Results 1 to 11 of 11
Thread: Is it ok to use Bon Ami or Bar Keepers Friend on a MKVI windshield?
  1. Moderator EPilot's Avatar
    Jul 27th, 1999
    Blog Entries
    1
    Present:2012 GTI Past: 99.5 GTI GLX, 95 Golf Sport, 78 Bus…
    03-31-2012 11:09 AM #1
    Is it ok to use Bon Ami or Bar Keepers Friend on a MKVI windshield? Is there some type of coating that might be damaged by those products? I have this one spot that has some kind of film that refuses to come clean. Any suggestions? Thanks
  2. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    04-01-2012 09:50 AM #2
    Myself I wouldn't but I have used #0000 steel wool and soapy water.
  3. Moderator EPilot's Avatar
    Jul 27th, 1999
    Blog Entries
    1
    04-01-2012 02:08 PM #3
    Quote Originally Posted by Jesstzn View Post
    That seems more abrasive than Bar Keepers Friend or Bon Ami.
  4. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    04-01-2012 02:42 PM #4
    Quote Originally Posted by EPilot View Post
    Not really ... the soap is a lub .. there the others don't have one
  5. 04-01-2012 09:51 PM #5
    We use #00 steel wool all the time on glass w/o issue. I would reach for that over an untested chemical first. You have a chance to etch or stain glass with chemicals.
    Though if I were in an experimental mood I might try some soft scrub or comet. I've never used what you're asking about but if they are similar I would try an inconspicuous spot first like a side window, out of the field of view. Be sure to not let it dry and rinse thoroughly.
  6. Moderator EPilot's Avatar
    Jul 27th, 1999
    Blog Entries
    1
    04-01-2012 11:11 PM #6
    Interesting information on Bon Ami's website http://www.bonami.com/index.php/prod...wder_cleanser/
    Ingredients:
    Limestone ~ Calcium carbonate
    Feldspar
    Biodegradable cleaning agents ~ Alkyl polyglucoside
    Soda ash ~ Sodium carbonate
    Baking soda ~ Sodium bicarbonate
    I have used Bon Ami for cleaning automotive windshields ever since BMW recommended your product in response to customer complaints about road grime making it hard to see out in the rain. We use a vinegar and water solution to neutralize acid rain spots then follow up with Bon Ami and the glass looks like new!
    - Steve, October 2010
    So I guess if BMW recommended it, it must be ok.
    And then on the Bar Keepers Friend site…
    http://www.barkeepersfriend.com/car-care
    “This worked for me, Bar Keepers Friend. I found it by the Comet® at the local Walmart. I mix it with water in a bowl and made a paste out of it. I used a towel and rub it on the wet windshield in a waxing motion. I later sprayed it off and bada bing, no spots ! Like others, I have tried vinegar, CLR® , Scotch Brite™, etc.. This took me about 20 minutes using no more effort than normal waxing.”
    I guess I'll have to try it out.
  7. Moderator Jesstzn's Avatar
    Apr 20th, 2003
    BC CanaDUH
    04-01-2012 11:18 PM #7
    Go for it ..
  8. Member derekjl's Avatar
    Jun 23rd, 2006
    2007 VW GTI, 2007 Lexus IS250
    04-02-2012 02:51 AM #8
    Bon Ami is extremely gentle, fine for glass. Personally, I love this stuff:
    Need VAG-COM work in CNY? PM me!
    OEM+
  9. 04-03-2012 08:13 PM #9
    If you want a designated windshield product that is pretty good at cleaning spots off of windshields, try some Duragloss #755 Nu-Glass.
    I have used Bon Ami on a MKIV windshield before with good success, but not a MKVI windshield.
  10. 04-22-2012 04:44 PM #10
    A clay bar does wonders, followed by RainX.
  11. 04-22-2012 06:56 PM #11
    Quote Originally Posted by glidd View Post
    RainX, Meh. Aquapel++
