Results 1 to 14 of 14
Thread: Question for those who know about MD's
  1. Senior Member .LSinLV.'s Avatar
    Nov 13th, 2009
    Vegas/Carbondale
    00' VR6 12' V6 TDI 72' 914-6
    03-30-2012 10:14 AM #1
    of all the AC I see on a daily basis, only one has the engines tilted down, the MD series. If anyone knows as to why, I'd like to know as this is a curious design. I'll have to check on the 95's and the 717's as I don't think these AC with the larger BR700 engines have this like the older AC with the JTD's.
    in fact, if the AC is horizontal in flight, the nacel's AOA seems like it might mitigate smooth flow into the engine, let alone vectored thrust out the back (which is down).
    anyway....just curious.
    TIA
    Larry
  2. 03-30-2012 10:21 AM #2
    Quote Originally Posted by .LSinLV. View Post
    TIA
    I'm no engineer, but it would seem to me that it might have something to do with the way the air flows over the tops of the wings in a curved fashion (assuming you're just talking about aircraft with tail mounted engines).
  3. Senior Member .LSinLV.'s Avatar
    Nov 13th, 2009
    Vegas/Carbondale
    03-30-2012 11:15 AM #3
    maybe...but look at these images to better see what I am talking about:
    MD-80 Series
    MD-90 Series
    Boeing 717
    Here is the Boeing 727 Series, note the engines and their AOA, no noticable angle difference from fusalage.
    Llyshin II-62
    Larry
  4. 03-30-2012 02:57 PM #4
    Quote Originally Posted by joness0154 View Post
    this or better takeoff performance?
  5. Member B3sat16v's Avatar
    Jan 23rd, 2002
    Around the world
    MH-60R
    03-31-2012 06:33 PM #5
    It is PBFM! Most likely due to airflow, CG (Vectoring the thrust slightly downward keeping the nose down with low loads up front), to get the best answer you would have to ask an Engineer that designed these aircrafts. Any of our answers are going to be pure speculation.
    And the IL-62 has a downward tilt as well as the VC-10, and so does the 727. Your picture does not show it too well.
    And as we know the 727 has a nose low attitude with WOW.
  6. Member
    Dec 11th, 2002
    '03 Golf TDI
    03-31-2012 06:54 PM #6
    Here's what the original DC-9 manual says:
    "The nacelle axis and pylon have been set at 3 degrees angle of attack relative to the fuselage to align them with the local flow conditions prevalent at cruising conditions. This is necessary to eliminate the interference and high induced drag that they would otherwise be subjected to. The nozzle is then canted upward relative to the engine axis, thus eliminating the pitching effects due to thrust.
    The air coming of the back of the wing is headed down just a bit after following the camber of the top surface.
    If it's not foggy
    and you have your fog lights on
    you are a doofus.
    "Pro Tip: Don't **** with people who've been trollin' longer than you've been alive." - OOOO-A3
  7. Member Zombiee313's Avatar
    Apr 27th, 2011
    Bay Area, CA
    Old Ford Truck
    03-31-2012 07:17 PM #7
    A-10's are like that also
    You should instead be praising the fact that life is so good, and safe that you can be afforded the luxury to be outraged by the death of one civilian, at the other end of the world. That's phenomenal.
    Quote Originally Posted by Jim Harbaugh
    Who's got it better then us?!? ...... Nooooo-body!!!
  8. Member B3sat16v's Avatar
    Jan 23rd, 2002
    Around the world
    MH-60R
    03-31-2012 07:21 PM #8
    Quote Originally Posted by Gern_Blanston View Post
    After reading that, I went and looked and some pics and damn the nozzle is canted quite a bit upwards in the DC/MD aircrafts, but the above one from the 727 it is not canted at much upwards.
  9. 03-31-2012 09:00 PM #9
    Quote Originally Posted by B3sat16v View Post
    The quiet kits that are installed make it look like they are at a less severe angle than 3 degrees.
    Plus the angle of the picture makes it seem weird too.
    But the pitch of the engine in relation to the rest of the fuse can be noticed.
    Quote Originally Posted by DIAF
    Mass murders are so statistically insignificant that they should not be used as a basis for any policy, particularly any policy that would infringe on individual rights.
  10. Member B3sat16v's Avatar
    Jan 23rd, 2002
    Around the world
    MH-60R
    03-31-2012 09:29 PM #10
    Quote Originally Posted by dubraycer36 View Post
    We are talking about the Nozzles right? Because the engines are tilted, and what Gern posted talks about the Nozzle being canted upward to maintain the thrust at linear as possible to avoid a moment causing a nose down attitude.
    Let me maker sure I explain. The Inlet (Diffuser) is canted upwards to take advantage of a more straight flow due to the downward flow coming from the top of the wing. The nozzle is also canted upwards to cancel any angle with relation to the longitudinal axis of the aircraft, thus providing a thrust vector that wont cause any moments. This can be seen very well on the DC/MD pictures, but I know for a fact that the IL-62 does not do this (Also seen in photos), as well as the VC-10 and if you look at the 727, the upward canted nozzles still have to angled thrust (Downward).
  11. Senior Member .LSinLV.'s Avatar
    Nov 13th, 2009
    Vegas/Carbondale
    04-03-2012 09:32 PM #11
    thanks guys! I appreciate all of the help/input.
    Larry
  12. 04-04-2012 09:10 AM #12
    This image is somewhat exaggerated, but gives a good idea of the effect they're talking about:
  13. Geriatric Member ATL_Av8r's Avatar
    Oct 17th, 2002
    Gapiana
    04-04-2012 09:20 AM #13
    Come on Larry, you've been in the MKIV forum. it's all about the reverse rake
  14. Senior Member .LSinLV.'s Avatar
    Nov 13th, 2009
    Vegas/Carbondale
    04-18-2012 06:51 PM #14
    so is that why 757's have such a sharply angled cockpit/front of the fusealge??
    Larry
