With a spare fuse just in case, I tested the relay idea. No joyThe relay barely triggered, meaning that it did pull the arm a teeny-tiny bit but not enough to pull it fully away from the contacts. The turn LEDs did illuminate.
Maybe I need something that requires less voltage, like a transistor? I know very, very little about making such a switch except that a transistorized switch would likely work.
I think for now I'll just wire in the DRL LEDs. The signal LEDs can be seen but ya really need to look to see them (let's call them "subtle"), something 99% of the drivers fail to do
I want the DRL LEDs on all the time as well, like VWroutanvanman's, and I'll likely use his method as well for powering them.
-- '02 Passat 1.8t & '13 Touareg Executive
of the turn signal illuminated:
was my motivation. I had no idea surface mount LEDs had gotten that far
Look at my last picture in my album and you'll see the difference a couple millimeters makes in the light throw with the optics at the top of the head light to the LED array.
Now, if you can stick the array to the bottom of the light housing...
