I'd take gross speculation, random ideas or completely uninformed guesses at this point![]()
#1
So I came home from work today and was inspecting my coilovers, just checking for anything that might be causing the noises I've been having... and while I was looking I noticed that the car has started to make this strange 'Wheezeing' noise and I can't for the life of me place where it might be coming from or what might be making the noise.
I've had the Intake Manifold somewhat recently (Beginning of the year) but I never noticed this noise until today.
I've also looked into the whole Water Pump deal but mine doesn't seem to be making that noise??
Any help here would be sincerely appreciated... I looked all over and couldn't seem to find where it was coming from, so as of right now I'm lost. :iono:
http://www.youtube.com/watch?v=7V31k5BDb5s
'09 Tornado Red GTI - APR Stage 2 TSI|BSH Race Intake|Raceland Catless 3" DP|H&R Super Sports |BFI Smoked Sidemarkers|18" Huff's| Thunderbunny Rear Bumper|Thunderbunny Sideskirts|Votex Rep Front Lip|R-Line Fogs |AWE Vent Mounted Boost Gauge|
#2
#3
Not even a guess....that is the water pump failing. Sounds like just about everyone has gone through numerous pumps and VW has not found a fix. Should be warranteed, don't let them tell you differently!
#4
Your gonna have even bigger problems. Every replacement pump has in stock has a faulty bearing. I have had 3 pumps replaced in the past month.
VWOA is currently working with a new manufacturer and should have them out in about 6 weeks.
DubsOfQueens.com | Tyrol Sport | BSH Street Team
#5
#6
#7
So you're sure that's the issue? I've heard other Water Pumps on youtube and it sounded a bit different? I suppose I should just wait for it to break or get worse then?
#8
not antoher sound!!! lol
Did you bring the car over to Fabian to take a Look?
#9
My car sounds just like that, but only when I turn it off after driving. Is that the same thing? Water pump?
#10
#11
My 2010 GTI produces the exact same sound. I thought it was normal. It's been doing it for at least 15K.
2000 Skoda Octavia 1.8T, mods: Revo Stage II, 4 bar FPR, INR tranny and engine mounts, 3" Draft 42 catless turbo back exhuast, vRS front bumper
2010 GTI, mods: Wavetrac LSD, APR Stage II, APR downpipe
#12
#13
And regarding this P/N, now i can confirm that IT IS NOT a new rev. for our engines. 06J121026AN is used in the 2012 CBFA Beetle and the 2009 A3 Sportback. In fact, 06J121026AN has a connector/sensor not present on the BA rev. I'd say some dealers are just experimenting with our cars. Definitely not a VW approved fix.
#14
#16
No camera at all, haha, but I'll try to figure something out.![]()
#17
My 2009 GTI sounds exactly like that video. Maybe it`s the speakers in my laptop but I don`t hear any wheezing in your video at all. Just the ticking of the DI. Sounds ''normal'' to me...at least I hope. I have no warranty on my car. How do you tell if your water pump is failing
#18
#19
My sound occurs right when I shut off the car.. so like one second after I turn the key to off. Sounds exactly the same. Took it in, of course it wouldn't make that sound when the technician was watching![]()
#20
*** UPDATE ***
I always hate it when people never come back and tell you what happened... so, in trying to be a better human being:
The winner was the Water Pump! So any of you that guessed water pump, you were spot on!
The tech and VW put a stethoscope on it and was able to verify that was where the noise was coming from, though all the techs there as well as management had never heard one make that noise before.
So, water pump was replaced under warranty and the sound is gone!
#22
#23
removing the coolant bottle cap usually makes the noise stop if the problem is the water pump.. not a part problem as much as is no lubrication. vacuum filling the cooling system or pre lubing with coolant prevents repeat failure
#24
#25
there are tools on the market that bring the cooling system into a vacuum using a ported vacuum and shop oir. then siphons coolant into the system from your coolant container.
