VWVortex.com - MK4Forum Offsets & Tire Sizes Request Thread
    Page 5 of 137 FirstFirst 1234567891555105 ... LastLast
    Results 101 to 125 of 3414
    Thread: MK4Forum Offsets & Tire Sizes Request Thread
    1. Member Kuncle20's Avatar
      Jan 21st, 2009
      Greenville SC
      Bagged GLI, Street Bob
      04-24-2012 12:53 AM #101
      Picking up a set of wheels pretty soon and curious to see if they will fit...
      18x8 et35 audi pattern. Going to run 5x100-5x112 15mm adapters.. Which should give me a final of et20 all the way around.. Is that going to look like total ass or? I really want to run these wheels but them starting with et35 offset its not giving me much of an option.. Thanks Guys
      __________________________________________________ __Follow Me @ Kuncle_________________________________________
      __________________________________________________ ______The Chive__________________________________________________ __
    2. Member vwgolftwo.slow's Avatar
      Feb 16th, 2012
      cape cod MA
      99 vw golf mk4 02 f250 7.3 diesel
      04-24-2012 07:52 AM #102
      Quote Originally Posted by Clean PG View Post
      rears will look almost identical to this, a little bit of poke.
      thanks for pic reference! if i run a 18x8.75 with a et35 up from will i have less poke ? i don't want the front to poke more than the rear ! new to the scence still trying to figure stuff out haha thanks for the help so far tho !
    3. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      Car that looks good from afar.
      04-24-2012 09:07 AM #103
      Quote Originally Posted by vwgolftwo.slow View Post
      yes, you will have about 12mm less poke than that picture up front. i posted that photo as a reference for how your rear wheels would sit
      || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
      || Please don't PM me with offset questions, post in THIS THREAD instead ||
    4. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      04-24-2012 09:13 AM #104
      Quote Originally Posted by JoeR32 View Post
      Sorry about the repost just pick up some sawblades nothing fancy stayed in the budget, need help with tires for r32.
      Front 17x8.5/33mm
      Rear 17x9.5/38mm
      Offset +56
      205/45 on the 8.5's and 215/45 on the 9.5's. oh and feel free to give this a browse: 2011 Sawblades Thread
      Quote Originally Posted by Kuncle20 View Post
      that will work, you could even go with a 20mm adapter up front if you wanted to. this would be exactly what your fronts would look like with a 20mm:
      and your rears with a 20mm would poke 5mm less than this photo:
      so you'll be fine running 15-20mm adapters with those audi wheels. for tires i'd do 205/40/18 if you havent made up your mind on that already (that's the size in those pictures)
    5. Junior Member
      Jul 20th, 2011
      Embrun
      2000 1.8t Jetta
      04-24-2012 09:42 AM #105
      I bought BBS CH's
      18x8 ET40 w/ 18mm Bolt Pattern adapters
      18x9 ET35 w/ 18mm " "
      my 00' 1.8t's dropped about 3.5 inches..
      i currently have 2 225/40's for the 18x9's
      and buying 215/40's for the 18x8's
      how's it gunna look?
      will i have like..tons of poke or whaaa?
      im new abit to the whole poke/flush look since before i never had any of that since i ran 17x7.5 audi a8 ET35 without spacers or nothing.
      and if anyone has any pictures of what it might look like dont be shy! lol
      2000 1.8T Jetta | ChrissTapp Eurodyne Chipped(20 PSI) | Single Gutted Cat To Magnaflow Muffler | RK Coils Dropped 3.5 | Stage 2 Bully Clutch | Blacked Head & Tails | AEM Cold Air | Badgeless Grill |17x7.5 ET35 Audi A8 Replica's |
      [Staggerd' BBS CH Black W/ Polished Lip (New) 18x8 ET35/18x9 ET40]
    6. Junior Member JoeR32's Avatar
      Sep 4th, 2010
      Houston, TX
      2004 Volkswagen R32
      04-24-2012 10:14 AM #106
      Thanks a lot
      .:R
    7. Junior Member vdub_4life@live.com's Avatar
      Jan 12th, 2011
      springfield vt
      97 vw golf gl
      04-24-2012 10:16 AM #107
      im thinking on gettting ccw @17x8 front 17x9.5 rear but i have not orderd them yet i want it to hellla flush with some poke and sttreched its going on a gti mk4 if that matters plzzz help feel freee to change the sizes
    8. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      04-24-2012 10:31 AM #108
      Quote Originally Posted by ddstfleurr View Post
      I bought BBS CH's
      fronts will sit near flush, just a tiny bit of poke. rears will poke a bit more but it's definitely manageable. may want to consider going down to a 215/40 for the 18x9's
      THIS is what your rears will look like:
    9. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      04-24-2012 10:38 AM #109
      Quote Originally Posted by vdub_4life@live.com View Post
      for fronts to be flush with the 17x8, look into something around a final offset of 29. give or take a few mm won't make a huge difference, so a nice round number of 30 would be good.
      for the rears with the 17x9.5, i'd go somewhere around the same final offset of 30 +/-. this will give you a little bit of poke identical to the rear wheels in this photo: (you can go with a higher or lower offset if you'd like depending on how you want them to sit)
    10. Junior Member vdub_4life@live.com's Avatar
      Jan 12th, 2011
      springfield vt
      97 vw golf gl
      04-24-2012 10:49 AM #110
      soooooo what about spacers it do i not neeed because of thr offest of wheels and what about streched tires
    11. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      04-24-2012 10:57 AM #111
      since you said you were getting CCW's and didnt provide me with offsets, i assumed you were going to get them made to the offset you wanted. if you know the offsets of the wheels, post those numbers up and i can let you know what size spacers to get. or if you want to school yourself a bit, take the offset of the wheel and subtract your desired final offset of 30 from it. the result is how big of a spacer you'll want. (ex. wheel offset is 45. so, 45 - 30 = 15mm spacer)
      for tires, 205/45 on the 17x8 and 215/45 on the 17x9.5
    12. Junior Member vdub_4life@live.com's Avatar
      Jan 12th, 2011
      springfield vt
      97 vw golf gl
      04-24-2012 11:07 AM #112
      i thank you sir
    13. Member vwgolftwo.slow's Avatar
      Feb 16th, 2012
      cape cod MA
      04-24-2012 01:30 PM #113
      alrighty sweet thanks !
    14. Junior Member
      Jul 20th, 2011
      Embrun
      2000 1.8t Jetta
      04-24-2012 03:08 PM #114
      thanks !!
      ad yeah i was suppose to do 215 for the 9 wide and 205 for the 8 wide but the 225's were given to me and im abit short on cash cause i blew my clutch and jumped my tranny like 4 days ago :/
    15. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      04-24-2012 03:18 PM #115
      thanks !!
      if the 225's are in good, or new, condition you could try to sell them for cash to pickup a pair of 215's instead, but it's really not that crucial. you'll be able to run the 225's if you need to.
    16. Member Kuncle20's Avatar
      Jan 21st, 2009
      Greenville SC
      04-24-2012 08:28 PM #116
      Thanks for the quickness on the reply Clean PG. I think it will be on the money once I get there.. They wheels come with like a 225/40/18 whatever the factory size was but they Pilot Sport PS2's so I may go with "Meaty fitment" for the time being and ride those out.. We will see. Thanks again man
    17. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      04-24-2012 09:06 PM #117
      nothing wrong with that, may as well use up the rubber that's already on there. if you're rubbin pretty bad then you know you can either go with smaller tires or do some minor fender work
    18. 04-24-2012 10:23 PM #118
      hey guys, looking at getting raceland ultimos, looking for about 24ftg, i already have 18x8 +35 et wheels, just wondering what adapters, if any, i will need to clear the front helper springs, currently have 225/40r18 for tires, and still have plenty of tread left too so im hoping that ill be able to use this up then go with a 205 or 215
      thanks guys
    19. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      04-24-2012 11:02 PM #119
      Quote Originally Posted by jmichzx6r View Post
      thanks guys
      your current wheels and tires should clear the coilovers just fine, wont need to get spacers
    20. Member Kuncle20's Avatar
      Jan 21st, 2009
      Greenville SC
      04-25-2012 05:45 AM #120
      Im thinking a roll for sure and maybe a slight pull. I hope to go on air before the end of the year so I dont want to do anything that will be so extreme that it looks goofy air'd out..
      Thanks again man
    21. Member alankitzmiller's Avatar
      Apr 14th, 2009
      Olive Garden
      black blob
      04-25-2012 07:49 AM #121
      they're 8 inches wide. don't "pull" anything.
    22. Member Fundaze's Avatar
      Apr 20th, 2011
      Kelowna, Canada
      2003 Jetta GLI 24v VR6, 2014 Jetta 1.8 TSI
      04-25-2012 01:09 PM #122
      Looking at doing wheels 9" all around
      Lemme know if this will work, or if not what spacers will I need?
      Wheel specs are:
      18x9 et 35 all around,
      I have 10mm and 15mm spacers right now and would prefer to use them if possible. Will the fronts clear 18x9 final et 25? I am on streetline coils about 24 ish ftg prob will go lower once i get the wheels. Looking at doing 215/40s all around too.
      Thanks in advance!
      VR Alliance #38
    23. Member alankitzmiller's Avatar
      Apr 14th, 2009
      Olive Garden
      black blob
      04-25-2012 01:20 PM #123
      that will clear and you should be fine using both sets. everything sounds good
    24. Member Fundaze's Avatar
      Apr 20th, 2011
      Kelowna, Canada
      04-25-2012 03:54 PM #124
      Quote Originally Posted by alankitzmiller View Post
      thanks
      VR Alliance #38
    25. Member dubbin27's Avatar
      Oct 24th, 2011
      SOOcal
      mk4 GTI
      04-25-2012 04:03 PM #125
      barely saw your reply thanks clean pg for the tips
