Originally Posted by
polska_ts
you can run it just like sub wire depending on what kind of tubing you have. underneath the molding on the bottom of the door. there's lots of room under there and as long as your not full force foot stomping the molding you should be fine. then once you get up to the front there's a hole in the firewall behind and a little ways up from the brake pedal if i'm not mistaken. you can mound your pump wherever but i would do it in the front just because its a lot easier to get power to it.
