Results 1 to 24 of 24
Thread: straight line race: ahu jetta tdi vs alh jetta tdi?
  1. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    1999.5 Jetta TDI 5spd, MODDED
    04-03-2012 03:42 PM #1
    Odd question, I know, but I'm very curious to know what a good 500lbs less that the 98 ahu jetta is carrying around can do when compared to the same motor with the same power in a car 500lbs, give or take, heavier. Any experience or input?
    I know that every hundred lbs is equivalent to 10hp, or .10 of a second in a drag race. Using that basis, it seems that stock vs stock the older mkIII jetta should eat up the heavier mkiv jetta.
    Opinions and input?
    Mar 31st, 2008
    PNW - Oregon
    04-03-2012 04:04 PM #2
    the ALH should go better because of the VNT.. the powerband is much nicer with the VNT.
    Mar 31st, 2008
    PNW - Oregon
    04-03-2012 04:07 PM #3
    better yet... who cares?
    this is another POINTLESS question..
  4. Member
    Mar 31st, 2008
    PNW - Oregon
    04-03-2012 04:07 PM #4
    how long is a piece of string?
    Mar 31st, 2008
    PNW - Oregon
    04-03-2012 04:09 PM #5
    brings back memories of THIS THREAD
  6. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    04-03-2012 05:11 PM #6
    Quote Originally Posted by Glegor View Post
    While the vnt is quite great, I dont think that a simple mechanism in a car 500lbs+ heavier is going to equalize the playing field...
    Aug 2nd, 2010
    Athens, Ohio
    99 Jetta TDI, 00 Golf 2.0, 81 Rabbit pickup vr6, 02 TDI jetta
    04-13-2012 10:57 AM #7
    Quote Originally Posted by 85_305 View Post
    obviously this guy has never driven a car with an upgraded turbo, aka 'simple mechanism'
    yankin your chain man
    Athens Euroworks, http://www.athenseuroworks.com/
    Owner, mechanic, diagnostician, parts specialist, receptionist, custodian, you get the point
  8. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    04-13-2012 12:00 PM #8
    So what do you think? The ahu vs the alh an equal straight-line battle? Or does the 500lbs lighter mkiii win?
    Aug 2nd, 2010
    Athens, Ohio
    04-13-2012 01:21 PM #9
    ahu wins low down, alh wins above 80mph when the k03 is choking down and the vnt is flowing buttloads of air.
  10. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    04-13-2012 01:56 PM #10
    Ah that makes sense... The kkk is TINY!
  11. Member
    Mar 31st, 2008
    PNW - Oregon
    04-13-2012 02:03 PM #11
    anything over 3500, maybe 4000 rpms is just making the turbo a restriction..
    i would rip the AHU out of the mk3, find a REALLY CLEAN mk2 GTI, or Jetta Coupe, and put a mechanical pump (or a full electronic swap if its a CE2 car) on the engine, a big turbo, and call it good..
    then it will be FAST, and handle BETTER THAN the mk3 or bloated mk4..
    plus, you can do nose wheelies with good brakes on a mk2..
  12. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    04-13-2012 02:19 PM #12
    What exactly is so bad, particularly, about the kkk? The dinky compressor?
  13. Junior Member
    Dec 3rd, 2011
    Chase, BC
    86' Jetta TD
    04-13-2012 02:55 PM #13
    Nose wheelies!? Are you serious
  14. Member
    Aug 2nd, 2010
    Athens, Ohio
    04-13-2012 03:39 PM #14
    Did this with a friend of mine to his 90 jetta coupe. 2.5" exhaust, fmic, nozzles, still on stock tune with timing and iq fine tuned. Running 15psi. Full electronic dbw. Made 62mpg highway and around 15sec 1/4 mile.
    Great car, and reliable too, with almost all oem parts! Still uses mk2 cluster and full votex/recarro trophy interior. Nice ride to say the least.
  15. Member
    Aug 2nd, 2010
    Athens, Ohio
    04-13-2012 03:41 PM #15
    It is small to reduce lag, and in turn, becomes a restriction at high flow situations aka high rpm.
    Ahu with k24 on it is where it's at. May not be the fastest possible, but a monster all the same.
  16. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    04-13-2012 04:29 PM #16
    Quote Originally Posted by fastinradford View Post
    Whoa!!! Thats sweet!!!!! I'd be down for something like that hehe
    So basically since the compressor is so tiny, it just runs out of wind up top? EGT's aren't bad on ahu's with kkk's?
  17. Member
    Aug 2nd, 2010
    Athens, Ohio
    04-13-2012 11:40 PM #17
    k03 makes boost rapidly, so it keeps egts pretty low actually, but it is a restriction.
    What I find, is that egt goes up with a laggy turbo, k24 runs higher egt than k14 for exaple, with both maxed out.
    the ahu/k03 in the coupe would be around 475f (egt) on the highway at 60, but was running max boost or damn near
    max egt with stock tune was closer to 900f, but tdis run a lot cooler.
  18. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    04-14-2012 12:01 PM #18
    Interesting. So an ahu/kkk can handle higher amounts of boost than stock?
  19. Member
    Mar 31st, 2008
    PNW - Oregon
    04-14-2012 12:04 PM #19
    uh, where did you get it in your head that the TINY K03 will make more boost than factory set?
    it MIGHT, but its not gonna last for crap..
    that VNT is where its at, turbo wise.
  20. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    04-14-2012 01:05 PM #20
    I'm gonna make it work. I've got a plan for this little turbo. Just wait
  21. Member
    Mar 31st, 2008
    PNW - Oregon
    04-14-2012 01:31 PM #21
    if you ask too much of the K03, its gonna break the turbine shaft, and cause your engine to run away..
    i would not even attempt to tune for much more power until you get a BETTER turbo..
    please keep the VNT on the ALH tho.. the VNT will be GAY on the AHU with no way to control it..
    if your gonna do something like that, buy a K24 or T3 turbo off a 1.6TD, and strap that on..
  22. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    04-14-2012 01:35 PM #22
    Accordsing to jeff at RC these turbos can handle stage III tuning, 18-19psi, just fine. But no I won't be putting a vnt onto the car. Too much bs and work. I'm not going crazy with this car, just a few healthy mods.
  23. Member
    Mar 31st, 2008
    PNW - Oregon
    04-14-2012 02:59 PM #23
    dude, ill say it again.. and put it in CAPS..
    THAT K03 IS JUST A BAD RESTRICTION ABOVE 3500 RPMs OR SO. restrictions are not good for power..
    that turbo is just too small for performance.. sure, its an insta-spooler, but it runs out of breath WAY BEFORE the engine does..
    if you run that K03 @ 18psi, it wont last long at all! promise..
    find yourself a K24/T3 and manifold, swap it on, and be done.. then it will RAIL, and you wont have to worry about your turbo exploding..
  24. Banned 85_305's Avatar
    May 31st, 2008
    Buffalo, NY
    04-14-2012 03:48 PM #24
    Where do I find that setup? Is it a bolt-on turbo?
