Page 1 of 58 1 2 3 4 5 11 51 ... LastLast
Results 1 to 35 of 1996
Thread: MK4Forum Offsets & Tire Sizes Request Thread
  1. Moderator Mr. Rictus's Avatar
    Sep 24th, 2004
    Buchanan, NY
    2003 Silverstone Grey 2.9L 24v twin turbo VR6, 2002 S6 Avant
    04-05-2012 04:59 PM #1
    With the recent increase in threads regarding what size adapters/spacers and tire sizes to run. I thought one master thread would help cut down on so many threads regarding some of the similar questions.
    This isn't another thread asking you to post your car and your specs. It's more of a thread to have information regarding the same type of subject in one place. Since so many people aren't sure what is needed to help them get the stance they need please answer the questions below so that we can help you.
    Wheel Size:
    Width (F & R):
    Offset (F & R):
    It may also be beneficial to supply your cars height, but I know not everyone had their numbers and would need to measure. Once you have supplied those 3 pieces of information we will be able to tell you what size adapters/spacers & tires will work best (in our own personal opinion). And should you be looking to change lips/barrels, most people on the forum know how to calculate the math to figure out what the new offset would be. For those who don't know, I would suggest looking through Calvins thread here: http://forums.vwvortex.com/zerothread?id=4256707
    If you need adapter sizes, please post the bolt pattern and center bore of the wheel you are looking to adapt.
    For most stock mk4s people run 5,8, or 10mm front and 15,17.5,20mm for the rear. Lets not clog this thread up with questions asking about stock mk4 wheels since that info has been covered a ton of times already and can easly be found in the archives.
    Another helpful thread regarding offsets is Dragon813gt's thread: http://forums.vwvortex.com/zerothread?id=3318328
    Credit to Travy for creating the original thread.
    Driversport|| Valley Dubs PM me for all your Fragola Fittings and Billy Boat Exhaust Needs!!!
    The Elite 24v VR6 Club: Member #4
    My Build Thread
  2. Moderator Mr. Rictus's Avatar
    Sep 24th, 2004
    Buchanan, NY
    04-05-2012 05:05 PM #2
    Lik to the original thread: http://forums.vwvortex.com/showthrea...Tire-sizes-Q-A
    It's worth looking through that thread before posting, just to see if your setup has been posted before.
    My Build Thread
  3. Member pentaxshooter's Avatar
    Sep 3rd, 2009
    Charlotte, NC
    2004.5 GLI
    04-05-2012 05:06 PM #3
    You misspelled 'wheel' in your first post
    Add me on FB and follow me on Instagram! | #TPG | #FLOSSfilthy | #V2LAB |
    Always looking for cars in the NC/VA area for feature shoots! PM me!
  4. Member jDubz18T's Avatar
    Jun 10th, 2011
    Stroudsburg, PA
    '02 Jetta 1.8T
    04-05-2012 05:44 PM #4
    17"x7.5" B5 Audi S4 Avus wheels:
    235/45/17
    ET45 front and rear
  5. Moderator Mr. Rictus's Avatar
    Sep 24th, 2004
    Buchanan, NY
    04-05-2012 06:20 PM #5
    Quote Originally Posted by pentaxshooter View Post
    Blame Travy, I just cut and pasted.
    Quote Originally Posted by jDubz18T View Post
    235/45/17
    ET45 front and rear
    How do you want them to sit in the fenders? Tuck, flush, poke? How low will you be? Those tires are larger than the 225/45 17 that come stock on Mk. IVs. 235/45 17 is Audi size.
    My Build Thread
  6. Member handdrumman's Avatar
    Aug 28th, 2006
    South 603
    '03 GTi Tippy:(
    04-06-2012 08:12 AM #6
    OK, I'm sure it's prolly posted on here somewhere but the previous wheels/offset thread was 60p long!!
    So i'll be running 18" 8w front 9w rear et35 all around w/205/40 front and 215/40 rear
    Sitting on coils and really just need to clear the front so I can drop it a little more.....might tuck the front if not run the fender flush w/the top of the tire. The rear I don't mind a little poke but same thing, I want basically visually see the car from the side sitting pretty much flush to the top of the tires, maybe a little front rake. Soooo....wondering what to do spacer wise? Any help would be cool, Thanks!!
  7. Member jDubz18T's Avatar
    Jun 10th, 2011
    Stroudsburg, PA
    '02 Jetta 1.8T
    04-06-2012 11:37 AM #7
    Quote Originally Posted by Mr. Rictus View Post
    I would really like them to be flush and I wanna be as low as possible without having an rubbing or other issues. Would 20mm front and 25mm rear be ok?
  8. Junior Member
    Jul 1st, 2011
    Alexandria
    02 VW 1.8t
    04-06-2012 07:09 PM #8
    wheels 18X8.5 et35 front and back
    225/40 18
    want them to sit just inside flush
    only going 2" lower than stock
  9. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-06-2012 07:35 PM #9
    15mm all around maybe a 20 in the back if that's what you're in to
  10. Junior Member
    Jul 1st, 2011
    Alexandria
    02 VW 1.8t
    04-06-2012 08:24 PM #10
    who was that for?
  11. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-06-2012 08:41 PM #11
    You, sorry
  12. Junior Member
    Jul 1st, 2011
    Alexandria
    02 VW 1.8t
    04-06-2012 09:03 PM #12
    im going to guess a roll and removing the liner will be needed
  13. Member Shifty's Avatar
    Mar 25th, 2004
    Oklahoma City Metro
    '01 Jetta 16v(!), '09 CC VR6, 1998 Suburban Command Center, '01 Triumph TT Warbird
    04-07-2012 12:11 AM #13
    Whoa a clean thread!
  14. Member
    Feb 8th, 2011
    New Hampshire
    00 gti
    04-07-2012 09:22 PM #14
    I'm running stock rx2's. Which are 16x6.5 with 42mm offset.
    I lowered my car so the fender to ground is 23.75 and the locks on the coilovers started rubbing my tires. I raised it back up but I prefer it at 23.75. What size spacer will I need to move it away from that lock? Will 10mm be enough?
  15. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    Car that looks good from afar.
    04-07-2012 09:24 PM #15
    Quote Originally Posted by yeabmx View Post
    10mm will be good, yes
    || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
    || Please don't PM me with offset questions, post in THIS THREAD instead ||
    Don't ever support KOCOUREK WAUSAU IMPORTS of Wausau, WI
  16. Member
    Feb 8th, 2011
    New Hampshire
    00 gti
    04-07-2012 09:28 PM #16
    Thanks!
  17. Member Top-NouchVR6's Avatar
    Jun 5th, 2007
    NY/ VA
    94 aba sold, 96 12v sold, 04 24v current
    04-07-2012 10:49 PM #17
    17x8 et 45
    17x9 et 45
    215 45 all around
    25mm adaptors all around
    Looking for slight poke all around. Any help is appreciated
  18. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-08-2012 09:57 AM #18
    Rear is fine maybe change to a 30 up front
  19. Member Blackwolf15's Avatar
    Mar 18th, 2009
    Potomac Falls, VA / Blacksburg,VA
    03 Wolf
    04-08-2012 04:59 PM #19
    I am looking at getting new wheels soon and would like to know what will fit without spacers. I am looking at 18" wheels and hope to be at just under 24" FTG. What offsets are needed to clear coils if looking at 7.5, 8, and 8.5 inch wide wheels?
    Thanks!
    HOKIES
  20. Member Top-NouchVR6's Avatar
    Jun 5th, 2007
    NY/ VA
    04-08-2012 06:03 PM #20
    Quote Originally Posted by alankitzmiller View Post
    was that for me?
  21. Member Blackwolf15's Avatar
    Mar 18th, 2009
    03 Wolf
    04-09-2012 12:31 PM #21
    Quote Originally Posted by Blackwolf15 View Post
    Thanks!
    Bump. Anyone? More specifically would an 18x8.5 et35 fit up front without spacers? 18x8 et35?
    HOKIES
  22. Member Shannon Hamilton's Avatar
    Jun 17th, 2004
    NEW JERSEY
    02 German made Jetta
    04-09-2012 03:10 PM #22
    Wheels are 5x120 et +28 17x7.5 want tuck front flush rear tire size is 205/40/17 . 23 3/8" high to fender. What size adapters do I need? Thanks in advance.
  23. Member VR6Mann's Avatar
    Apr 10th, 2008
    Norfolk, VA & York, PA
    92 Jetta sold, 94 Jetta Sold, 98 Jetta GLX SOLD, 99 2.0 DD and 00 Jetta VR
    04-09-2012 05:06 PM #23
    17x10 all the way around.
    Et0
    On no poke can sit on tire...thanks in advance.
  24. 04-09-2012 09:01 PM #24
    im doing the same wheels and am using 20mm front and rear. 25mm would work for sure in the rear. those tire sizes are a bad idea. im doing 215 falkens and i'll probably have to roll my fronts. rears are no issue with the 20mm tho.
    pic for reference.
    [i have a wagon btw]
    crap
  25. Member
    Sep 5th, 2011
    Richmond, VA
    '03/VW/Jetta 1.8t
    04-10-2012 12:58 AM #25
    I'm looking to run
    17x7.5 et35 all around
    spacer size to sit flush(want tire close'ish to fender), 24" ftg most of the time
    want a conservative stretch nothing too crazy, recommended tire size?
    thanks in advance.
    -Jeremy
  26. Member jDubz18T's Avatar
    Jun 10th, 2011
    Stroudsburg, PA
    '02 Jetta 1.8T
    04-10-2012 02:16 PM #26
    Quote Originally Posted by futur View Post
    pic for reference.
    yeah I guess those tires are Audi size...I bought them from a place that parts them out.
  27. Member
    Oct 30th, 2011
    Toronto, Ontario, Canada
    1999.5 Golf Mk4 2.Slow
    04-10-2012 10:07 PM #27
    Hey guys need some help with spacers heres what im picking up on thursday
    18X9.75 5x100 et 20 all around
    And was thinking front tire
    225/35/18
    Rear tires
    215/35/18
    And i drive a 4 door golf mk4 raceland ultimos coils are all the way down might cut rear bumper stop to make it lower im looking to tuck wit a bit of poke what spacers do u guys think i should run for the front and what is your opinion about tire?
    Thanks in advance
  28. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-10-2012 10:19 PM #28
    you'll probably want 225/40 all around. stay away from 35 series
  29. Member
    Oct 30th, 2011
    04-10-2012 10:35 PM #29
    Just out of curiousity why do suggest 40 series and not 35....what do u suggest spacer wise?
  30. Member ray32's Avatar
    Apr 26th, 2008
    NNJ
    ///BMW X5:staggerd/shaved MK4.:R32
    04-11-2012 11:00 AM #30
    why would you run a 225/f and a 215/r?
    the 40 would be more ideal for 9.75 unless thats the look you going for.....
    depending on the suspension, height, et, etc will alter things around. you should fit the wheel on first then go from there.
  31. Member
    Oct 30th, 2011
    04-11-2012 11:47 AM #31
    Quote Originally Posted by ray32 View Post
    Thanks for the feedback, i think i might just go with 215/40/18 all around and figure out my spacer size after
  32. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    04-11-2012 05:24 PM #32
    Here is the deal, i am going on air soon and i hate my current fitment. Front has way to much poke compared to rear.
    et55-56
    17x9.5 all around
    215/45/17
    33 mm rear and 38mm rear adapters on.
    DSC_0431 by Bierce IV, on Flickr
    DSC_0436 by Bierce IV, on Flickr
    Car is now lower, but what should i run. 36mm front 40mm rear? i want more poke in rear then front. But i also want it to sit right when i go on air. Or should i look for a different setup. (futuras )
    Quote Originally Posted by mk4boost View Post
    If you don't want to break the bank you have the wrong hobby
    My Thread
  33. 04-12-2012 03:22 AM #33
    those fog lights are so naaaaaz
  34. 04-12-2012 04:53 AM #34
    MK4
    rota g-force
    18x9
    +35
    what size spacers
  35. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-12-2012 09:37 AM #35
    Quote Originally Posted by rollbounce View Post
    MK4
    rota g-force
    18x9
    +35
    what size spacers
    10front/15rear
