Results 1 to 4 of 4
Thread: reciever speaker outputs?
  1. Member 1.8t gtilove's Avatar
    Nov 15th, 2007
    central il
    03' volkswagen gti
    03-28-2012 07:29 PM #1
    so i installed several ceiling speakers throughout my house and when i went to hook up my new reciever i'm not sure where i need to install the wires. it's not surround sound, i just want the radio and components to play over the speakers. i tried them on the speaker jacks but it sounded real weak. any ideas?
    this is the reciever...
    http://www.crutchfield.com/p_158STN1...20.html?tp=179
  2. Member zhenya00's Avatar
    Aug 7th, 2003
    Ithaca, NY
    03-29-2012 08:46 AM #2
    How did you wire them? More information would be helpful.
    That said, you have a couple of options.
    That receiver can natively run two separate sets of stereo speakers. Hook one set to the jacks marked Front A and the other to the jacks marked Front B in small print. Use the Speaker button on the front to switch between them. It may or may not allow you to drive them both at the same time.
    Second, if you don't want to also use the receiver for home theater/surround sound, and your receiver has an 'all stereo' or '7 channel stereo' mode or something similar, it can effectively run 3 sets of speakers, albeit with no individual control. You could wire volume controls in line to each set of speakers to get your own manual control. Wire as above and add a third set to the Surround jacks and then choose the All Stereo mode.
    Beyond this, things get a bit more complicated, as you need to add a speaker control box. This seems simple, but realize that most of these wire in the additional speakers in parallel, which reduces the load seen by the amplifier, and can damage your equipment. These typically recommend an amplifier that can drive 4 ohms which yours cannot, so research carefully.
    Another option is to do the above, and add an impedance matching volume control at each set of speakers, which would allow you to tailor the load to work for your particular components. Again, tread carefully.
    1987 Mercedes 190E 16v Cosworth
    1997 Volvo 855 T5
    2010 Volvo XC90
  3. Member SurferbobGolf's Avatar
    Aug 10th, 2005
    Tallahassee, Florida
    2012 VW CC R-Line
    03-29-2012 10:07 AM #3
    Is this receiver strictly for running these ceiling speakers? Or does it also control your home theater?
    I would run it as suggested above, to Front A, and B. You should be able to select either A, B or both to play.
    Flickr
  4. Member 1.8t gtilove's Avatar
    Nov 15th, 2007
    central il
    03' volkswagen gti
    03-29-2012 10:06 PM #4
    Yes this reciever is only running the ciling speakers. thanks for taking the time to give such a detailed response.
    well here are the products i used and as for wiring, i ran a pair of wires from the receiver to each of the 5 different volume controls throughout the house. then from each control i ran out to 1 or 2 speakers wired in parallel.
    http://www.leviton.com/OA_HTML/Produ...minisite=10251
    FEATURES AND BENEFITS
    (In-Wall and In-Ceiling Models)
    • Kevlar® composite woofer – Woofer construction combines
    exceptional rigidity and lightness to provide the perfect linear
    movement needed to reproduce dynamic, tight bass and
    incisive midrange frequencies
    • AeroNylon tweeter diaphragm – Aerospace-grade
    nylon tweeter diaphragm combines very low mass and high
    tensile strength to provide crystal-clear treble response and
    exceptionally accurate tracking of even the most challenging
    musical transients
    • AutoSurge™ circuit protection – Built-in AutoSurge
    protection responds to potentially destructive power peaks
    automatically and resets after the event, helping prevent
    speaker damage
    • Advanced phase/time alignment guide – A precise
    phase/time waveguide is used to properly align sound without
    mis-aligning the tweeters – a problem with many adjustable
    in-wall speakers – in order to provide extremely accurate
    stereo imaging
    • Precision dividing network – The dividing network (or
    crossover) used in all Spec-Grade Sound speakers is made of
    high-spec components to ensure total audio signal electronic
    integrity up to the last microsecond before the signal is
    converted into sound
    • Inert mounting frame with “dogleg” installation
    points – To eliminate any transmitted vibrations that could
    color in-wall or ceiling sound quality, Spec-Grade Sound
    speakers rely on a baffle-frame assembly incorporating
    higher-density plastics and a series of adjustable “doglegs”
    to rigidly clamp the speaker to the wall or ceiling material
    SPECIFICATIONS
    6.5-inch Two-Way In-Ceiling Loudspeaker
    (Cat. No. SGC65-00W)
    • 6.5-inch Kevlar composite cone low-frequency transducer
    • .5-inch AeroNylon dome high-frequency transducer
    • 2-way balanced precision crossover network with AutoSurge
    circuit protection
    Frequency Response: 50-20kHz +/- 3dB
    Sensitivity: 87.0 dB SPL @ 1Watt/
    1 Meter
    Power Handling: 120W peak/60W RMS
    Impedance: Nominal 8 Ohms/
    Minimum 6 Ohms
    Physical Dimensions and Weight:
    Diameter: 9.03 in/229.4 mm;
    Depth: 3.25 in/
    volume control
    Dimensional Data
    Height: 4.06 Inch/103.2 mm
    Width: 1.31 Inch/33.4 mm
    Depth: 2.50 Inch/63.5 mm
    Material Specifications
    Color: White
    Resistor Type: Cermetile
    Mechanical Specifications
    Mounting Location: Wall Mount
    Technology: Digital
    Switch Positions: Precision 12-Position
    Attenuator Type: Transformer-Free
    Performance Data
    Frequency Response: 20Hz-20kHz +/- 1dB
    Power Handling RMS: 100 Watts RMS
    Power Handling Peak: 200 Watts Peak
    Impedance: 2-16 Ohms Nominal 8 Ohms
    Product Features
    Type: Volume Control
    Style Name: Leviton Spec-Grade Sound
    Switch Type: Slide
