VWVortex.com - MK4Forum Offsets & Tire Sizes Request Thread
    Page 2 of 137 FirstFirst 1234561252102 ... LastLast
    Results 26 to 50 of 3408
    Thread: MK4Forum Offsets & Tire Sizes Request Thread
    1. Member jDubz18T's Avatar
      Jun 10th, 2011
      Stroudsburg, PA
      Bagged MK4 Jetta 1.8T, MK2 Jetta Diesel
      04-10-2012 03:16 PM #26
      Quote Originally Posted by futur View Post
      im doing the same wheels and am using 20mm front and rear. 25mm would work for sure in the rear. those tire sizes are a bad idea. im doing 215 falkens and i'll probably have to roll my fronts. rears are no issue with the 20mm tho.
      pic for reference.
      [i have a wagon btw]
      yeah I guess those tires are Audi size...I bought them from a place that parts them out.
      Oct 30th, 2011
      Toronto, Ontario, Canada
      1999.5 Golf Mk4 2.Slow
      04-10-2012 11:07 PM #27
      Hey guys need some help with spacers heres what im picking up on thursday
      18X9.75 5x100 et 20 all around
      And was thinking front tire
      225/35/18
      Rear tires
      215/35/18
      And i drive a 4 door golf mk4 raceland ultimos coils are all the way down might cut rear bumper stop to make it lower im looking to tuck wit a bit of poke what spacers do u guys think i should run for the front and what is your opinion about tire?
      Thanks in advance
    3. Member alankitzmiller's Avatar
      Apr 14th, 2009
      Olive Garden
      black blob
      04-10-2012 11:19 PM #28
      you'll probably want 225/40 all around. stay away from 35 series
      Oct 30th, 2011
      04-10-2012 11:35 PM #29
      Quote Originally Posted by alankitzmiller View Post
      Just out of curiousity why do suggest 40 series and not 35....what do u suggest spacer wise?
    5. Member ray32's Avatar
      Apr 26th, 2008
      NNJ
      BMW HAMANN-X6 HPA\\\ BUILT/BORED motor~MK4 R
      04-11-2012 12:00 PM #30
      why would you run a 225/f and a 215/r?
      the 40 would be more ideal for 9.75 unless thats the look you going for.....
      depending on the suspension, height, et, etc will alter things around. you should fit the wheel on first then go from there.
      Oct 30th, 2011
      04-11-2012 12:47 PM #31
      Quote Originally Posted by ray32 View Post
      Thanks for the feedback, i think i might just go with 215/40/18 all around and figure out my spacer size after
    7. Member Bierce IV's Avatar
      Apr 5th, 2010
      NY
      Current:2016 s3 Previous: MKV r32/Mark IV GTI
      04-11-2012 06:24 PM #32
      Here is the deal, i am going on air soon and i hate my current fitment. Front has way to much poke compared to rear.
      et55-56
      17x9.5 all around
      215/45/17
      33 mm rear and 38mm rear adapters on.
      DSC_0431 by Bierce IV, on Flickr
      DSC_0436 by Bierce IV, on Flickr
      Car is now lower, but what should i run. 36mm front 40mm rear? i want more poke in rear then front. But i also want it to sit right when i go on air. Or should i look for a different setup. (futuras )
      Quote Originally Posted by mk4boost View Post
      If you don't want to break the bank you have the wrong hobby
      Detailing/Paint Specialist Arete Auto Salon Detailing
      Mark IV Thread
      R32 Thread
    8. 04-12-2012 04:22 AM #33
      those fog lights are so naaaaaz
    9. 04-12-2012 05:53 AM #34
      MK4
      rota g-force
      18x9
      +35
      what size spacers
    10. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      Car that looks good from afar.
      04-12-2012 10:37 AM #35
      Quote Originally Posted by rollbounce View Post
      MK4
      rota g-force
      18x9
      +35
      what size spacers
      10front/15rear
      || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
      || Please don't PM me with offset questions, post in THIS THREAD instead ||
      May 30th, 2010
      Germany
      1980 W126, 1983 MK2, 2010 Passat Wagon
      04-12-2012 07:26 PM #36
      Static Jetta 23"f/23.5"r ftg
      17x8.5f/9.5r
      ET 20f/30r
      Thinking about 205/45 f and 215/45 r Achilles? Not sure about spacers, I'm on 18x8.5/9.5 ET23/30 on 215f/225r FK452s atm, and I don't really want to rub the rears like now...
      My MK2
      • FVCKD FB | Flickr | IG/
      • IG: @schvmo
    12. Member ArchLibra's Avatar
      Sep 4th, 2008
      Toronto
      2003/VW/Jetta 1.8T 2005/Audi/A4 1.8T
      04-12-2012 09:01 PM #37
      Hey guys, I'm running:
      18x8.0 5x100 ET42 VIP RG-1's all around
      225/40/18
      lowered 1.5" front and rear
      Want to sit flush all around
      Don't have to fender roll with the small 1.5" drop right? Thanks!
    13. Member
      Jan 17th, 2010
      MA
      16 Jetta, 93 Miata (sold), 05 vw gti (Sold)
      04-13-2012 04:15 PM #38
      I need new rear tires,
      Right now im running 225/40/18 512's but I dont think I will be going with 512's this time around.
      If I go with another tire should I go with something 215/40/18? or another 225/40/18? I'm guessing the stretch will be a little less on a tire that's not a 512.
      I found an ns-II on tyrestretch.com in a 215/40/18 and liked the stretch. Any other tires to recommend?
      Thanks for looking
    14. Member Low n' Slow's Avatar
      Jan 13th, 2011
      Boston Ma
      2000 Golf
      04-13-2012 05:46 PM #39
      Wanted to know if i would be fine with theses wheels im looking to buy. mkiv with coils. spacer recommendation for a little poke maybe?
      The specs are 18x8.0 et 43 18x9.5 et 49
      thanks
    15. Member
      Oct 19th, 2010
      Pennsylvania
      03 GTi 1.8t
      04-13-2012 08:25 PM #40
      So right now i have my winter wheel/tire setup on my MKIV Gti. (16" Montreal II's 205/55 tires) with 12mm spacers in the front only because without them my tires would rub the struts. I'm sitting on FK Streetlines. My fronts are around 3.5" from the ground. Im looking at these TSW Nurburgring's. They're 17" by 8 width. The offsets are 35mm or 45mm. I'm unsure of which offset i should choose as i dont really want poke, but i also dont want them deep in the wheel well either. Tire size 205/45 too? If someone could give me some insight that would be awesome, thanks.
    16. Member alankitzmiller's Avatar
      Apr 14th, 2009
      Olive Garden
      black blob
      04-13-2012 09:29 PM #41
      go with the et35 on with that tire size you have in mind, unless you aren't that low, then I'd go with a 215
    17. Member alankitzmiller's Avatar
      Apr 14th, 2009
      Olive Garden
      black blob
      04-13-2012 09:31 PM #42
      Quote Originally Posted by Schümey View Post
      17x8.5f/9.5r
      ET 20f/30r
      yeah go for 205 and 215/45. get a 5 and 10mm spacer
    18. Member alankitzmiller's Avatar
      Apr 14th, 2009
      Olive Garden
      black blob
      04-13-2012 09:33 PM #43
      Quote Originally Posted by Low n' Slow View Post
      thanks
      20-25f 25-30rear
    19. Junior Member JoeR32's Avatar
      Sep 4th, 2010
      Houston, TX
      2004 Volkswagen R32
      04-13-2012 10:27 PM #44
      What size adapter & tires would I run on saw blades? Mk4 r32
      Front 17x8.5
      Rear 17x9.5
      Not sure about et?
      Ride height is 24.5 from wheel fender to the floor.
      Help
      Sent from my Galaxy Nexus
      .:R
    20. Member mk41904's Avatar
      Jan 4th, 2012
      socal
      2012 gli mk6
      04-15-2012 02:11 AM #45
      18x7.5 all 4 et45 what size of spacer run on rear maybe 20mm??
    21. Member ArchLibra's Avatar
      Sep 4th, 2008
      Toronto
      04-15-2012 02:18 AM #46
      225/40/18
      Want to sit flush all around, recommended spacers?
    22. Member
      Oct 19th, 2010
      Pennsylvania
      03 GTi 1.8t
      04-15-2012 10:52 PM #47
      - Will i have to roll my fenders at all? I plan on staying pretty low..
    23. Member alankitzmiller's Avatar
      Apr 14th, 2009
      Olive Garden
      black blob
      04-15-2012 11:04 PM #48
      if you're low enough anything will rub. so yes
    24. Member
      Oct 30th, 2011
      04-16-2012 08:53 AM #49
      Hey guys i posted on here early to figure out what tires i should go with and you guys really helpd me out before i put my wheels on i need some help with spacers what do you guys think? i want to be tucked with a little bit of poke?
      All around
      225/40/18
      Thanks in advance guys i'll post pics once i get everything done
    25. 04-16-2012 01:07 PM #50
      Will this work?
      17x9" ET 24 Front
      17x9.5" ET 17 Rear
      Front fenders are rolled, and i am on air
      Thinking 205/45 front and 215/45 rear
