Any of you RS guys get a crunch sound from the rear suspension when it's fully compressed and sport mode is off? I seem to hear a crunch from the rear driver's side wheel, but I haven't had a chance or haven't heard one from the right side yet.
It sounds like a rubber crunch sort of sound, just wondered if that's normal when hitting the bump stops or if it's something I need to get checked. I've never had a TT before with the adjustable suspension so I don't know what's normal and what's not.
EDIT: See below. The noise I was describing is the stock wheel / tire rubbing the carpet/sound insulation in the rear wheel well on the driver's sode. Michalborz has it on both sides.
Other RS guys can you check for rubbing? It seems audi needs to have redesigned isulation so this doesn't happen with the stock 19s.
yeah I figured it was normal, but didn't know for sure. I wonder if anyone else has noticed it?
I don't get a "crunching" sound. I get something that sounds more like a little knock. Or something is loose and is rolling inside a box of some sort. It only happens on quick right turns, though. I'm going to ask the service department to take a look at my suspension, control arms, etc. during my 5k service. I did accidentally hit something really hard at about 50 mph in Belgium with my left front wheel. They've got some pretty terrible roads there...
Wait, though... How is your suspension fully compressed? Are you loading the car up with "little people" or something?
- Jeremy -
Misano TT RS w/ Tech Pkg, Aluminum Pkg, Sport Exhaust, Alcantara, Heated Seats and Black/Red Wheels + Milltek secondary decat pipes
Haha.. well I probably am not describing it properly, but it's a bump/hole on one of my favorite roads that causes the rear driver's side wheel to hit the bump stop I think. When the bump stop is hit is when I hear that rubber crunch/scrunch sound. It's hard to describe. I guess I should have them take a look just in case.
I hear the same kind of sound but it's when I shift and it happens sometimes. I remember my z4 m coupe doing this as well. Like a rubber crunch and sort of pop noise right after you shift and have released the clutch...at slower speeds and easy shiftd
To me it doesn't sound like something is lose. More like a rubber scruntch. Anyway.. I think I will have them check it out when I get an oil change. It doesn't seem to affect the car, just more of an annoyance than anything.
Also doesn't happen in sport so perhaps I should always be in sport mode.
i got my car today and i get a sound that sounds like a squeaky old tricycle when i am goin under 15mph and the road has some bumps. Taking it in to see what is up but if anyoe has this problem let me know
#11
I don't have a TT-RS but a 3.2CQ 6MT with magnetic shocks and get the exact same noise in non-sport mode from the driver side rear. Its not all the time and not in sport mode so I figured it's just possibly bottoming out or the spring pops out a bit. The car does feel just a tad under damped in non-sport mode and I think the shocks cannot control the springs perfectly; in sport no issues so far.
2007 BMW Z4M Coupe, 2008 Audi TT 3.2 Coupe Quattro 6MT
#13
#14
Anyone still hearing this? Seems like only a few of us are noticing this...
#15
Just wanted to add my 5 cents, I just came back from Tail Of the Dragon and I heard the robbing you described on most of the hard turns when suspension was fully compressed.
Looks like the outside edge tire rubs against fender liner. My car is stock, unmodified with stock wheels and tire (Toyo).
I went to the dealer right after my trip, showed them pictures from the trip, and fender liner with marks. The dealer wrote all the information and supposedly waiting for Audi of America to respond.
I believe you should go to the dealer and do the same thing, maybe then they'll do something about it.
#16
Exactly what it sounded like to me!! Did you have it happen on both sides or only one side?
I'll have to check with a flashlight. Also were you in sport or non-sport mode of the suspension?
#17
#18
Let us know the outcome. I will complain once I go in for the oil change I plan on getting at 1k miles.
It seems for the 19" wheels they maybe should have installed different bump stops.
#19
I get a little ping or scrunch noise when the car shifts forward or back, like when you shift or take off. I have not noticed any tire rubbing but that would be a separate issue as this noise happens right away and I have not noticed it at full throttle as other things are going on.
#20
It seems on the back fenders the lining in the wheel well is raised with a big lump right at the point where the tire hits when the suspension fully compresses.
Exactly what michalborz shows. It seems your has been rubbed more. I have no idea why they would design a huge hump there. Makes no sense.
#21
