Results 1 to 2 of 2
Thread: 93 Eurovan 5sp
  1. Junior Member
    Oct 27th, 2008
    Tampa Florida
    11 Jetta TDi 07 GLi,93 Eurovan,93 Westy,93 Cabriolet, 86 gti 16v, 82 TD Caddy, 73 914, 65 double cab
    03-31-2012 03:30 PM #1
    I have a 93 Eurovan MV 5 spd that I have put a ton of new parts on it... I was restoring it, then I found a weekender I could not pass up now I have a 95% restored Eurovan that needs a good home!
    It has all the following new:
    tires
    brakes and lines
    wheel berings
    shocks and springs
    ball joints
    power steering pump
    water pump
    timing belt
    tensioner
    valve cover gasket , main seal
    clutch, throw out bering, clutch plate
    both axels replaced
    motor mounts
    shift bushings
    slave cylinder
    temp sensors
    cap rotor, plugs wires
    idle solenoid
    rear hatch, old one rusted out
    fuel pump and sender
    exhaust
    front and rear heater cores
    The van has power windows and locks, power mirrors cruise control both jump seats, table and rear bed, curtains and a roof rack.
    All the van needs is a good cleaning.. i broke the trim that goes around the back window, but I am trying to find it, and have a friend that may have some.. so I am doing my best to get it!
    Runs perfect just made the trip down from NYS come check it out and drive it home!
    Dog does NOT come with van
    And I cannot figure out how to attach photos on here.. so here is my SAMBA link
    http://www.thesamba.com/vw/classifie...php?id=1285215
    Asking $3995.00
  2. Junior Member
    Oct 27th, 2008
    Tampa Florida
    04-23-2012 06:35 PM #2
    Sale pending!
