Results 1 to 35 of 35
Thread: TSI - Still Intake Deposit Issues?
  1. 04-02-2012 11:18 AM #1
    I'm thinking about a 2012 GLI. However, with the horror stories I have read about 2.0T intake valve deposits, I am weary. Frankly, I do not want to mess with deposits, nor having to install a catch can. So, can anyone comment on their experiences with more recent 2.0s?
    Thanks in advance.
  2. Member MasterNele03's Avatar
    May 27th, 2008
    West Palm Beach, FL
    2000 C/W Jetta VRWookie, 2005 Volvo XC90, 2010 CW GTI, 2008 Yamaha R6
    04-02-2012 12:29 PM #2
    Quote Originally Posted by BTLew81 View Post
    Thanks in advance.
    They still have intake deposits and it's the same for the 2012's as it has been since 2006 with the FSI motor. Granted it's not as bad, but you still get a get amount in there enough for you or have someone else do it for you between 40-60k miles depending on how your drive. It happens on both b/c of the direct injection design. There's no way around it, even other makers like toyota and them were having the same problems. The only way around it is to hav both direct and port injection, but that won't happen until the new 1.8L TSI motor comes out. Catch cans are not diffcult to install but they won't stop nor reduce the amount of buil-up on the valves. However they will nearly elimante all oil blow-by from teh PCV system in your intake tract before the intake mainfold (intercooler, turbo outlet pipe, turbo itself, etc...) There is also a theory of the valves seals not being the best at keeping the oil from going on the valve but that has no real proof to it so take it how you will. Other than that it's a really solid engine and you really can't go wrong with it if you really like the car, it's just a maintenance thing like every other car manufacturer will have. Hope this helps
    Drive it like you stole it!!!
    XBL GT: MasterNele 03
    Need a crank/cam locking tool for your 2.5T (Volvo), PM me.
  3. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    04-02-2012 01:33 PM #3
    Currently ALL Direct Injection motors are plagued with valve deposits, Minis have the problem, new Mustangs have the problem, Mercedes has the problem etc....
  4. 04-02-2012 01:36 PM #4
    Thanks. For now, it is just not something I want to deal with. I know that probably sounds stupid. I do enjoy maintaining my cars to a high degree, but worrying about performance robbing deposits is not something I want to deal with.
    It's too bad. I know it is widespread, which is bad. A great technology and almost everyone who drives one will evenutally have these issues. Pretty terrible way to do business, in my book. Get the tech right and then sell it.
    Sometimes my lowly 2.5 isnt all that bad.
  5. Member JHEIII's Avatar
    Dec 14th, 2005
    South Florida
    04-03-2012 12:06 AM #5
    Had mine taken care of at 42K under CPL warranty. No out of pocket and loaner provided no questions asked. Don't let it turn you away.
    2008 Passat TSI 2.0T 6spd. Manual
    1994 Miata M-Edition Caged Track Toy
  6. 04-03-2012 12:21 AM #6
    good to know, but it does turn me away knowing this is basically a scheduled maint. item. Too bad, as it's a fun little motor. Just what I see as a major issue...
  7. Member Slayer's Avatar
    Aug 8th, 2000
    Windham CT
    2008.5 GTI w/TSI motor, 1995 GTI Vr6
    04-03-2012 11:18 AM #7
    exactly what I was going to say.
    No gas on the intake valves = caked on **** until you go scrape it off. That's just how it is
    Check out my Garage build thread - 08.5 GTI 2.0T TSI, APR stage2, APR intercooler, 42DD 3" Catless Downpipe, Autotech 3" Exhaust, Full Carbonio intake, AWE DV relocation, BSH Motormounts, Coolingmist CMGS stage2 Meth injection, Dieselgeek Shortshifter, Southbend Stage2 Endurance clutch, Forge Shift knob, Euro LED tails, Koni Coilovers, Miro STP3 19x8.5 rims, General Exclaim 225/35/19 Tires
  8. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    2009 GLI, 01 "Thundercat"
    04-03-2012 12:18 PM #8
    Thanks in advance.
    think about it like this, 10 years ago when majority of the cars had timing belts, would you buy worried about purchasing a car with a timing belt knowing it would have to get done at 60-70k miles? no, same goes for this, at about 50-60kyour valves may need to be cleaned, can you drive without the cleaning? yes.
    Additionally, never manifolds are less prone to failure.
    Contact me for: FENDER ROLLING!!! also *Coilover & Exhaust install*brakes, maintenance & more*
  9. 04-03-2012 02:16 PM #9
    Well, I blew it. I went and drove one today. LOVED it. Just gotta get the fiance to buy in..
    Aug 30th, 2009
    Santo André SP Brasil
    Passat Wagon 2.0 TSI 09; APR K04 ;carbonio; DP APR;cat 200 cels inox;paddle shifts; VCDS;
    04-03-2012 02:36 PM #10
    It seems that new ones (I don´t know when) will have 2 injection systems.
    One comes through the valves, and the other one, direct injection.....
    Perhaps one for low rpm and other for high rpm.
    Living and learning.....with mistakes.....
  11. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    04-03-2012 03:20 PM #11
    Quote Originally Posted by zucchini View Post
    Sounds like an additional set of injectors to worry about
    Sent from my Galaxy S while planking on a cop car using Tapatalk
    Aug 30th, 2009
    04-03-2012 07:10 PM #12
    Quote Originally Posted by onevrsix View Post
    Indeed!
  13. 04-03-2012 09:59 PM #13
    Yes, valve deposits are a downside of DI, but the upsides do outweigh the issue IMO... and judging from your test drive reaction, you agree! Pulling the IM and cleaning valves once in a very long time isn't the end of the world. Timing belt change is far more difficult and invasive.
  14. Member
    Dec 29th, 2010
    Danvers, MA
    03 VW Golf(sold), 05 Jetta(sold), 09 Audi A3
    04-05-2012 12:36 PM #14
    Here is my TFSI @105K miles. I did the cleaning myself in 6hrs. Pictures speak a thousand words
  15. Member
    Apr 27th, 2011
    San Diego
    2012 CW GTI Autobahn w/DSG
    04-06-2012 04:45 AM #15
    ^ That doesn't look so bad. And by "not bad" I mean having this as a 100k maintenance item isn't bad, not necessarily having to do it in the first place.
    Also, I hear it depends on your driving habits too, no?
  16. Member MK6GTI's Avatar
    Aug 1st, 2009
    Rack City Bitch
    2010 GTI
    04-10-2012 01:27 PM #16
    ^^ daayyyuummm. I bet the car ran so much better after you did that..
    APR | RAI | GHL | KW | BBS
    instagram: @gti_pat
  17. Member
    Dec 29th, 2010
    Danvers, MA
    04-10-2012 02:05 PM #17
    Quote Originally Posted by MK6GTI View Post
    It felt a little... loose after the cleaning. and noisy... it was just my feeling. 200miles later I did oil change and then ran a full tank of gas with seafoam in it. There were some small deposits that clogged my injectors. After I did this everything has been good. I am at 116K now. I will recomend cleaning them every 50K miles.
  18. Member worth_fixing's Avatar
    Dec 23rd, 2009
    St-Jean-sur-Richelieu, Qc
    2009 Volks GTI Tornado Red
    04-17-2012 12:58 PM #18
    Hey guys,
    I just bought a 2009 GTI last Friday with 105,800 km (~65,000 miles) I'm assuming no one has done
    any maitnenance on the engine to this extent. It's also out of warranty (completly) therefor I plan on
    doing all the maintnance myself (well, at least most of it).
    Is there a step-by-step how-to guide on cleaning my intake valves?
    How would I know they are due? (Lack of power I assume)
    Could this potentially cause permanent damage if not cleaned?
    Thanks!
    James
    P.S. F***ing amazing car is f***ing amazing.
    Quote Originally Posted by slide13 View Post
    My ITR can probably smoke that sporty cavalier, called corvette.
    Kind regards,
    James
  19. Member MK6GTI's Avatar
    Aug 1st, 2009
    Rack City Bitch
    2010 GTI
    04-17-2012 01:28 PM #19
    Quote Originally Posted by Evo V View Post
    Hmm. My car is still young at just under 37,000. I think 50K is a little premature. Maybe 100K or 105K like you did.
    instagram: @gti_pat
  20. Member onevrsix's Avatar
    May 27th, 2010
    Philly Area
    04-17-2012 04:36 PM #20
    agreed, I looked at mine around 60k and decided I'd wait till 75-100....now that I'm at 76k car still runs fine, pulls like a raging animal (stage II).
  21. Member
    Dec 29th, 2010
    Danvers, MA
    04-17-2012 05:05 PM #21
    @ 105K my car ran fine as well. I saw pictures of MisterJJ's car at 76K and that got me motivated. I'm so glad that I did it. After what I saw inside I will do it again @150K.
  22. Member Deaks2's Avatar
    Mar 10th, 2001
    Ottawa, Canada
    2011 VW GTI DSG
    04-17-2012 06:15 PM #22
    Toyota DI systems have always had port injection in order to keep the vlaves clean and reduce cold start emissions. The next-gen 2.0 TSI (post on this forum somewhere) will also have a dual injection system.
    Audi covers valve/intake manifold cleaning on the 4.2 TSI in the RS4 and R8, but not on the more pedestrian models... Hmm...
    2011 VW GTI DSG
    GIAC Stage 2, Ultimate Racing DP, Neuspeed P-Flo, DG Springs, RS-3 brake ducts, R20 tails, etc...
  23. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    04-18-2012 05:02 PM #23
    Quote Originally Posted by Deaks2 View Post
    New generation Diret Ijection motors from VW/Audi are 1.8L, not 2.0L
  24. Member
    Mar 26th, 2008
    Fredericksburg, VA
    '12 R; Built GTI TSI 3+
    04-22-2012 11:08 AM #24
    OP..go buy the GTI then use my DIY to clean the valves. Don't let DI stop you from owning a very fun car.
    http://forums.vwvortex.com/showthrea...Valve-Cleaning
    11.53@121.18
  25. Member Deaks2's Avatar
    Mar 10th, 2001
    Ottawa, Canada
    2011 VW GTI DSG
    04-22-2012 07:18 PM #25
    Current TSI engines include a 1.8 TSI.
    There was a post on here that had the next gen 2.0 TSI tech package for VW dealer techs. I recommend you look it up.
    Edit, found it: http://forums.vwvortex.com/showthrea...ight=injection
    2011 VW GTI DSG
  26. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    04-22-2012 07:30 PM #26
    All of the pictures and information are on the 1.8TSI motor, I have yet to hear anything about the 2.0
  27. Junior Member
    Feb 14th, 2011
    NJ
    04-24-2012 10:32 PM #27
    I was quoted $600 bucks to clean my valves from Redline Speed worx
  28. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
    04-24-2012 11:08 PM #28
    thats crazy ****ing expensive... i paid $250... most i know personally paid less than $350...
  29. Member
    Mar 26th, 2008
    Fredericksburg, VA
    04-24-2012 11:14 PM #29
    No doubt. Dealer probably cheaper.
    11.53@121.18
  30. Junior Member
    Feb 14th, 2011
    NJ
    04-25-2012 07:35 AM #30
    From a dealer?
  31. Junior Member
    Feb 14th, 2011
    NJ
    04-25-2012 07:36 AM #31
    Quote Originally Posted by Krieger View Post
    From a dealer?
  32. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    04-25-2012 12:55 PM #32
    from larger shops that know wtf they are doin and arent in it to rape you.
  33. Member
    Dec 29th, 2010
    Danvers, MA
    04-25-2012 03:38 PM #33
    Are they actually open the intake and manually clean the valves for $250 or just spray it with seafoam and call it a day?
  34. Member ViRtUaLheretic's Avatar
    Aug 16th, 2008
    Kansas City
    2009 GTI
    04-25-2012 03:53 PM #34
    If thats the case, I will spray seafoam in your intake manifold for $200 and i will drive to your house
  35. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    04-25-2012 04:03 PM #35
    pull the intake mani and manually scrub the intake valves... seafoam doesnt do **** either.
