VWVortex.com - light output is different
    Results 1 to 4 of 4
    Thread: light output is different
    1. Member eurorice's Avatar
      Dec 10th, 2005
      Cin City
      04 Platinum GLI
      03-30-2012 12:42 AM #1
      well i have a 2004.5 GLI and one of my headlights seemed to be noticeably dimmer than the other so i went ahead and ordered new bulbs thinking it was going out. i then install the new headlights and the driver's side headlight is noticeably dimmer just like before. it could be in my head but it seems as if the rear running light is also dimmer on the same side. does anyone know what could be causing this ?
      i have already checked fuses and i've already pulled my battery and checked the grounds underneath.
      TIA/P4C
      keith
      euroskope.net
      B-List Internet Celebrity
    2. 03-31-2012 07:30 AM #2
      What kind of bulbs are you using? Cheap/overwattage bulbs are known to fry the connectors on Jettas.
    3. Member eurorice's Avatar
      Dec 10th, 2005
      Cin City
      04 Platinum GLI
      03-31-2012 01:51 PM #3
      i had sylvanias in there when it happened, seems like it's just the headlight btw
      fogs and tail lights are the same, so it has to be in the headlight somewhere.
      keith
      euroskope.net
    4. 04-01-2012 07:03 AM #4
      Sylvania bulbs should be fine - but I'd still check the bulb connector. It could be damage from a bulb that the previous owner used.
      Are both the high and low beams dim?
