Results 1 to 11 of 11
Thread: WTB: Audi A4 B5
  1. Member miggs's Avatar
    May 1st, 2008
    Sheridan, Or
    Lowered skateboard
    04-02-2012 04:39 PM #1
    I am looking to buy an audi a4.
    Requirements:
    1999-2001
    1.8T
    5 speed
    quattro
    prefer black or red
    less than 120k miles
    maintenance up to date
    mods are okay.
    I have $8000 to spend
    Text or message on here.
    503-435-7169
    abf_jetta on Instagram
    Buy it. Build it. Drive it.
  2. Member miggs's Avatar
    May 1st, 2008
    Sheridan, Or
    Lowered skateboard
    04-03-2012 07:46 PM #2
    nobody has one???
  3. Member Spray Junkie's Avatar
    Jul 2nd, 2006
    Gma's 88 Carat, OG '92 16v,
    04-04-2012 02:56 PM #3
    I have one, but its not 1.8t, its white, and it has 190k on it. Doubt your interested but if you are it just got all its maintenance done and then some.
  4. Member miggs's Avatar
    May 1st, 2008
    Sheridan, Or
    Lowered skateboard
    04-04-2012 04:44 PM #4
    pics, price and whats the "then some"?
  5. Member Spray Junkie's Avatar
    Jul 2nd, 2006
    04-04-2012 05:25 PM #5
    pm me your email and I'll send ya pics if you're still interested
    Modifications:
    2001 OEM Headlights, Taillights, and Foglights installed using factory 2001 wiring, heat shrinked and wire loomed.
    2001 Rain tray cover and battery cover. (Never offered on a 1996)
    Clear fender markers.
    Inpro chrome mirror caps.
    S4 Suspension.
    S4 Heated black leather seats.
    S4 Control arm kit with all new hardware from FCP.
    Pioneer CD player.
    Deleted armrest ( Arguably the worst designed armrest/cupholder ever )
    K&N air filter.
    Recent Maintenance:
    Rebuilt front control arms and steering links with 13 piece FCP Groton S4 upgraded kit.
    Alignment
    Replaced Oil pressure switch, upper oil pan gasket, lower oil pan gasket,oil cooler gasket, valve cover gaskets, cam seals, cam plug, cam position sensor, vacuum lines, valve breather hoses.
    All parts removed i.e.valve covers, oil pans etc, were completely decreased and had all deposits removed prior to re assembly.
    Replaced brake fluid reservior and master cylinder, flushed fluid with dot 4
    Replaced rear brake pads and rotors, checked fronts which are at 90%
    Timing belt, tensioner, idler pulley
    Accessory belt
    Water pump and thermostat
    Radiator flush, refilled with fresh G12
    Oil changed with Mobil1 synthetic 5W30
    Re-charged Air filter
    Re-finished stock wheels in factory silver
    POR-15d the raintray, under the battery.
    Needs
    Cracked passenger side mirror glass, does not affect function
    Has an occasional exhaust rattle under de-accel, and at idle
    One broken passenger pull handle ( oh S*** handle) I have the replacement from a 2001 which need minimal modification to fit.
    Door panels were painted to match the seats and are showing wear.
    One tire has camber wear as a result of the control arms needing to be rebuilt.
    A/C recharged due to condenser removal when timing belt was serviced.
    Has an inspection sticker from WSP, although title is clean.
    I have documentation and photographs of the entire repair, which I did myself. (Professional paint and body man here)
    Asking $4,200 obo, or trade for a wagon, truck, or suv.
    This has been the wife-mobile for almost two years, but our family has outgrown it and we need something bigger. Really hate to sell it after putting so much love into it, but we just need something bigger. I'm one of those people that replace EVERY little thing I find wrong on a car. Also comes with a hard bound Bentley service manual in excellent shape.
  6. Member miggs's Avatar
    May 1st, 2008
    Sheridan, Or
    Lowered skateboard
    04-05-2012 05:49 PM #6
  7. Member Spray Junkie's Avatar
    Jul 2nd, 2006
    04-08-2012 11:06 PM #7
  8. Member miggs's Avatar
    May 1st, 2008
    Sheridan, Or
    Lowered skateboard
    04-09-2012 08:55 PM #8
    Bump. I have $8000 to spend.
  9. Member miggs's Avatar
    May 1st, 2008
    Sheridan, Or
    Lowered skateboard
    04-10-2012 02:26 PM #9
    still looking
  10. Member miggs's Avatar
    May 1st, 2008
    Sheridan, Or
    Lowered skateboard
    04-11-2012 12:26 PM #10
    This money is burning a hole in my pocket!
  11. Member miggs's Avatar
    May 1st, 2008
    Sheridan, Or
    Lowered skateboard
    04-12-2012 07:25 PM #11
    found one. please delete.
