Page 7 of 10 FirstFirst ... 3 4 5 6 7 8 9 10 LastLast
Results 211 to 245 of 346
Thread: OEMMODS famiry purchase
  1. 05-10-2012 06:22 PM #211
    white ligts are racing dash lights. They have like 20 leds inside.
    red lights use 194
    Oct 13th, 2008
    H & SA, TX
    08.5 A3
    05-10-2012 06:35 PM #212
    white lights are like these then?
    http://www.rdash.com.tw/en/product_d...ber=LL5603892W
  3. 05-10-2012 06:43 PM #213
    yes sir those are the ones
  4. Member
    Jul 30th, 2008
    NYC
    05-13-2012 03:07 AM #214
    LEDs came in the mail. Where are da installation dvd or instructions that is suppose to come with it?
  5. Member neu318's Avatar
    Feb 17th, 2003
    Coral Gables, FL
    2003 Silverstone GTI 1.8t(Gone), 2006 Brilliant Red Audi A3 3.2Q
    05-13-2012 10:44 AM #215
    Got mine as well. Could you maybe give us a few pictures of how the connections go tp?
    Mods:Unitronics Stage 1+ | UM DSG Tune | Magnaflow Catback | HPA SHS Coilovers | MODSHACK VTDA intake
    VRSociety #172
    Quote Originally Posted by Boost112 View Post
    Interests:Food being shoved in hot chicks faces.... and other stuff....
  6. Member krazyboi's Avatar
    May 19th, 2004
    NoVA
    2006 A3 3.2T
    05-13-2012 02:14 PM #216
    Footwell light instructions: http://audi-diy.blogspot.com/2007/10...installed.html
    Trunk lights is basically this to remove panels, but on both sides: http://forums.fourtitude.com/showthread.php?2741663
    722 pages, 25255 posts, and 1,015,739 views later... R.I.P. LoL Bump thread 03/27/2008 ~ 02/16/2011.
    Link to my build: Audi A3 3.2 VR6 BT
    VMR l Wheels - V721
    Jul 30th, 2008
    NYC
    05-13-2012 06:49 PM #217
    where does the trunk light cable go? thru the roof area of the liftgate, by where the liftgate latch is or by the seat folding area?
  8. 05-13-2012 07:55 PM #218
    yo PM me you guys email i can forward instructions on the trunk. I have no done instructions on the door yet. I will do instructions tomoorw night. SORRY!!
  9. 05-13-2012 08:01 PM #219
    1. Torx screw
    2. torx screw
    3. pull up
    4. pull where the arrow is going
    5. run cable
    6. shows u where to run cable
    7. cut 8 vents off like in picture( I think i did it wrong on this
    one, because the driver side is one vent above the lower vent not 2
    vents higher than bottom. Double check your car first. And double
    check before you cut, but its up to you to see where you want to put
    the light. You can only cut once I suggest you cut 6 vents off first
    then test fit and cut and test and cut.)
    then put everything back in in reverse order
  10. Member
    Jul 30th, 2008
    NYC
    05-14-2012 01:33 AM #220
    install of trunk lights is pretty easy, if not for all the metal clips that doesn't pull out and/or breaks. the subwoofler instruction is more detailed on where the clips are.
  11. Member neu318's Avatar
    Feb 17th, 2003
    Coral Gables, FL
    05-14-2012 04:27 PM #222
    for the puddle lights I just need a visual of where the cables connect. that's all
    VRSociety #172
  12. 05-14-2012 04:30 PM #223
    Quote Originally Posted by neu318 View Post
    will get tonight!
  13. Member neu318's Avatar
    Feb 17th, 2003
    Coral Gables, FL
    05-14-2012 04:31 PM #224
    Quote Originally Posted by tp. View Post
    will get tonight!
    Thanks tp
    VRSociety #172
  14. Member neu318's Avatar
    Feb 17th, 2003
    Coral Gables, FL
    05-14-2012 04:32 PM #225
    oh, and if not listed yet, what changes need to be made on Vagcom. Thanks
    VRSociety #172
  15. 05-14-2012 04:49 PM #226
    06 door pin in the 32 pin.
    1 should be power
    2 should be ground.
    2 should be brown. If its brown take it out the female pin from the connector and connect it to the male pin on the harness. Use the supplied heat shrink to wrap those 2 connectors together. Connect the female end to the #2 connector housing. The harness has 3 pins, 2 females and 1 male. The one with the 2 pins together(male and female) is the ground wire.
    same as all doors for 2006
    VCDS need to activate door exit/warning light
    Goto chassis tab on top
    goto 42,52 for front
    62,72 for rear
    you will need to go coding. then add 64 to the total for door exit/warning lights installed.
    2007+
    pin 18 for power
    19 for ground
    rear
    1 power
    2 ground
  16. Member
    Jul 30th, 2008
    NYC
    05-14-2012 05:22 PM #227
    what do we do with the 2 yellow straws? Is it to focus the light into a tighter cone or some sort of drain?
  17. 05-14-2012 05:24 PM #228
    Quote Originally Posted by LWNY View Post
    those are heatshrink tube.
    for the pin that you take out of the connector housing and connect to the male pin on the harness.
    i'll get you pics tonight.
  18. 05-14-2012 11:22 PM #229
    FOR 2006 Please use pin 1 power and 2 ground for front doors
    FOR 2007+ Use 18 power, 19 ground
    Ground wire will be the wire that has the split
    These pics are 2006 model year. 2007+ please find the pin 18 and pin 19 and do as above.
    BROWN wire always ground.
    1: remove the brown wire, use pin or small flat head
    2:Connect the male end from the cable loom to it the brown wire
    3:Use the supplied heat shrink tube to cover the open connection
    4:Ground cable goes to 2 and power goes to 1. (2007+ use 18 and 19)
  19. Member neu318's Avatar
    Feb 17th, 2003
    Coral Gables, FL
    05-15-2012 08:56 AM #230
    Awesome, just what i needed
    VRSociety #172
  20. Member krazyboi's Avatar
    May 19th, 2004
    NoVA
    2006 A3 3.2T
    05-15-2012 09:10 AM #231
    Great, get yours installed, then you can install mine at SoWo. Not sure I'll have time.
    VMR l Wheels - V721
  21. Member neu318's Avatar
    Feb 17th, 2003
    Coral Gables, FL
    05-15-2012 09:12 AM #232
    Quote Originally Posted by krazyboi View Post
    LOL, i don't have time either I had ordered the red warning lights from this company last week and it still hasn't shipped. So I waiting to get them so I don't have to take the doors apart twice.
    By the way, where are you going to be at SOWO? Is your car going to be at a booth or are you just parking with the rest of the population?
    VRSociety #172
  22. Member krazyboi's Avatar
    May 19th, 2004
    NoVA
    2006 A3 3.2T
    05-15-2012 09:23 AM #233
    My plan is to show the car. Not sure what that will do b/c my wheels look like crap all curbed up and all
    VMR l Wheels - V721
  23. Member neu318's Avatar
    Feb 17th, 2003
    Coral Gables, FL
    05-15-2012 09:30 AM #234
    LOL , I guess I'll try to find your car, hope it's not too crazy. I've never been to SOWO so I don't know what to expect
    VRSociety #172
  24. Member krazyboi's Avatar
    May 19th, 2004
    NoVA
    2006 A3 3.2T
    05-15-2012 09:46 AM #235
    Same dude. Not sure if you saw what I posted in the A3 @ SoWo thread, but there's suppose to be a Audi photoshoot / dinner Sat. evening around 6pm if you don't have plans yet.
    http://forums.vwvortex.com/showthrea...1#post77374440
    VMR l Wheels - V721
  25. Member neu318's Avatar
    Feb 17th, 2003
    Coral Gables, FL
    05-15-2012 10:11 AM #236
    Cool. Thanks I'll check it out. I'm going to SOWO with almost 30 people so I'll try to find time and see if others want to join
    VRSociety #172
  26. 05-15-2012 11:56 AM #237
    you actually dont have to take door card out 2 times. just tape the cable to the red reflector. and pull off reflector once the light comes in and plug it in.
  27. Member neu318's Avatar
    Feb 17th, 2003
    Coral Gables, FL
    05-15-2012 11:58 AM #238
    ah ok, right since the hole is already there for the warning light. good idea. I'll see if I get around to it. thanks
    VRSociety #172
  28. Member
    Mar 23rd, 2011
    Charlotte
    2008 a3 sline
    05-15-2012 12:28 PM #239
    tp...any luck with sending out anymore packages?
    i've got a fever...and the only prescription is...famiry lights
  29. 05-15-2012 12:50 PM #240
    My buddy took turn to make them this weekend. I am waiting for him to txt me back on how many he has done then i can go pick up.
  30. Member krazyboi's Avatar
    May 19th, 2004
    NoVA
    2006 A3 3.2T
    05-15-2012 01:00 PM #241
    His buddy is 7 y.o. He works in a sweat shop w/ other kids. He will have to borrow mommy's phone to text.
    VMR l Wheels - V721
  31. Member
    Jul 30th, 2008
    NYC
    05-16-2012 02:54 AM #242
    after install, trunk looks like FOB friend's living room, with their hanging florescent fixture with their 40 inch tubes lighting up every crevice of the room.
  32. 05-16-2012 12:31 PM #243
    picking up cables tomorrow. ship friday. UI shold have evrey ones ready.
  33. 05-18-2012 02:04 AM #244
    Aiight Problem.
    I dont have enough pins to make the cables. SO 2 guys will have to wait a bit longer to get their sets. SOrry ~~~ I order from pin manufacturer will take a while.
  34. 05-18-2012 03:50 AM #245
    Just a heads up - I got mine
