Fluid Temp. Sensor (G93)
    27-10 - Implausible Signal - Intermittent
    01314 - Engine Control Module
    49-10 - No Communications - Intermittent
    01316 - ABS Control Module
    49-00 - No Communications
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 1C0 909 605 F
    Component: 04 AIRBAG VW61 0202 0003
    Coding: 12340
    Shop #: WSC 00066
    VCID: 2757D825C5F634C
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
    Part No: 1J5 920 906 N
    Component: KOMBI+WEGFAHRSP VDO V52
    Coding: 15234
    Shop #: WSC 05051
    VCID: 38750B591848AB4
    2 Faults Found:
    01039 - Coolant Temperature Sensor (G2)
    29-10 - Short to Ground - Intermittent
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 00066
    VCID: F0E57379B0B8B34
    1 Fault Found:
    Address 46: Central Conv. Labels: 1C0-959-799.lbl
    Part No: 1C0 959 799 C
    Component: 1H Komfortgerát HLO 0003
    Coding: 00258
    Shop #: WSC 00066
    VCID: 377708651556A4C
    Subsystem 1 - Part No: 1C1959801A
    Component: 1H Tõrsteuer.FS KLO 0202
    Subsystem 2 - Part No: 1C1959802A
    Component: 1H Tõrsteuer.BF KLO 0202
    Subsystem 3 - Part No: 1C0959811A
    Component: 1H Tõrsteuer.HL KLO 0202
    Subsystem 4 - Part No: 1C0959812A
    Component: 1H Tõrsteuer.HR KLO 0202
    8 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    53-10 - Supply Voltage Too Low - Intermittent
    00928 - Locking Module for Central Locking; Front Driver Side (F220)
    54-00 - Incorrectly Equipped
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    00930 - Locking Module for Central Locking; Rear Left (F222)
    00931 - Locking Module for Central Locking; Rear Right (F223)
    00912 - Window Regulator Switch; Front Left (E40)
    01358 - Internal Central Locking Switch; Driver Side (E150)
    01359 - Internal Central Locking Switch; Passenger Side (E198)
    Address 56: Radio Labels: 3B7-035-1xx-56.lbl
    Part No: 3B7 035 180 G
    Component: RADIO 3CP 0005
    Coding: 00031
    Shop #: WSC 00066
    VCID: 244DCF29B4C0DF4
    No fault code found
    Any Ideas? I recently bought the unitronics 1+ but that is all that has been modified.
  2. Junior Member pahjetta's Avatar
    Sep 25th, 2011
    Camp Pendleton
    03-27-2012 02:21 AM #2
    bump
  3. Junior Member pahjetta's Avatar
    Sep 25th, 2011
    Camp Pendleton
    03-27-2012 02:33 AM #3
    bump
  4. Junior Member pahjetta's Avatar
    Sep 25th, 2011
    Camp Pendleton
    03-27-2012 02:48 AM #4
    come on guys some one has to say something
  5. Member Freddy24's Avatar
    Oct 16th, 2011
    Chicago, IL
    2001 GTI
    03-27-2012 02:53 AM #5
    All of a sudden white smoke? Out the exhaust? Engine? AC vent? Oil level good? Blown turbo? Does it even crank? What happens when u try to crank?
    01 GTI 10/14/11
    Gonzo Tuned
    Quote Originally Posted by boradie sucht View Post
    what good does searching do anymore? say in 2 years when new people come on and have questions and decide to search first. and then this thread pops up, when its all idiots like you telling him to search. whats the point of that, either contribute or STFU
  6. Junior Member pahjetta's Avatar
    Sep 25th, 2011
    Camp Pendleton
    03-27-2012 02:55 AM #6
    when i crank the engine over it turns perfectly but no start or stumble. smoke cam from under the hood behind the motor
  7. Member Freddy24's Avatar
    Oct 16th, 2011
    Chicago, IL
    2001 GTI
    03-27-2012 03:36 AM #7
    Quote Originally Posted by pahjetta View Post
    with the very little knowledge i have, i would say rest in peace ko3
    01 GTI 10/14/11
    Gonzo Tuned
  8. Junior Member pahjetta's Avatar
    Sep 25th, 2011
    Camp Pendleton
    03-27-2012 11:46 AM #8
    I took the turbo off this morning and there is no excessive end play or and nicks on the impeller. Could it be the engine blown or what ?
  9. Junior Member pahjetta's Avatar
    Sep 25th, 2011
    Camp Pendleton
    03-27-2012 12:06 PM #9
    bump for a good cause
  10. Junior Member pahjetta's Avatar
    Sep 25th, 2011
    Camp Pendleton
    03-27-2012 01:30 PM #10
    bump
  11. Junior Member pahjetta's Avatar
    Sep 25th, 2011
    Camp Pendleton
    03-27-2012 04:28 PM #11
    bump
  12. Junior Member pahjetta's Avatar
    Sep 25th, 2011
    Camp Pendleton
    03-27-2012 06:58 PM #12
    bump
  13. Member
    Apr 13th, 2011
    Minnesota
    Overpriced & Underpowered
    03-27-2012 07:11 PM #13
    post in the technical forum if you want actual answers......
