VWVortex.com - Sidewalks are harsh.
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 33
    Thread: Sidewalks are harsh.
    1. Member KeiCar's Avatar
      Jul 23rd, 2002
      Philthadelphia
      2007 Acura TSX / 2013 Toyota Yaris LE
      04-02-2012 11:59 PM #1
      I just recently came into possession of an older K2 road bike, needed a little TLC but I got her all fixed up. This was my first ever road bike, I had mountain bikes when I was in my teens but once I got my drivers license that was the end of that. Now Im in my 30's and wanting desperately to get back into better shape.
      Well I went and took it out today, checked the tires before hand and put air in them and a new tube on back. The tires say 110lb of PSI (not a range of pressure but a single number), I guess thats normal but for some reason I felt scared to put that much air in and stopped around 90 or so. I don't know the condition of the front tube and the rear I was worried about it pinching and not seating correctly since it was the first time I ever replaced a tube.
      I took the bike out of a few rounds around the block, riding on the street for 3/4 of the way (their backroads, relax) but the main road forced me onto the sidewalk and MAN that is a hard ride. I know my mountain bike when I was younger had not only front suspension but I'm positive the tires had pressure nowhere near that high.
      Should I put them up to the recommended 110 PSI or is 90ish ok? I only weigh about 145 so Im not heavy on the tires at all. They are hard as a rock and don't deflect at all when I'm on it. I know lowering the pressure will make the ride a bit softer at the expense of rolling resistance, but is it worth it?
      You need at least sixteen pigs to finish the job in one sitting, so be wary of any man who keeps a pig farm. They will go through a body that weighs 200 pounds in about eight minutes. That means that a single pig can consume two pounds of uncooked flesh every minute. Hence the expression, "as greedy as a pig.
    2. Member genjy's Avatar
      Aug 7th, 2005
      Glendora, CA
      Volvo C30 6spd / Mazda5 5spd / '16 Subaru STI 6spd
      04-03-2012 01:04 AM #2
      I have two aluminum frame fixed-gear bikes that I ride on the sidewalk 99% of the time--110 PSI in all of the tires. It was pretty rough at first, but nothing I wasn't able to get used to. One of them now even has a hard road saddle.
      I had one of the bikes at 90 PSI for a while, but the rolling resistance just killed most of the enjoyment out of it--and I think less than 90 PSI would be unbearable for me.
      Maybe you can keep the tires at 90 or 110 PSI, but get a softer saddle?
    3. Member KeiCar's Avatar
      Jul 23rd, 2002
      Philthadelphia
      04-03-2012 01:14 AM #3
      I should of mentioned the saddle. Its got a shock-absorbing post and the seat says "women's comfort"... hey I don't care, its soft
    4. Member lojasmo's Avatar
      Dec 23rd, 2002
      SE MN
      2006 Vue, 2012 Chevy Cruze LT2, 2004 Allroad
      04-03-2012 07:16 AM #4
      Why would you ride a bike on a sidewalk?
    5. Member SpeedyD's Avatar
      Jun 9th, 1999
      Lexington, KY
      2010 VW CC Sport
      04-03-2012 08:18 AM #5
      Get off the sidewalks, ladies.
      Sent from my basement using two tin cans and a string.
    6. Member
      Nov 17th, 2009
      Baltimore
      04-03-2012 08:57 AM #6
      you are correct, mountain bike tires do not have as high of pressure. the larger diameter allows pressures around 35-60psi instead of 90-145psi. larger tires always absorb more road bumps
      that said...
      it's illegal to ride your bike on the sidewalk in philly (if that is still where you currently reside)
      http://www.phila.gov/philacode/html/...idewalks_.html
      you can get a $50 ticket, here's why
      http://bikephl.bicyclecoalition.org/...s-illegal.html
      here's more information
      http://www.bicyclecoalition.org/content/faq#sidewalks
    7. Member KeiCar's Avatar
      Jul 23rd, 2002
      Philthadelphia
      04-03-2012 10:05 AM #7
      Quote Originally Posted by SpeedyD View Post
      So you would rather I ride in traffic around a large blind turn. Fantastic idea!
      Actually I live in the suburbs and I've ridden this same stretch of sidewalk since I was a little kid and its ridden all the time by bikers avoiding the dangerous part of the road. It does have 3 house on that stretch and never has anyone said anything that live in those homes.
    8. 04-03-2012 10:36 AM #8
      The road is a much yours on a bike as it is a car's. Only noobs ride on the side walk (besides that it's illegal). Wear a helmet if you're worried and pay attention to what's going on around you
      Jun 30th, 1999
      MoCo, MD
      Jetta TDi, BMW S1000R, Suzuki DRZ400SM, Brodozed Tacoma
      04-03-2012 10:51 AM #9
      Quote Originally Posted by KeiCar View Post
      Most of us in this forum do so every day.
    10. Member
      Feb 8th, 2012
      Los Angeles
      2015 Audi S3, 460hp 2002 GT2871 TT Q coupe (sold), 1969 RS Camaro, '97 GTI VR6 DE (sold)
      04-03-2012 03:15 PM #10
      You can get away with 90psi, most of the time. a hard hit will flat the tube, but not a biggie.
      MORE accidents happen with bikes on sidewalks by cars not expecting something moving that fast down them as they turn in a parking lot, drive way, etc. Also a ped coming out of a store or house is not expecting you.....and at 20mph or so, you easily can kill someone and be to blame for it. get used to going with traffic on the edge of the road and you'll then be able to safely ride anywhere in the world.
    11. Member genjy's Avatar
      Aug 7th, 2005
      Glendora, CA
      04-03-2012 03:47 PM #11
      Sorry--on the sidewalk, I can proactively protect myself by peeking around corners and driveways, ride around pedestrians, and maneuver the bike as needed. I have more control of my safety on the sidewalk.
      On the road, I am at the complete mercy of the cars next to me and behind me. One bad, drunk, or distracted driver and I am dead. There's no way I could outmaneuver a car coming at me at 40mph+.
      There are times when riding on the road is perfectly safe--just not all the time.
      I know this isn't everyone's opinion or even lawful, but I have had way too many very, very close calls riding on the road to think that it's the only way to ride.
      Nov 21st, 2003
      Northern VA
      04-03-2012 04:13 PM #12
      Quote Originally Posted by genjy View Post
    13. Member B3passatBMX's Avatar
      Feb 26th, 2004
      Coloradical
      91 318iS, 03 Forester
      04-03-2012 06:53 PM #13
      Hard to go fast with squishy tires. I ride 120-130psi all the time.
      Well, then, I'm here to "ruin" the vortex for you. I'm sorry you hate fun.
      91 318is M50 Swapped
      03 Forester
    14. Member Some cats and a Rabbit's Avatar
      Nov 5th, 2009
      Dartmouth NS
      2007 VW Rabbit, 2010 Toyota Matrix
      04-03-2012 10:49 PM #14
      I don't think riding on the street is ever "perfectly safe" but that's where you belong on a bike. Take what precautions you can, wear a helmet, be alert and enjoy the ride; nothing in life is perfectly safe.
    15. Member KeiCar's Avatar
      Jul 23rd, 2002
      Philthadelphia
      04-03-2012 11:41 PM #15
      Quote Originally Posted by pschmerg View Post
      No go on, tell us how you really feel.
    16. Member
      Nov 17th, 2009
      Baltimore
      04-04-2012 12:11 AM #16
      in 2009 in the US, there were 33,808 traffic fatalities. of those, 630 were cyclists. you are at the complete mercy of other drivers whether you are in a car or a bike or on foot. if you REALLY want to avoid the bad, drunk, or distracted drivers, i suggest you park your car and begin taking public transit everywhere.
    17. Member lojasmo's Avatar
      Dec 23rd, 2002
      SE MN
      04-04-2012 12:51 AM #17
      Sidewalks are for pedestrians and preschoolers on bicycles. If you are an adult, and ride a bike, you should ride on the road, and follow regular traffic rules.
    18. Member SpeedyD's Avatar
      Jun 9th, 1999
      Lexington, KY
      2010 VW CC Sport
      04-04-2012 07:38 AM #18
      Yeah, I would. I've been riding on the road for 25 years and I'm not dead, and neither are the thousands of other road riders who know what they're doing. You're an idiot.
    19. Member KeiCar's Avatar
      Jul 23rd, 2002
      Philthadelphia
      04-04-2012 08:58 AM #19
      Im an idiot for not wanting to get hit by a car, yea that makes a lot of sense. Glad to know that you know what your doing, I'm sure in your 25 years of riding (I care?) you managed to mind control the other drivers, cause you know, they NEVER pose a threat otherwise
      Your the reason most drivers hate bikes.
    20. Member
      Nov 19th, 2006
      Raleigh, NC
      2009 BMW 328i xDrive Wagon 6MT
      04-04-2012 10:02 AM #20
      The majority of accidents with cyclists occur at intersections, and very few accidents happen during overtaking. A sidewalk creates an intersection at each side street that you cross, so you're effectively increasing your risk of being hit by riding on a sidewalk. Not to mention the fact that you're annoying tons of pedestrians and limiting your speed.
      Ride on the street like you're a car. Stay in the right lane, and if you're in a situation where it is dangerous for a car to pass you, take the lane. Driver's will stop. They might be pissed at you, but its very unlikely that you'll be hit.
      Just to add, the only time I've been hit by a car was on the sidewalk. I've stuck to the roads since.
    21. Member
      Jul 8th, 2003
      Philly.
      04-04-2012 11:48 AM #21
      how are you all giving him pressure recommendations when you dont know what size tires hes running or his weight?
      if you plan on riding on rough terrain (ie sidewalks) larger tires at a lower pressure will help the bike adsorb the vibrations/bumps.
    22. Member El Jarretto's Avatar
      Jan 17th, 2006
      Las Vegas, NV
      70 Beetle, 56 Beetle, '98 4wd yota
      04-04-2012 12:50 PM #22
      I would. Statistically the sidewalk is many times more dangerous, and I've been hit by a car because I was riding on the sidewalk. It's illegal for exactly that reason.
      <Nieros> 4x4 guys = get the job done whatever way possible
      <Nieros> car guys = dick swinging
    23. Member
      Feb 8th, 2012
      Los Angeles
      04-04-2012 01:01 PM #23
      .... he said he's 145 lbs.
    24. 04-04-2012 01:39 PM #24
      No, you're an idiot for not wanting to get hit by a car and then taking action that directly correlates to an increased chance of you getting hit by a car.
      In regard to pressure, and since I'm lacking mulitquote skills, B3passatBMX, unless you're crazy heavy, try running a scoot less pressure. You're in the area where you may well be increasing rolling resistance due to your pressure. I'm 185ish, and I now run 110-115psi in my Open Corsas and feel much faster than I did at 120.
    25. Member
      Jul 8th, 2003
      Philly.
      04-04-2012 01:48 PM #25
      Quote Originally Posted by M this 2! View Post
      missed that skimming. thanks for all the periods though.
      The issue with riding on the sidewalk is that if a car actually checks to see if its clear, they are not expecting a person walking/running to be going as fast as a bike would be on the sidewalk.
