Results 1 to 15 of 15
Thread: Who has the technical name for this????
  1. 04-03-2012 10:48 PM #1
    So I was looking online to find a distributor block off for my ABA build and came across this Not willing to pay that much. I also heard that the 3A bubble blocks had them stock. No luck in my search for an OEM one. So this evening I was screwing around with some broken 1.8l distributors and came up with this. Know I would like to know what the technical name was or is for this and dont say dizzy gizzy cause that is not it. All help would be great also if u have the Audi 3A unit I need it. The reason for the distributor block off is because I am running 034 Standalone and dont need it or dont want it. Thank you for your help.
  2. Member websaabn's Avatar
    May 23rd, 2003
    Hopkins, sc
    04-04-2012 02:16 AM #2
    oil pump drive, thats what its for.
    The road to riches is paved with Jolly Ranchers!
  3. 04-04-2012 06:58 AM #3
    I know what its for i need the technical name like thw title states. Dealer name.
  4. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    04-04-2012 08:57 AM #4
    That is the BBM Dizzy Gizzy w/ drive gear installed. AKA Oil pump drive for a 16V motor.
    FS:Sunroof Deflector
    Mar 31st, 2008
    PNW - Oregon
    04-04-2012 12:04 PM #5
    Quote Originally Posted by ps2375 View Post
    16v oil pump drive uses a splined shaft, and a splined gear..
    the one pictured uses a stock 8v oil pump drive tang..
    its 8v specific, thats for sure..
    but im sure you already know that..
  6. Member Brian.G's Avatar
    May 7th, 2010
    West of Ireland
    02 25i Msport
    04-04-2012 12:49 PM #6
    The 2.0l gear is also a different size. I did a large writeup on this, Ill find it later
  7. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    04-04-2012 01:01 PM #7
    Quote Originally Posted by Glegor View Post
    yup, this is used in an block with an 8V oil pump, like when making an ABF clone with an ABA, and not having to change the oil pump and IM shaft.
  8. 04-04-2012 08:19 PM #8
    I am trying to find the name the Audi Dealer called this. It Originaly came out of a 3A Audi 80/90 2.0L. There was no distributor just this plug which drove the oil pump. So if u know the name post it! I know what it does and that the BBM one is called a Dizzy Gizzy, I also know what engine it comes from and I can swap out the internals. So again if you are familiar with this post if you know what I know look read but dont post anything. Not trying to be a jerk just get results.
  9. Member Racer16's Avatar
    Aug 21st, 2002
    NNJ
    2000 audi s4,2001 a4,1999 a4,2002 gti,86 gti,85 scirocco,91 corrado,91 jetta gli,2000 passat
    04-04-2012 08:33 PM #9
    well it looks like a block off for the distributor thats driven of the intermediate shaft.I dont know the name but I do know that if your looking to block it off.1.8T aeb engines came with a factory block off plate.that should do the job.the 1.8 block and 2.0 are the same block.I hope this helps.
    I would call it a distributor block off plate.I believe I have one at work from a AEB engine.I will try and see if theres a part number on it and ill post it up tomorrow.
    Own A Audi or VW in the Tri-State Area??Need Repairs???Contact Us.We do free estimates and always use OEM parts and Will Beat any shops prices.We have Over 38 years experience in Servicing and Repairing All European Brands!
  10. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    04-04-2012 09:05 PM #10
    For the PL/9A, it is called a sealing cap, pn 068103113B.
    For the AEB, same name, pn 058103703.
    I could not find anything like them for the 3A.
  11. 04-04-2012 10:08 PM #11
    Thank you!
    You found what I have been looking for.
    I will save the web page also as this will be helpful in the future
    Cheers!!!
  12. Member Mathdiesel's Avatar
    Sep 13th, 2005
    QC, Canada
    92 Jetta VR, 04 A4
    04-05-2012 09:21 PM #12
    To clear things up, the 3A had a distributor, not a block-off.
    The 3A distributor is sought after for the ABA block/ Counter-flow head hybrid. It fits in the ABA block and is functionally the same as the 1.8L
    Good work ain't cheap, Cheap work ain't good - Sailor Jerry
  13. Member Racer16's Avatar
    Aug 21st, 2002
    NNJ
    04-07-2012 11:46 AM #13
    Damn someone beat me to it.Oh well I will post pictures later on when I'm home of the part if you want???
  14. Member
    Mar 31st, 2008
    PNW - Oregon
    04-08-2012 06:19 PM #14
    Quote Originally Posted by Brian.G View Post
    they never made anything to drive an 8v oil pump, rather than the dizzy or a vacuum pump..
    the only ones that were driven by a gear, had a splined shaft, like the 16v engines, the OLD 1.5D w/ manual brakes (no vac pump to drive oil pump) and maybe a few other engines..
    never the less tho, that dizzy delete from bahn brenner, VW/Audi never made anything like that factory..
    they made a splined oil pump shaft, and the oil pump shaft held the splined gear, and then there was a sealing cap/gear retainer that held all of that in place..
    and yes, 3A has an 8v large base, 4 window dizzy in the block, not a sealing cap, splined gear, and splined oil pump shaft.
    the DIZZY GIZZY from bahn brenner is their own design, not a copied VW design, because VW never used an 8v oil pump without a dizzy/vac pump to drive it..
    they have been using the splined shaft/gear since the early/mid 70s, so idk why they would have changed it..
  15. Member GTijoejoe's Avatar
    Oct 5th, 2001
    OH
    '98 GTi, '06 Evo Mr
    04-17-2012 09:16 PM #15
    He speaks the truth.. I had to make my own when I got rid of my distributor... instantly knew I needed it when I had zero oil pressure.
    2.0T+034efi+meth = 300+whp = Part out PM me for anything
