Results 1 to 8 of 8
Thread: Suspension Problem?
  1. Junior Member Theescapist's Avatar
    Dec 31st, 2011
    Maryland
    '92 Volkswagen Cabriolet WE
    03-30-2012 08:03 AM #1
    Yesterday I hit railroad tracks pretty hard in my '92 cabby and noticed something didn't seem right driving on my way home.
    This is the drivers side front tire
    Passenger front
    I'm not really sure what's wrong, or if I should even drive it to my mechanics house.
    Help?
  2. Member oneunder's Avatar
    Mar 31st, 2009
    Minneapolis, MN
    89 Cabby, 01 xit
    03-30-2012 09:12 AM #2
    I am guessing its a broken spring. Stock suspension I am guessing?
    "Those two piece splits are as close to fakes splits as real splits get"
    May 16th, 2004
    1986 16v Rocco
    03-30-2012 09:15 AM #3
    takes only a few minutes to take the tire off and really look.
    take it off and take a picture
    Apr 16th, 2009
    Wild Wonderful Wv.
    1965 Beetle, 1987 Triple White, 1988 cabriolet, 1993 2dr Fox gl, 1999 Jetta GL
    03-30-2012 09:22 AM #4
    Which pic is how it "normally" sat before ? Its possible you moved/spun the coilspring in the upper/lower spring perch ? What do the strut bushings look like at the top of the strut towers under the hood ? Both wheels seem centered in the wheel wells so I'm not thinking a popped out or broken ball joint ?!
  5. Member oneunder's Avatar
    Mar 31st, 2009
    Minneapolis, MN
    89 Cabby, 01 xit
    03-30-2012 09:46 AM #5
    With 19 posts, and asking what could be wrong, I am assuming OP is not highly technical (which is totally OK). That being said, I doubt there are coil overs or other modified suspension its.
    A blow upper strut mount is also a good guess though. All you need to do is pop the hood and compare the right, and left strut mounts. It should be blatently obvious if it is blown out better part of two inches.
    My guess is still a broken spring....I am also guessing that it is original suspension.
  6. Junior Member Theescapist's Avatar
    Dec 31st, 2011
    Maryland
    03-30-2012 04:46 PM #6
    The struts are being replaced next week anyway, but they are even.
    And I was planning on buying raceland coilovers next week also so maybe now I have a reason to.
    Yeah, no way in hell could I take the whole tire off :p
  7. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    03-30-2012 06:15 PM #7
    Taking the tire off means to remove the tire off the car as if you are changing a flat. Then inspect the suspension. I have seen broken Strut mounts cause that kind of "lowering" also, you can really notice a broken upper strut mount by the rod denting your hood
    Where are my grounds ?
  8. Junior Member Theescapist's Avatar
    Dec 31st, 2011
    Maryland
    03-30-2012 06:37 PM #8
    I know what he meant, haha.
    Thanks everyone~ I'm pretty sure I'll be buying new coilovers and such in the next week just not sure which kind yet.
