Results 1 to 3 of 3
Thread: New TB New TPS still f**ked
  1. 03-30-2012 12:14 AM #1
    okay i just replaced the TB and Throttle positioning sensor cuz thats what i was getting codes for but they are still there. i checked the wires to the o2 sensors they are fine. changed the o2 sensors didnt do anything. when i go to engine readiness almost everything is failed except AC and EGR.
    i am thinking its the ECU but i want opinions before i go to VW to get them to re-code the used one i bought.
    engine
    18039 - Accelerator Position Sensor
    18042 - Accelerator Position Sensor 2
    17581 - Angle Sensor 2 for Throttle Actuator
    17987 - Throttle Actuator
    ABS
    01314 - Engine Control Module (pease check fault codes)
    Instruments
    01314 - Engine Control Module (no communications)
    central conv.
    (there are a bunch of window regulator codes in there and door module codes but all the windows and doors work fine.)
    but this one i thought was weird cuz i dont have heated mirrors..
    00943 - Heated Exterior Mirror
    please someone help i am about to just get the new ECU remapped and if that doesnt work sell it as it i donno wtf is going on.
    P.S. when it says check ECM fault codes. that just means check engine fault codes ya?
    Quote Originally Posted by SoIAteAPancakeToday View Post
    it would whisper in your ear, "lrn2offsetbrah."
    Jul 19th, 2010
    In the south, but not the "barefoot and toothless" south.
    2004 VWs
    03-30-2012 10:08 AM #2
    You need to post a full Auto-Scan:
    Make sure you are using the latest version of VCDS as well:
    http://www.ross-tech.com/vcds/download/current.html
    Once a full Auto-Scan is posted, we will dig in and try to help you resolve this.
    Jef blah blah blah
    071, 070, 034, 036, 046, 077
    Feb 25th, 2010
    Wilkes-Barre, PA
    03-30-2012 10:42 AM #3
    I think I have your answer but need an auto scan first.
    Good luck
