Results 1 to 12 of 12
Thread: Multiple cylinder misfire
  1. Member Suter's Avatar
    Aug 28th, 2005
    VA
    24v Fast, 2L low and slow
    03-31-2012 12:50 PM #1
    The problem started yesterday out of nowhere. 03 GTI, pretty much stock. I drove to work yesterday with out any issues, but after work, before I was even out of the parking lot I noticed the idle was rough. Ive had ignition coils go out, and that as my first assumption.
    As I accelerated out of the parking lot, the car was pretty jerky and hesitant, and then I noticed the CEL was blinking. Checked it out when I got home, and I have 3 new codes, PO300 - Random/multiple cylinder misfire. Misfires are on 1 and 4. I switched coils 1 and 2 and erased the codes to see if the coil was bad, started it up, and same thing, misfires on 1 and 4.
    Im pretty new to this engine and its a newer car than Ive ever owned. Most of the info I found was in the 1.8T forums, and usually pointed to software issues or vacuum loss, but all the info was vague or directly related to the 1.8T.
    Could anyone offer me a little direction?
  2. Member orau22's Avatar
    Oct 15th, 2008
    NJ 08085
    SLAWbuilt MKIV & MKII Jetta Diesel
    03-31-2012 10:13 PM #2
    spark plugs?
    SLAW [Straightline Autowerks]
    PM for fender rolling and coilover installs in South Jersey
  3. Member blevs17's Avatar
    Jun 3rd, 2010
    YOCO PA
    24v gas eater, 90 convertible creeper
    03-31-2012 10:58 PM #3
    im having the same problem with mine. i have just a cyl 1 misfire. new plugs and coils, even a new injector. and still have the problem. interested to hear how yours turns out.
    Quote Originally Posted by static.20v View Post
    no respect. dont build a car if you dont intend to drive the **** out of it. its like getting a super hot girlfriend and not ****ing her until shes autistic every night. just sayin'
  4. Member Suter's Avatar
    Aug 28th, 2005
    VA
    04-15-2012 02:32 PM #4
    I just replaced the spark plugs and still no luck. I had tried unplugging the battery before as well thinking it might be an ECU problem or something that might reset.
    I honestly dont have the slightest clue this time around. Im puzzled how it just randomly started upon a startup with no prior issues.
  5. 04-15-2012 02:39 PM #5
    Check compression
  6. 04-17-2012 03:40 PM #6
    Before you replace anything unplug your front oxygen sensors at the firewall. I had my car in the shop and they couldn't figure it out so when I got it back home I tried this and that was the problem.
  7. Member Suter's Avatar
    Aug 28th, 2005
    VA
    04-20-2012 09:35 PM #7
    Well guys sorry for being in and out of here. I had originally swapped the coils and reran the codes and was still getting misfires the same cylinders. I later checked manually by unplugging them and found 2 bad coils. So I replaced them and was good for a few days. Now today I start her up and have 8 faults.
    P0300
    P0301
    P1364
    p1361
    P1355
    P1358
    p1370
    p1367
    doesn't seem to be running as rough, but is still pretty choppy. I'm looking for a little more insight before I get home in the morning
  8. Member Suter's Avatar
    Aug 28th, 2005
    VA
    04-21-2012 04:08 PM #8
    I will try disconnecting my o2 tomorrow and see what that does for me. Havent had a computer available, browsing and posting on a phone is the worst. doing some research on the new codes at home now though.
  9. Junior Member
    Feb 12th, 2012
    Where the Navy sends me...
    '03 Jetta GLI, '93 Corrado SLC
    04-27-2012 04:37 PM #9
    Has to be the amplifier. Ignition coils do go bad, but not two at a time by themselves. I've never heard of this problem before, keep us updated.
    -Holmes
    People are always surprised that my car smells of crayons
  10. Member rajvosa71000's Avatar
    Jun 8th, 2004
    '04 VF Stg.2 24v GTI VR6, '98 GTI 12V VR6, '06 VW Touareg VR6
    04-28-2012 05:37 AM #10
    Sometimes i get missfire codes on my supercharged GTI, and while i replaced new coilpacks and pugs i would still get it sometimes, it happens when Im at wot, cel would blink but go away aftet a few seconds.
    Now, my theory is, my timing its advanced at 1.25 degrees and while on despot 91 oct. It runs lean, or its my lwfw, giving false load reading to the ecu. I asked Jeff from at that time C2 motorsports and he asked me if i had lwfw, and that it would give ecu false load reading or someting like that, cant remember.
    Sent from my HTC Sensation 4G using Tapatalk 2
  11. Member Suter's Avatar
    Aug 28th, 2005
    VA
    04-30-2012 01:51 AM #11
    Quote Originally Posted by Holmes741 View Post
    Amplifier? Sorry, again, Im new to this new of an engine. I just replaced all the spark plugs, and it looks like cylinder 1 has burned up another coil. Swapped it to cyl2 and checked and yep, the coils dead. Now Im no longer getting a constant CEL that flashes on acceleration, but just a flashing CEL on acceleration occasionally. The light goes off though, and Im not able to check the codes for it.
  12. Member Suter's Avatar
    Aug 28th, 2005
    VA
    04-30-2012 01:53 AM #12
    Quote Originally Posted by rajvosa71000 View Post
    lwfw? Although my motor is basically stock so Im not sure if it would pertain to me anyways.
