Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 35 of 166
Thread: Fuel Injected ITB's
  1. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    King of Prussia area
    92 GTI, 2000 GTI
    04-03-2012 12:43 PM #1
    I'm currently planning a 16v ABA build, and I want to go with ITB's, but I don't want carbs.
    So far, most of the builds I've found all have carbs, and I've spent a lot of time looking for information on google as well, but I guess I'm bad at searching for these things because I can't find any useful information.
    Do any of you guys know of a detailed build thread, or just somewhere that I can read about this kind of build and what is required to do it?
    Any known issues I should be worried about?
    Bad idea in general?
    I'm still reading stuff about an ITB set up in general, so any information regarding that would be nice too. Thanks!
    Eurofine
    '95 Jetta 2.0: R.I.P. || '92 GTI ABA: Current Project || 2000 GTI 1.8T: Current Daily
    FS: OBD1 ABA + parts
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    04-03-2012 01:27 PM #2
    There are a few different companies that make ITB setups for 16v. Some use Itbs from bikes. You will want to look into standalone engine management to control fuel and spark
  3. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    04-03-2012 02:04 PM #3
    So basically, I have to deal with getting the ITB's to work properly (opening together, closing, so on)
    Then all I have to do is set the management up to fuel / spark correctly?
    Eurofine
  4. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    1992 Corrado ABA and MS3-Pro powered, 84 Honda V65 Sabre
    04-03-2012 03:50 PM #4
    My old boss and I had an SCCA tube frame Scirocco with a 1.8L 8V running GSXR ITBs and a megasquirt2 standalone. It worked quite well and wasn't horrible to set up or tune. But you'll want the ITBs from a 98-02 bike.
    The Professor
    Melbourne, FL
    M & L EFI Performance
  5. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    04-03-2012 03:54 PM #5
    Any reason why I want that year range?
    Eurofine
  6. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    04-03-2012 03:57 PM #6
    Quote Originally Posted by Sycoticmynd29 View Post
    Yeah those are the only ones that are truly individual... the newer ones are paired like a weber DCOE.
    The Professor
    Melbourne, FL
  7. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    Megasquirt 3x Powered 98 Jetta GT 2.0
    04-03-2012 09:24 PM #7
    Also be sure to find a set that has the TPS still on it. Limits the range. I found tons of ITBs but only a few had TPS. Luckily they were off a bike and were only $50
    98 Jetta 2.0 w/ Megasquirt 3/3x fully sequential
    ABA 16vT build thread
  8. Member airplanewrencher's Avatar
    Oct 14th, 2008
    Vancouver Island, BC
    82 Caddy - 88 Jetta coupe
    04-03-2012 09:57 PM #8
    Here is a DIY i did on some local forums regarding GSXR ITBS and a 16v head. Good info on making your manifold and whatnot.
    http://dubberz.com/forum/index.php/topic,61149.0.html
    Cheers
  9. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    04-04-2012 10:20 AM #9
    That's awesome! Thanks!
    What management are you using?
    If I get a set of GSXR TB's, do I want GSXR 750, or 1000?
    Eurofine
  10. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    04-04-2012 11:58 AM #10
    750 and 1000 are the same size and work well for a 1.8-2.0L turning up to ~8000rpms
    The Professor
    Melbourne, FL
  11. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    04-04-2012 12:04 PM #11
    What would you suggest if I was aiming for 9k-10k rpm limit?
    Eurofine
  12. Member airplanewrencher's Avatar
    Oct 14th, 2008
    04-04-2012 12:27 PM #12
    I'm using megasquirt( my build isn't quite done)
    Do you know how much you want to spend? It gets really expensive making a high rpm high comp na monster. Are you planning on solid lifters? Compression ratio? 94 octane or race gas? Extend of head work?
    My setup is this.
    Obd1 aba block bored 1mm over
    Arp head studs,mainstuds and Conrod bolts
    Je 11:1 abf pistons(from integrated engineering)
    Gsxr itb's
    TT 288 cams
    TT hd valve springs
    Rest of valve train stock
    Very minimal port and polish( more of a cleaning up all the factory cast and machining marks)
  13. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    04-05-2012 05:30 AM #13
    A dry sumped motor and hyabusa ITBs
    The Professor
    Melbourne, FL
  14. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    04-05-2012 11:14 AM #14
    Quote Originally Posted by airplanewrencher View Post
    My setup is this.
    Gsxr itb's
    TT 288 cams
    TT hd valve springs
    Cost is not a problem, I plan on buying everything piece by piece then building it all at once.
    Thinking OBDI ABA bottom end with all new seals and gaskets
    ARP bolts / studs on everything
    I think ABF pistons, I still want to look into reasonable compression ratios a little more, I'd like to go as high as I can while not risking blowing up my car.
    Probably new connecting rods, lighter weight, not sure.
    GSXR ITB's
    276*cams
    Solid lifters
    rebuilt valve train, lighter weight, heavy duty parts
    Multi-angle valve job
    port and polish (probably relatively mild)
    With Lugtronic standalone.
    The car is going to be a daily, so I would like to keep it on pump gas (hence my compression ratio worries)
    I really want to do a 2.0 NA build, but I don't want to spend almost as much on it as I would for a turbo kit, and end up with 30 more HP. I'd like to have a drive-able NA car at around 200hp.
    Quote Originally Posted by Prof315 View Post
    Any examples? haha, I just kinda want to see it now.
    Eurofine
  15. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    04-10-2012 03:30 PM #15
    Any suggestions for where I can read about ignition timing?
    Seeing lots of talk about people having problems with the ignition timing and setting advances and retarding things, and I have no idea what the point of any of it is.
    Thanks.
    Eurofine
  16. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    04-10-2012 03:45 PM #16
    http://en.wikipedia.org/wiki/Ignition_timing
    http://www.msextra.com/doc/ms1extra/..._Index.htm#log
    http://www.tuningmadeeasy.com/tuning...nition-part-1/
    Basically, its the tuning aspect if your car that will let you get more power, or completely destroy your engine.
  17. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    04-10-2012 03:52 PM #17
    GSXR ITB's
    276*cams
    Solid lifters
    While a drivable 2.0L 200hp N/A motor can be done, you're not going to do it with a 2.0L VW without a dry sump oiling system ( $1500 and up). The factory oiling system is good to about 8000 rpm. You'll need to turn the motor 9000-9500 or more ( like the 2.0L in a Honda S2000) and to do that you HAVE to dry sump it.
    The Professor
    Melbourne, FL
  18. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    04-10-2012 04:35 PM #18
    So if i go through with the build using the parts listed, about what kind of power do you think I can expect?
    Thanks.
    Eurofine
  19. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    04-10-2012 04:46 PM #19
    Without going into pistons or crank, I bet you could do 165 to 175 whp with that setup.
  20. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    04-11-2012 10:52 AM #20
    Agreed
    The Professor
    Melbourne, FL
  21. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    04-11-2012 06:27 PM #21
    Found some Helpful seeming threads:
    Dyno Results
    Build thread
    Still reading through everything in the build.
    It looks like he used higher compression pistons and bigger valves than I'm planning, but he was able to hit 195whp after his rebuild, and apparently that is without it being tuned for optimum performance...
    What compression ratio would you guys suggest I aim for? I heard 11:1 and up is risky on pump gas.
    Eurofine
  22. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    04-11-2012 07:20 PM #22
    He had bigger pistons, bigger valves, and lighter weight crank. 195 is really, really nice on that setup. With a bigger cam you could start to push some better numbers, along with the bigger valves as well.
    11:1 is fine on pump. My ABA runs at 10.7:1 on 93 with no issues. All it means is you will have to use a tad less timing. But if you are itching for some big numbers, crank that up to 13:1 with 83.5mm pistons and use e85 as your fuel. With 288 cams, good porting, and +.5mm valves, you could crack 200 whp with that puppy. Big bucks though
  23. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    04-11-2012 08:55 PM #23
    Just a note r32 are 11.3:1. You should have no problem with 11:1 on 93
  24. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    04-16-2012 02:58 PM #24
    Next question I have is about idling.
    I feel like this is probably a really stupid question and that I am over-complicating things which is why I am so confused.
    How do you get ITB's to idle?
    Not Idle smoothly, or consistently, just idle at all.
    The engine I know the best is OBD1 ABA, which uses an IAC / ISV so I'm curious if you use something similar with ITB's, or if its something completely different.
    As I said, really stupid question.
    Eurofine
  25. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    04-16-2012 03:35 PM #25
    Actually all of my ITB/twin sidedraft experience has been that idling is easy even with big cams. Much easier than a plenum manifold and single TB.
    That being said, when we did the ITBs on the GTL car we tied the GSXR injector ports together with brass fittings and 3/8 hose and ran them to a digi 1 ISV. but I have put standalone systems on a number of ITB race motors and even without an idle valve they worked fine. Just use the base idle screw on the ITBs
    The Professor
    Melbourne, FL
  26. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    '67 rolls royce, '67 mgb gt, and a '13 mom wagon
    04-16-2012 05:50 PM #26
    its the off idle performance that can be interesting to tune... idle/crank/startup is usually no problem.
    they sound wicked... but id probably still do a budget turbo setup. NA power is always more expensive than you think itll be
  27. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    04-16-2012 06:18 PM #27
    Connecting vaccuum lines from each TB to an ISV is actually something I thought of, so good to know I wasn't over complicating haha
    Quote Originally Posted by ValveCoverGasket View Post
    Going boosted is definitely the better bang for your buck, but I do plan on owning more than one car and I feel like starting with NA will help me build a better base knowledge of these cars, or at least the functioning of an engine.
    So although I did get into NA expecting a cheaper build, as time went on, I kinda stopped caring about the cost haha.
    Eurofine
  28. Member 81type53's Avatar
    Jun 2nd, 2008
    n.y.
    81 roc.79 911sc and a old man Subaru
    05-02-2012 10:07 AM #28
    If you plan on ITB's try TWM's model for the 16v. A friend of mine has them and they are quiTE Impressive. You'll want to run Electromotive Tec-3 I believe to have worry free driving and the hottest spark etc. Super quality yet Expensive stuff. GL
    I run electromotive XDI on a pretty well built 2.1l 16V motor with dual 45 dcoes and after some Initial tunung by the correct people I have been effortlesly driving It for over a year now with no issues and If I am not hammering It too bad the gas mileage Is even bearable.
    Bought it!!!!! That's why it runs you jerkies!!!!
  29. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    05-02-2012 11:06 AM #29
    I just googled TWM ITB's and looked around for a minute (seriously not long at all)
    One thing I noticed was the Google Shopping links with prices over $1g, and I'm just kind of curious as to why they are so expensive?
    What would the improvements be over GSXR ITB's?
    I also know that those prices are for a new set of ITB's where as the prices I have looked at for the bike throttles are Used prices, but if there aren't $900 worth of reasons to buy the new throttles, I probably wont.
    Anything you can show me with some more info on electromotive?
    Eurofine
  30. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    05-02-2012 03:29 PM #30
    Twm you get a finished product. You bolt it on and you drive the car. The linkage is figured out. The fuel rail. The tps sensor. Extrudabody also makes a similar setup.
    I am suprised someone actually recommends a electromotive unit. It seems they have not updated their system for quite some years and there are products that do a much better job that are more affordable.
  31. Member Prof315's Avatar
    Jan 5th, 2009
    Melbourne, FL
    05-02-2012 04:16 PM #31
    Quote Originally Posted by 81type53 View Post
    While Electromotive makes a decent SEM, the tuning software is less than stellar and with all Electromotive systems (Full out SEM or standalone ignition) YOU MUST run a 60-2 trigger wheel. No options. Also it ain't cheap. Megasquirt or Lugtronic are the best bang for the buck.
    The Professor
    Melbourne, FL
  32. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    05-08-2012 03:41 PM #32
    Quote Originally Posted by bonesaw View Post
    Ah, seems like a lot of money to avoid a little bit of work.
    Also, I see you have a link to Lugnuts tuning in your signature, is that you? or are you just promoting someone who does good work?
    Only reason I ask is because I know Lugtronic is in Harrisburg (well not know but I've been told) and your profile says rockaway, nj which looks a little closer.
    Basically I'm looking for someone who will be able to tune the car (leaning towards a lugtronic set up) that I can get to easily instead of having a map made for me then giving it a shot.
    Eurofine
  33. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    05-08-2012 04:17 PM #33
    Lugtronic is located in Harrisburg area but he does do remote tuning support and does travel for street/dyno/track tuning. He works closely with my buddies shop Caste Systems Performance in Norwood, NJ
  34. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    05-23-2012 03:16 PM #34
    Getting closer to actually starting this build!
    Probably going to start with getting an ABA bottom end and stripping it down, having it cleaned, then rebuilding it / having it rebuilt.
    Then the same for the 16v head.
    Then finishing building the motor out of the car to run a normal 16v ABA swap on stock management.
    Then getting the ITB's and while I get that all set up, save the money for the Lugtronic.
    Goal is to have it done by next show season.
    Eurofine
  35. 05-27-2012 03:47 PM #35
    These blocks have oiling issues at really high rpm, we've blown up a few of them so I know what of I speak. If you plan to turn them much over 8000 rpm get oversized bearings that increase the main and rod clearance by 0.001". This is one of our 8v grenades, it happened when coming off throttle at about 8700 rpm.
