#71
need some help choosing my tire size.
wheels are:
18x8.5 et 44 15mm adapter
18x9.5 et 46 15mm adapter
im thinking 215/40 and 225/40 but im not sure if they will rub or not.
#72
|| Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
|| Please don't PM me with offset questions, post in THIS THREAD instead ||
Don't ever support KOCOUREK WAUSAU IMPORTS of Wausau, WI
#73
#74
#75
#76
#77
#78
Will this fit on my mk4 jetta?:
16x7.5 et 25
16x9 et 25
205/55 all around.
Sizes and offset can be played with. I have 8mm spacers up front right now, but they don't need to be used. I'm not wanting poke really, just flush with the fender.
Thank you!![]()
#79
that'll workfronts will be almost flush, just a tad bit tucked and the rears will poke only a little bit.
also, if you look at the Mk4 Wheel Offset and Stance Picture Index you can see a 9 et25 listed. that will show you a picture of what yours will look like in the rear, except for the fact that your wheels are 16's.
#80
9.5 widened longbeach
ET63.4
What's the best thickness of spacer i need to fit little poke rear, more flush than poke front (little poke)?
Well, What's the perfect offset for 9.5 inch wheels on a mk4 Jetta?
Thinking of 35mm rear for an final ET28.4 et maybe 25mm in front for final ET38.4?
215/45 should fit perfectly for the stretch?
Thank you all!
#81
215/45 will be fine but you are going to want to have your offsets be around 20ish. I'm pretty sure 22 is the highest you can go with it clearing your coil.
Not gonna lie it all just sounds like a bad idea
#82
17x7 all the way around
et+52 Spacers:15mm/F 17mm/R
Mk4 GTI on coilovers w/ rolled fenders
What size of tire would you recommend, dont wanna poke just keep flush
Thank you in advance![]()
#83
looking to buy some ultimos and looking to run 18x8.5 ET30 or 18X8.5 ET35.
thanks!
#84
Hello !form Kazakhstan
Soon I will get my XXR 522 18" 9.5J et 38 all around.
tires will be 225/35/18.
which spacers i must install all around ? 20 mm or more ?
Do I need to roll out my wheel arches?
sorry for my bad english
My car http://www.drive2.ru/cars/skoda/octa..._tour/bobo911/
Eibcah prokit -30 all around, Koni STR.T.
FK front Strut bar, rear from Skoda Octavia RS + custom
Engine - 2.0 8v stock
#85
Hey . Picking up new wheels tomorrow.
18x9
18x10
Et 38
20mm adapters
Final.et.18
I was thinking
205/40 for The front
215/40 for the rear.
Most likely yoko s drives or nitto neo gens
I'm already low and fenders rolled.
What do u guys think?
#86
buying wheels
how to run 18x8.5 wheels +44
lowered on streetlines?
want to be flush
thanks for the help
#87
18x8.75 all the way around et 20....will these work on a golf?lowerd on spring at the moment ultimos sooner than later trying to get flush
#88
I checked about this info and the highest i can go is near 28mm.
So, i decide to make two of them 8.5 inch, which will probably give me more facility for the final setting for the front axle.
So, 40mm spacers for rear wheels (9.5) for final ET23.4, and 33mm spacers for front wheels (8.5) for final ET17.7
That's ok i think?
But, because now i'm not going to ride a squared setup, what's the correct size of tires i need to have an almost perfect overall diameter between front and rear?
215/45/17 rear
205/45/17 front?
215/40/17 front?
Would like to run 205/45, but want to be sure it's going to fit well...
Need approbation plz!
Thank you!
#89
yup, those will clear your coilovers. will want to roll your front fenders though
you can get away with a 20mm up front. for the back 15-20mm will work well. and yes, definitely roll your front fenders!
the rear is gonna poke quite a bit, but if you want to get into a little fender work or can learn to just deal with it you shouldnt have issues managing that. everything else looks good, tires sure are going to be nice and stretched
15mm up front, 20mm in back
yup, that will work but the fronts are going to poke a little, they won't be flush. is that final offset of 20 with or without spacers? if you can get a smaller spacer, it wouldnt hurt for achieving the look you want![]()
#91
sorry about that, i didnt see your 2nd post about changing to staggered 8.5f and 9.5r. those will work for sure, i'd even consider going with a slightly smaller adapter up front. 8.5et35 is somewhat of a magic number for being flush up front so you could drop to even a 20-25mm adapter if you wanted. rear will poke a little bit but in a good way.![]()
#92
yea the final off set of 20 is with out spacers its the off set of the wheel itself
#93
#94
#95
#96
#97
#98
#99
Sorry about the repost just pick up some sawblades nothing fancy stayed in the budget, need help with tires for r32.
Front 17x8.5/33mm
Rear 17x9.5/38mm
Offset +56
.:R
#101
Picking up a set of wheels pretty soon and curious to see if they will fit...
18x8 et35 audi pattern. Going to run 5x100-5x112 15mm adapters.. Which should give me a final of et20 all the way around.. Is that going to look like total ass or? I really want to run these wheels but them starting with et35 offset its not giving me much of an option.. Thanks Guys![]()
Syndicate________________________________TheChive _______________________________DriveWayBuilds
_____________________________________Follow Me @Kuncle
#102
#103
#104
205/45 on the 8.5's and 215/45 on the 9.5's. oh and feel free to give this a browse: 2011 Sawblades Thread
that will work, you could even go with a 20mm adapter up front if you wanted to. this would be exactly what your fronts would look like with a 20mm:
and your rears with a 20mm would poke 5mm less than this photo:
so you'll be fine running 15-20mm adapters with those audi wheels. for tires i'd do 205/40/18 if you havent made up your mind on that already (that's the size in those pictures)![]()
#105
I bought BBS CH's
18x8 ET40 w/ 18mm Bolt Pattern adapters
18x9 ET35 w/ 18mm " "
my 00' 1.8t's dropped about 3.5 inches..
i currently have 2 225/40's for the 18x9's
and buying 215/40's for the 18x8's
how's it gunna look?
will i have like..tons of poke or whaaa?
im new abit to the whole poke/flush look since before i never had any of that since i ran 17x7.5 audi a8 ET35 without spacers or nothing.
and if anyone has any pictures of what it might look like dont be shy! lol
2000 1.8T Jetta | ChrissTapp Eurodyne Chipped(20 PSI) | Single Gutted Cat To Magnaflow Muffler | RK Coils Dropped 3.5 | Stage 2 Bully Clutch | Blacked Head & Tails | AEM Cold Air | Badgeless Grill |17x7.5 ET35 Audi A8 Replica's |
[Staggerd' BBS CH Black W/ Polished Lip (New) 18x8 ET35/18x9 ET40]
