#1
SHELL SOLD
dash sold
engine sold
door & tail lights pending
wheels sold
good auto transmission with shift and throttle cables 150
front and rear disc 150
grill with headlights 50
radiator 40 with fan 50
ac condensor 450
heater core and blower assemble non AC 45
misc e-brake cables ask...
1982 VERY CLEAN Rabbit,
restored for daughter last year
I had gone through most everything new wheel bearings-suspension-brakes-added rear disc-replaced fuel accumulator-pump
Dyed carpet black-painted door cards- new fabric headliner- added sound deadening
fresh $900 maaco white paint
well accidents happen.
she is hit in passengers side door pillar but hood is straight front horns measure out fine
needs door, fender, windshield and the pillar replaced or some shops can do magic!.
VERY SOLID as you should be able to see from pic at rocker panel , removed door and fender
Purchase just the shell with rear axel beam with disc, door, hatch, hood, bumpers lights gas, tank pump accumulator attached complete wiring all worked $450
or with other parts with below $900
1988 1.8 less than 15K original miles (i bought in 1990) finally used in this car.
atuo transmission TN series i believe serviced runs strong
seats very clean no damage from 88 cabby
good dash with wood grain panel
axels
new front calipers and rotors
I am keeping the wheels and tires shown as they are brand new.
if does not sell as complete will begin to part out day after Easter (April 8)
thanks for looking, please ask any questions located SW OHIO
just from paint shop
with door and fender removed removed dash to make sure was not damaged, lower plastic panel was cracked
COMMON SENSE IS NOT SO COMMON.
