Originally Posted by
KOWCC
Easiest thing ever!! i did it last night to install my silver turn signals, took me about 60 seconds each side. After you remove that carpeted piece, you will see that white tab that holds all the bulbs. There is a wire connector there as well, pull that blue tab that says "pull" or "open", as if you are actually disconnecting the electrical. As you are doing that with your thumb, have your remaining fingers on the white strip and pull out. Very very easy. HOpe this helps.
