Results 1 to 5 of 5
Thread: 02A into mk1 peeps - standard 100mm driveshafts work?
Hybrid View
    Sep 28th, 2001
    Belmont, CA
    '81 Z1 Scirocco Ragtop, '78 CE (gone :(
    03-30-2012 11:55 AM #1
    Hi all - swapping in a 02A into a mk1 scirocco. I was originally under the impression that standard 020 100mm driveshafts would work. But in talking to Mike Potter last night, he said that he's heard they don't quite fit...anyone know or have experience w/ this? Need to order soon.
    Thanks! JT
  2. Member InSaneV's Avatar
    Oct 24th, 2009
    Calgary, AB.
    84 Jetta coupe 2.0slow 79 Rabbit 8VG60
    03-31-2012 12:43 AM #2
    By standard you mean what?
    mk2/mk3 100mm drive shafts will not fit in your mk1
    mk1 100mm drive shafts will of course work ie 16v scirocco and or later cabriolets 85+ ish
    " if you owe a VW and DON'T have AAA gold...your an idiot haha " - NOTHING LEAVES STOCK -
    " Because a 16v g60 sounds like the hand of god bitch slapping your car. " -lagomorph-
  3. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    03-31-2012 09:50 AM #3
    Should be no problem as long as you have 100mm inners in whatever you are running.
    I have mk2 axles in my mk3 with 02a, and have run a mk3 020 in my mk1 with late cabby axles.
    -Paul
  4. Member d-bot's Avatar
    Sep 6th, 2004
    Par 5 from the Space Needle, PNW.
    80 Storm 20vSC Syncro, 93 Corrado VR6
    04-02-2012 09:37 AM #4
    I have always ran 100mm cabby or rocco axles w/10.1 brakes and 02A/J transmissions in mk1 chassis with zero issues and great OE fit!
  5. Member fredybender's Avatar
    Nov 17th, 2008
    Montreal Canada
    81 Rocco,80 Rocco track, 81 Rocco Haldex twin charge Berg cup project, 84 Mk1 Jetta coupe
    04-07-2012 08:26 PM #5
    I can say from experience, that they do fit, but:
    If you have a header, the inner CV boot on the PX side, will rub on the headers.
    Solution: A TT driveshaft boot has internal bellows instead of outwards...
    80$ boot, but its a bolt on...
