Results 1 to 16 of 16
Thread: Installing cams @ 95K, no chain noise, looking for guidance.
  1. Member blinkinbanana's Avatar
    Jul 14th, 2000
    Long Pond PA
    '04 R, '10 Jetta TDI
    04-01-2012 09:21 AM #1
    I bought TT 264/260 cams for my R, I've looked around a little and I found these two threads and still have questions about install.
    cam install with detailed pictures
    R32 what needs to be replaced w/ cam install
    1. I'm at 95k, my clutch is good and my chains aren't making any noise. I don't drive my car super hard and I only put about 5-8k on my car a year. Should I hold off replacing my timing chain until they make noise? Should I just replace the 3 guides while I'm in there replacing the cams?
    2. At the very least I need to replace; cam oil rings, valve cover gasket and o rings, cam stretch bolts, intake gasket...anything else?
    3. How do you suggest removing the cam gear from the cam? In the photos it looks like someone just used an adjustable wrench on the cam lobes, I'm not looking to scratch the stock cams.
    4. I would assume I should use some assembly grease what do you recommend and how much is too little vs too much? Does assembly grease funk up the oil? How soon after install/lube should I change the oil?
    5. What is a good marking tool; paint, grease pen, crayon, that I can use to make my own timing marks that won't effect anything.
    6. How much time should I figure for this job? I've done this job on a 2 liter a few times, but never on a VR.
    Thanks
    BB
    IATSE Local 52
    AASI lvl 3
    USASA lvl 1
  2. Member Lolasaurus_Rex's Avatar
    Jul 15th, 2009
    CenTex
    B5 A4, 08 .:R32
    04-01-2012 07:23 PM #2
    3. Wrapping the lobe in a small towel before would cause no harm.
    4. You can never have even lube
    5. Any of those would work. Even some white out.
    @jayyyw
  3. Member blinkinbanana's Avatar
    Jul 14th, 2000
    Long Pond PA
    04-02-2012 02:58 PM #3
    Thanks. Anyone else?
    IATSE Local 52
    AASI lvl 3
    USASA lvl 1
  4. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    04-02-2012 04:55 PM #4
    Yeah quit being a sissy and go do that ****.
    Helpful?
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  5. Member blinkinbanana's Avatar
    Jul 14th, 2000
    Long Pond PA
    04-02-2012 06:28 PM #5
    Quote Originally Posted by need_a_VR6 View Post
    Helpful?
    Good words of wisdom Paul, now come turn some wrenches and help me install!
    IATSE Local 52
    AASI lvl 3
    USASA lvl 1
  6. Member blinkinbanana's Avatar
    Jul 14th, 2000
    Long Pond PA
    04-07-2012 05:53 AM #6
    So no input as far as timing chain replacement, or at least the guides.
    Or how soon after can install I should change the oil.
    IATSE Local 52
    AASI lvl 3
    USASA lvl 1
  7. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    04-07-2012 11:31 PM #7
    I have taken a few 24vs apart and up to 130k the guides still looked mint. Nothing lile the 12v ones. If you have used synth just check em while you are in there, dont plan to replace.
    -Paul
  8. Member Rmeitz167's Avatar
    Dec 15th, 2007
    NEPA
    tred r33t
    04-08-2012 10:51 AM #8
    At 96k, my guides are showing some wear. Did cams at 70k, did my spacer at 96k for my turbo setup. Ill do the chains probably this coming winter when i build the motor
    WunderWagens June 10,2012 in Gilbert, PA... 2nd year http://www.wunderwagens-show.com
    UnitedMotorsport r32 cam flash... get one
    My Turbo .:R Build Thread
    WunderWagens Vortex Forum
    WunderWagens Facebook
  9. Member blinkinbanana's Avatar
    Jul 14th, 2000
    Long Pond PA
    04-10-2012 06:58 PM #9
    Thanks for the input on the chains and guides. I purchased a bentley manual and found this;
    Curious as no one mentions this hex area.
    IATSE Local 52
    AASI lvl 3
    USASA lvl 1
  10. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    04-10-2012 08:09 PM #10
    My cam wrench is too big to fit so I use giant vice grips.
    -Paul
  11. Member blinkinbanana's Avatar
    Jul 14th, 2000
    Long Pond PA
    04-10-2012 08:12 PM #11
    Sounds much better than using a wrench on a cam lobe.
    Thanks Again Paul.
    IATSE Local 52
    AASI lvl 3
    USASA lvl 1
  12. Member Rmeitz167's Avatar
    Dec 15th, 2007
    NEPA
    tred r33t
    04-10-2012 11:26 PM #12
    Yep bentley says 32mm, my tt cams 100% arent 32mm. *******s
    Also blinkin im not far at all from you, message me if you need help or have questions
  13. Member blinkinbanana's Avatar
    Jul 14th, 2000
    Long Pond PA
    04-11-2012 06:12 AM #13
    Quote Originally Posted by Rmeitz167 View Post
    Awesome. Thanks. I think The only question I have left is about break in period. How long til I can hit higher revs?
    IATSE Local 52
    AASI lvl 3
    USASA lvl 1
  14. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    04-11-2012 11:26 AM #14
    Right away, no break in on cams.
    -Paul
  15. Member blinkinbanana's Avatar
    Jul 14th, 2000
    Long Pond PA
    04-11-2012 12:01 PM #15
    Awesome!
    IATSE Local 52
    AASI lvl 3
    USASA lvl 1
  16. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    04-13-2012 02:40 PM #16
    Even on the schricks, there are 2 different styles with different size hex.
    Don't use vice grips. Sheesh. You can buy a large cheap crescent style adjustable wrench pretty cheap. (especially if the coo is prc)
    - Josh
    -Josh
    444hp/413tq - bone stock, all motor, Volkswagen.
