thinking of selling my Ur https://picasaweb.google.com/lh/sred...qwE&feat=email so i might be interested in your allroad.
lmk if it's still available.
Cheers,
deadmoon
*********sold**********
Gruppe,
Up for sale is my wife's previous daily driver. We have owned the car for appx 2.5 years (Purchased Aug/09) and to my knowledge it has had 2 prior owners before us. It was last owned by a Porsche service writers wife; they had purchased the vehicle CPO. We just picked up an 09 Touareg which is why we are selling. It has great service records which I will list below. All books and original window sticker are included.
Previous owner maintenance history:
-Jul/07 @ 49k -- both turbo's & all lines replaced
-Jul/08 @ 60k -- recall on fuel tank & replaced alarm horn
*Not sure of the date or mileage however he had confirmed all 4 airbags (suspension) were replaced.
My maintenance history:
-Nov/09 @ 73k -- oil/filter change at the dealer
-Jun/10 @ 76k -- oil/filter change
-Jul/10 @ 77k -- front brake pads replaced
-Oct/10 @ 79k -- 80k service (also: timing belt, water pump, serp belt, fuel filter, coolant temp sensor, valve cover gaskets, prop shaft seal, camshaft seal) -- this job was completed by the previous owner (side work)
-May/11 @ 85k -- oil filter change (rear brake pads replaced *came with vehicle when purchased)
-Jun/11 @ ??k -- venthose replaced (vacuum hose behind the cyl head)
-Jul/11 @ ??k -- both front axles replaced
-Sep/11 @89k -- battery replaced
-Sep/11 @ 89k -- Crankshaft sensor replaced
-Oct/11 @ 90k -- Pirelli P6 allroad tires mounted balanced & alignment done
-Nov/11 @ 92k -- oil/filter change
-Dec/11 @ 93k -- Fuel pump replaced (also replaced batteries in key fob)
-Mar/11 @ 95k -- Ignition module for cyl's 4-6 replaced
The only issues with the vehicle are a minor oil leak (not sure where it is coming from and I haven't had time to thoroughly look), & the front right airbag sometimes sags overnight (I plan on checking the bag and and o rings to figure out what the culprit is).
Other than that the allroad has been a great car and I'm a little sad to see it go.. honestly if it were a 6spd I would probably keep it over my E39 530i.
Below are some photos:
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Cheers,
deadmoon
did this sell ? sorry - I've been offline for a bit...
Just saw your ad. I'm interested. Have you found the oil leak and fixed it and the leaking air bag?
Rob
