Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 106 to 140 of 166
Thread: Fuel Injected ITB's
  1. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    King of Prussia area
    92 GTI, 2000 GTI
    08-27-2012 10:46 AM #106
    http://www.jenvey.co.uk/home/turbo-plenum
    They make plenums for boost as well as normal ones.
    Eurofine
    '95 Jetta 2.0: R.I.P. || '92 GTI ABA: Current Project || 2000 GTI 1.8T: Current Daily
    FS: OBD1 ABA + parts
  2. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    08-28-2012 01:53 PM #107
    83.5mm pistons.
    Yay or Nay?
    If I have done the math right, it should bring my overall displacement from 1984cc to 2032cc as well as bring my bore / stroke ratio to ~0.90:1 from 0.89:1 stock.
    And from what I can tell, the closer to square / Oversquare, the better? (allows for easier revving to high RPMs)
    Although I guess since I'm not changing the stroke, it really wouldn't matter in that aspect.
    Eurofine
  3. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    09-10-2012 09:56 AM #108
    So after my last post, I started reading about compression ratios, and how to raise or lower them.
    Realized I literally had no idea what I was dealing with,, and that my last post is kinda dumb.
    So I am trying to do as much research as I can before I actually get my parts, but I realized I can't really do many theory measurements, as when I get the head I am going to have bigger valves put in as well as a multi-angle valve job, and I feel like this is going to alter the CC's of the combustion chamber. Will any changes to the volume be significant enough that I should wait to get the head work done and measure, or would I be safe to do some rough guesses using values for the combustion chamber I have found?
    Quote, originally posted by CrackerX »
    I measured the cylinder head combustion chambers of a 1.8L and 2.0L head with a Bosh triple copper plug installed. The 1.8L head was 41.6cc's on average, and the 2.0L head was 43.4cc's on average with a +-.2 cc error margin. Very different from the 45cc "accepted" value. Neither head had been shaved as far as I could tell...
    Eurofine
  4. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    09-19-2012 01:53 PM #109
    Going to pick up the engine and various other parts for this this weekend.
    Then its time to start stockpiling parts!
    Eurofine
  5. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    09-24-2012 09:58 AM #110
    Over the weekend I drove out to Ohio and came back with enough parts to have a 16v ABA on ITB's assembled by the end of next month. BUT, that would be all stock internals, and no more head work than just a PnP.
    Unfortunately, now that I have most of the parts I need to get started, I have to deal with a more serious problem with my car. Floors need to be replaced ASAP. UGH
    Eurofine
  6. Member Rdoppie's Avatar
    Dec 9th, 2004
    Grenada, W.I
    1972 Vw Karmannghia, 1989 Vw Gti , 2001 Vw Polo Gt
    09-26-2012 04:54 PM #111
    good luck
    always been a dream project for me to Build a spare 16v 2.1L on ITBs
    never had the to actually start it
  7. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    10-01-2012 08:00 PM #112
    Alrighty, So its time to buy my valve train. But the question is have now is, should I have the head flow benched before I decide on valve sizes?
    Eurofine
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    10-01-2012 08:26 PM #113
    Depends how much money you want to spend.
  9. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    Megasquirt 3x Powered 98 Jetta GT 2.0
    10-01-2012 09:14 PM #114
    ITBs LOVE big valves. Go over sized either way. Don't bother flowbench before porting IMO.
    98 Jetta 2.0 w/ Megasquirt 3/3x fully sequential
    ABA 16vT build thread
  10. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    10-02-2012 10:30 AM #115
    Quote Originally Posted by bonesaw View Post
    Would it be worth the money though?
    Quote Originally Posted by SirSpectre View Post
    The head has already been PnP'ed, I just don't want to go too big on the valves and end up with terrible velocity.
    32.5mm Intake / 28mm Exhaust
    34mm Intake 28.5 Exhaust
    Or should I piece together a valve train instead of buying a kit?
    Eurofine
  11. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    10-03-2012 04:59 PM #116
    So far the build threads I have read on here, including the ones linked earlier, and some I found, they have used +.5mm valves, so that's what I'm going to use.
    Downside, I found a pretty good deal on a completely unrelated part, so I might have to pick that up before I can buy my valve train.
    Yay for parts ADD
    Eurofine
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    10-03-2012 07:44 PM #117
    Anything good?
  13. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    10-04-2012 09:00 AM #118
    Anything good?
    020 trans with a quaife LSD and the same Trans code I had in my jetta and loved.
    Eurofine
  14. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    10-04-2012 10:19 AM #119
    I hope 3.94.
  15. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    10-04-2012 10:58 AM #120
    Code 1st. 2nd. 3rd. 4th. 5th. R&P Notes
    CHE 3.45 1.94 1.28 0.97 0.80 3.67 From '93 115hp,Large input shaft
    "Borrowed" from Broke's site.
    Eurofine
  16. 10-04-2012 07:47 PM #121
    Quote Originally Posted by Sycoticmynd29 View Post
    Yay for parts ADD
    You can often find deals on super tech valves on eBay. I went with the +.5 undercut, and if your spending the money go with the tapered guides as well.
  17. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    10-05-2012 09:24 AM #122
    Quote Originally Posted by vwjunkie42 View Post
    Because the head has already been PnP'd, I think I'm going to have it flow benched to get some base line numbers before I buy anything.
    Before I bought the head I was told it was "very port and polished" so now I'm terrified that I'm going to spend a bunch of money on valves, and end up with a head that flows like garbage for what I'm trying to do.
    Eurofine
  18. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    10-05-2012 01:35 PM #123
    Don't worry about velocity for ITBs. They will give very high velocities either way.
  19. Member frechem's Avatar
    Oct 19th, 2002
    Roxboro, NC
    '91 ITB GTI, '96 VR GTI, '96 .:R32 Harlequin #22, '07 X-Runner
    10-05-2012 04:00 PM #124
    I would recommend using SCCH for your headwork. Jarod can also flow bench your head before and after to show you the difference.
    My Build ThreadDobbin's shoot #1Dobbin's shoot #2Parting out salvaged BMP 2004 R32
    >>>DO NOT deal with veedubtek!<<<
    Quote Originally Posted by veedubtek View Post
    I've been known to be an a**hole at times, no doubt about that.
    Understatement of the century!
  20. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    '67 rolls royce, '67 mgb gt, and a '13 tdi
    10-05-2012 04:07 PM #125
    Quote Originally Posted by frechem View Post
    didnt he move somewhat recently? i thought i tried looking him up a while back and he wasnt on the west coast anymore...
  21. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    10-05-2012 04:16 PM #126
    This involves shipping the head out, then shipping the parts to him if he is assembling the head (which I plan on having done by the shop)
    Budz Motorsports
    This is the machine shop I had planned on using as it is 10 minutes from my house.
    Quote Originally Posted by ValveCoverGasket View Post
    Yes he did move (just checked the site) and he moved to the East Coast which would make shipping a little easier and faster, but not close enough that I would no longer have to ship the parts to him.
    Eurofine
  22. Member frechem's Avatar
    Oct 19th, 2002
    Roxboro, NC
    10-05-2012 08:49 PM #127
    Budz Motorsports
    I'm telling you it's worth it. My first P&P was done by a local shop in WA and it actually flowed worse than a stock head in certain valve lift ranges. The head had a second go-round by Jarod at SCCH and he made a HUGE improvement.
    Here are some flow graphs for my head,
  23. Member SirSpectre's Avatar
    Mar 20th, 2011
    Milwaukee, WI
    10-05-2012 09:24 PM #128
    Sweet baby J I think When I get my head PnP'd, definitely going that route.
  24. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    10-07-2012 12:37 PM #129
    Damn you Frechem.
    Why am I mad at you? Because when I started planning this I made the decision that what ever I'm doing, I'm going to do the best way I can, and now you're screwing things up by hating on the machine chop I was thinking of using and pointing out the throttles I was looking at aren't very good.
    Eurofine
  25. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    10-07-2012 02:05 PM #130
    He is just trying to help from his experience. Maybe the machine shop will be fine but many have found machinists that specialize in VWs many times do it better.
    I would also steer away from bike ITBs. they make throttle response very touchy and the throw is extremely short.
  26. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    10-07-2012 02:37 PM #131
    That can be remedied by modifying the throttle cam that the cable attaches to.
    FS:Sunroof Deflector
  27. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    10-07-2012 04:03 PM #132
    That's what I was going to say but the terminology escaped me
  28. 10-07-2012 11:59 PM #133
    I would not do bike itbs. I ran gxxr itbs on my car for almost two years and yes the made good power. And can be done on the cheap. But now that I have my badger 5 set up it is like night and day. The drivability and easy tuning made me wish that I had just spent the extra 500 or so more, years ago. Do your self a favor do it the right way the first time or in a few years if you still want itbs you will end up buying new ones. I did and can't be happier.
  29. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    10-08-2012 09:00 AM #134
    At this point I might run the bike ITB's as a temporary set up just to get it running on ITB's, as I already own a set of bike throttles (included in the parts pick up I did a few weeks ago)
    End game I will be going with either the TWM's or the Jenvey ITB's (aren't Badger5 throttles the same as the Jenvey throttles?)
    I was originally going to go with the Jenvey's, but Frechem pointed out a handful of flaws in them, so now I'm going to look into the TWM's a bit more, even though they cost more than I paid for the car itself
    Eurofine
  30. Member frechem's Avatar
    Oct 19th, 2002
    Roxboro, NC
    10-08-2012 09:39 AM #135
    There's no n in my name.
  31. 10-08-2012 09:44 AM #136
    Yes badger 5 and jenvey are the same itbs. Bill at badger 5 gets them grime jenvey and installs his linkage so you can use the stock Vw cable. As for flaws the only thing I did not like about them was the fuel rail but with some custom brackets I was able to run a Vw 1.8t rail.
  32. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    10-08-2012 12:05 PM #137
    Sorry about that, I'll go back and fix it haha
    Here is the post from Frechem when I asked why he preferred the TWM's over the Jenvey's;
    Sure. Here are a few pros and cons off the top of my head.
    Jenvey Pro
    Less expensive? you get what you pay for
    Jenvey Con
    No FPR
    Only one size (45mm)
    Not very good way to mount throttle cable
    Not very good throttle return
    Two piece design that needs to be sync'd
    Air horns aren't fully radiused
    Multi-piece fuel rail has o-rings that leak easily
    Can't mount flat backing for filter
    Made out of country
    Need to drill and tap for vacuum
    Should run vacuum from all four runners into a vacuum canister
    Not very plug and play
    TWM Pro
    Integrated adjustable FPR
    Multiple sizes (45, 48, and 50mm)
    Good way to mount throttle cable
    Good throttle return
    One piece design
    Air horns are fully radiused
    One piece fuel rail
    Can mount flat backing for filter
    Made in USA
    Has vacuum port through all four runners
    No need for vacuum canister
    As plug and play as you can get
    TWM Con
    More expensive? See Jenvey Pro
    Should mount a fuel pressure gauge on fuel rail
    Before I had even asked him, I had noticed that you need to tap the Jenvey's for vacuum off the bat, and I was kind of unhappy about the idea of taking my brand new $1g part and drilling holes in it when I just spent $800 more than I would have on bike throttles just so they would be a direct bolt on.
    Eurofine
  33. 10-08-2012 09:31 PM #138
    All good points. Taping wasn't that bad. I'm running a 1.8t rail with stock Vw fpr. jenvey sells a dished filter plate. maching them wasn't so bad and the badger linkage works real nice. I see where he is coming from but with a little DIY knowage i found it nice not to spend the extra $. Plus when I went to order the twm ones the where back ordered till the end of the year.
  34. Member Sycoticmynd29's Avatar
    Jan 16th, 2011
    92 GTI, 2000 GTI
    10-12-2012 12:53 PM #139
    Part of the reason I decided to step away from bike throttles was for a direct bolt on application, I'm not a fan of the idea of paying 10x as much for a set of throttles, and still have to do do 75% of the modification the bike throttles would have required.
    then again, the throttles and stand alone are going to be some of the last things I get for this, so I still have plenty of time to really make up my mind.
    Hopefully picking up this transmission this weekend, then all extra money I get will be getting set aside for the valve train and head work.
    I'm going to start talking to Jarod at SCCH about some work and some prices, turn around times, and all sorts of other fun stuff.
    Frechem, what was your power at the wheels last time you dyno'd it? Last graph I saw was from 2010 and had you at ~165
    I saw that you went with the stg4 head from SCCH, which is what I'm going to be doing, but I also saw that you have your rev limit at ~7500.
    I'm beginning to get kinda worried that my power goals are unrealistic.
    Eurofine
  35. Member frechem's Avatar
    Oct 19th, 2002
    Roxboro, NC
    10-12-2012 01:40 PM #140
    That graph is from the last time I dyno'd my car. I haven't done anything to the motor since then except for some tuning.
    I have my rev limit set at 7500 because I don't need to go any higher. From my other dyno runs I can tell I start losing power around that point so that's where I set it. I'm sure the head could take it but my bottom end isn't built for high RPMs.
    If you're looking for 200 whp then be willing to spend a MAJOR amount of money. A 9000 RPM motor will help you get to 200 whp but that will be a very high sprung race motor.
    I would not recommend chasing numbers. That can be a huge waste of time and money.
