Results 1 to 7 of 7
Thread: HELP my vrt !
    Aug 11th, 2010
    SoCally
    97 Jetta GLX
    03-30-2012 06:57 PM #1
    i just replaced a cracked coilpack since my car was running would go really lean under load/boost. and now after the new coilpack its not cranking! . i unpluged the maf and it will start but will run really rich, i tried another maf and it wouldnt start either. the car will start without a maf but will die out soon as either maf's contact the plug.
    I survived epic thread 2011 never forget 11/11/11
    Aug 11th, 2010
    SoCally
    97 Jetta GLX
    03-30-2012 07:00 PM #2
    car has no codes either, could it be my maf harness is shot?
    Aug 11th, 2010
    SoCally
    97 Jetta GLX
    03-31-2012 12:12 AM #3
    bump
  4. 04-02-2012 12:55 AM #4
    That sounds weird. And if the car is running and the MAF is plugged in the car should die. Sounds to me like the MAF is working as intended. Try clearing all the codes, and then do a TBA. If that doesn't work treat it like a old Chevy give it a little bit of pedal as you crank it over, so vrt's are super touchy after things are replaced.
    "I admit that I'm often...vexed by the behavior of my own people..." - Huey Freeman (The Boondocks)
    Aug 11th, 2010
    SoCally
    97 Jetta GLX
    04-02-2012 03:05 AM #5
    Now its not starting at all I ordered a new crank sensor and ignition switch I hope they fix the problem
  6. Member
    Aug 11th, 2010
    SoCally
    97 Jetta GLX
    04-02-2012 11:51 AM #6
    bump
    Aug 11th, 2010
    SoCally
    97 Jetta GLX
    04-04-2012 08:10 PM #7
