shift light and bounce off rev limiter
#1
I've been looking into building a 16v ABA with ITB's.
So far it seems like the higher power NA builds have a rev limit WAY higher than the stock 7g red line of a mk3.
So just curious as to what you guys have done to keep an eye on your revs. I know I could always get an aftermarket / external tach, but I'm going for as much of an OEM look as I can, so I'm more interested in anything I could do to replace / modify the existing tach in the gauge cluster?
Any Ideas? Suggestions? Thanks!
Eurofine
'95 Jetta 2.0: R.I.P. || '92 GTI ABA: Current Project || 2000 GTI 1.8T: Current Daily
FS: OBD1 ABA + parts
#2
#3
isn't the rev limiter set to 7000?
I'm planning on going stand alone so I won't have a preset limit.
Eurofine
#4
stock is prob lower than 7k. with standalone you can set it to what you want.
#5
You should be able to make a standalone drive the stock tack.
FS:Sunroof Deflector
#6
I wasn't worried about the stock rev limited, or using the stock gauge, but if my car Revs to 10k RPM, I would like a Tach that doesn't stop at 7k.
I feel like aftermarket will be pretty much the only option.
Eurofine
#7
Yeah unless you run the output at 1/2 speed.
-Paul
1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
Build Thread: The Build Thread "Good Clean Fun"
#8
yeah.... Id run it at half
Forced convection.... Now we grillin.
Some times she goes, some times she doesn't.... Way of the road
Rem 870 super mag in max 4 camo for sale. Pm me
#9
Anywhere you guys could point me as to how I would do that?
Eurofine
#10
In ms its an option under tach speed for the output. Other systems, no idea.
-Paul
#11
#12
Eurofine
#13
Most cams are going to be best between 7-8k rpm. Even with ITB's. The costs in the build to go higher than 8k rpm become kinda silly, and that is mostly $ thrown at the valve train and port work.
#14
The real question is does it make power at X rpm?
#15
Thinking about getting 276* cams with solid lifters and a fully rebuilt head.
Multi angle valve job
port and polish
So on so forth.
Think 9k is still too high?
Bonesaw, Does lugtronic have the option to run the tach at different speeds?
Figured I'd ask you because its in your sig.
Eurofine
#16
From what I know, that target is beyond the useful range of that cam profile. Even the 288*'s are most useful at or below 8k.
#17
So 8k is about the limit unless I go full out race car?
Eurofine
#18
there is a tach divider, but sure how useful that would be. 8K is now 4K? really doesnt make much sense. you get a feel for where the needle goes when it reaches certain RPM. you can also use a digital Tach and/or a shift light.
#19
If I have more options than just cutting it in half it could be useful with a new Gauge over lay.
Eurofine
#20
#21
Is it possible to use hydro cams with solid lifters?
The solid lifters are about $12 more a piece (so about $200 more than LW) which really isn't bad. And if I can get parts that can take more abuse without negatively affecting performance, I will.
Thanks guys![]()
Eurofine
#22
#23
Glad I found that out before I started buying parts haha, although I feel like somewhere along the lines I would have picked that up.
I'm planning on buying as many parts as I can new. I know it will make the build cost a lot more, but I'd rather spend more to get something new than have a used part fail on me.
Plus I really like the idea of a motor with miles on nothing but the block and the head itself.
Eurofine
