#281
One observation. The LED sez they will not produce bulb out errors, but when i hooked only one up, the bulb turned on and quickly turned off. I just assumed that I had to hook both up, but if I wuz to hook one up, it would never lite up. Is the dual units suppose to replace 1 OEM unit?
#282
hirro
#283
#285
Received. Thanks teepee!![]()
#286
hey tp is it pin 1 and 2 for rear doors aswell for 2006 audi a3?
#287
I ended up getting all the doors working now, was a alot of work with the cutting otherwise wiring and putting everything back together was simple.
#288
Does this need vag com to run power? I think i'm all hooked up right but kinda hard to tell because these pics are from an 06 and mine is an 08. I hooked everything back up and tried to turn on the car to accessory mode and no lights come on. Don't have access to vag com atm but if I can't even test the power I'll finish the install now and vag com it later. ASAP replies please
#289
I read higher in the thread it is supposed to flash a few times when the car is turned on so did I not connect my wiring properly?![]()
#291
So I'm not even supposed to get a quick flash of power right? Ground goes to 18 and power to 19 on 07+ after heat shrinking the brown male to whatever I pulled from 19? maybe I followed tps instructions too closely and was supposed to put brown female into the 19 and power into 18?
#292
I doubt it. The controller won't send power to a component that it is programmed to believe is not there.
#293
yes 18 power 19 ground.
Brown male pin is ground.
You need to activate via vagcom.
if not activated you will not see anything.
#294
Ok fronts done now for the rear doors the male that im supposed to heat shrink is not in 19 its solid brown in slot 2 but im 07+ should I be following directions for 06 just for rear doors?
#295
soif i don't vagcom, can i hook it up to a 9v battery instead? no need to take the door card off. Or maybe tap into the power windoze juice line?
#296
#297
#298
Bump for help on the rear doors they dont match the pics tp posted of course since I have an 08 but still confused about the wiring tired of driving without rear door panels onat least they are all cut and installed just wiring ill try to get pics tomorrow
#300
Solid brown for rear doors is what heat shrinks to the male as well? I think atm its under #2 sounds right just wanna be sure
#302
Installed the trunk lights today...super easy. Will knock out the pudlle lights this week...thanks again tp![]()
#303
Attempting to install the front puddle lights. It appears the ground wire is a thicker gauge than the supplied wiring and on the 07+ the female connector on the ground is larger than the female with the supplied wiring. The new grounf doesnt seem to fit into the original pin position 19. Am i missing something here?
Assistance please...on the plus side the cuttng was simple
#304
#305
#306
#307
Is it possible we use pin 18 and pin 9? Pins 19 & 20 are larger than the 1-18
#308
hirro
#310
no worries...i have removed the door cards so many times already, it's not a big deal to yank them off again.
On my 2008 the harness looks different than the picture instructions posted earlier. It is smaller (only pins 1-18) and it clips into a harness with two thicker gauge wires (pins 19 & 20). This whole unit then clips into the inside door panel. Pins 19 & 20 are substantially larger which leads me to believe that the pins we need to use have to be somewhere from 1-18. Pin 19 is a brown wire, but there is also a thinner brown wire going to i believe pin 9.
The rear doors appear the sameway & the instructions say to use 1 & 2. Pins 1 & 2 on the rear are the correct size which leads me to believe the pins we must use on the fronts for 2007+ have to be somewhere between 1-18.
Thanks for the help![]()
#311
So if i wanted to get the red lights working as well, what all is involved? With the door cards off, it appears it is currently just a red cover. Is it just a light housing, bulb, and wiring that is needed?
I am guessing this wiring would need to go into the same harness as the puddle lights?
#313
#314
