Just an idea I played around with. Hows about the area between the cup holders and the shifter?
#1
I've got a MKV Jetta. Any ideas of where to put the rocker? As of now, I've been thinking about putting it on the drivers side door, by the gas tank and trunk release... but I'm up for any ideas.
///KCH2O ”VDUBkill 2:0 – The path of 2.0T is beset on all sides by the injustice of the speedtrap and the Plague of the Prius drivers. But blessed is he who in the name of disparity overwhelmeth the exotic in the valley of the s-bends. And I shall strike down upon thee with great revs and furious acceleration those who attempt to obstruct or delay my overtaking and you will know my engine is turbocharged when I lay my powerband upon thee.”
#2
#4
I would put it somewhere easy to access just in case you have to raise your car really quickly in an emergency. But that's just me.
#5
I put mine on the center console under the e-brake lever. It's right within reach when i need it but it remains out of the way and inconspicuous.
#8
What is that? All up - all down?
#9
red is down. but it was blinking at the time, so I'm not sure what it was.![]()
#10
#11
You do. There's a small black button that allows you to cycle from corner to corner or front at the same time and back at the same time.
Oh, and FYI- I put the rocker switch on the armrest portion of the center console-- I had to cut a hole with the dremel, but man, it's out of the way and I think it looks sharp.
#12
You do. There's a small black button that allows you to cycle from corner to corner or front at the same time and back at the same time.very interesting
