Page 3 of 57 FirstFirst 1 2 3 4 5 6 7 13 53 ... LastLast
Results 71 to 105 of 1977
Thread: MK4Forum Offsets & Tire Sizes Request Thread
  1. Junior Member iron bird's Avatar
    Mar 25th, 2011
    Beaver Falls, PA
    04-18-2012 04:02 PM #71
    need some help choosing my tire size.
    wheels are:
    18x8.5 et 44 15mm adapter
    18x9.5 et 46 15mm adapter
    im thinking 215/40 and 225/40 but im not sure if they will rub or not.
  2. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    Car that looks good from afar.
    04-18-2012 09:53 PM #72
    Quote Originally Posted by iron bird View Post
    wheels are:
    those will be good. i run the same size tires on those wheel widths
    || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
    || Please don't PM me with offset questions, post in THIS THREAD instead ||
    Don't ever support KOCOUREK WAUSAU IMPORTS of Wausau, WI
  3. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-19-2012 10:02 AM #73
    Quote Originally Posted by SeanEh View Post
    They're the rotary forged TSW Nurburgrings. Would they sit closer to my fender than the Montreal II's i have? 17x8 offset 35 compared to my Montreals i have now : 16x6.5 offset 42.
    the TSW's will stick out 26mm more than your Montreals.
  4. Member
    Oct 19th, 2010
    Pennsylvania
    03 GTi 1.8t
    04-19-2012 12:24 PM #74
    Quote Originally Posted by Clean PG View Post
    Thanks a lot, you guys are a lot of help. For tires, if i wanna stay this low, possibly lower (not much though) what would you suggest? 205/45 215/45? Thakns again for the input...
  5. Member heartisall's Avatar
    Nov 14th, 2010
    Virginia Beach, VA
    2003 Volkswagen GTI Anniversary Edition, 1995 Cabrio
    04-19-2012 01:28 PM #75
    Quote Originally Posted by heartisall View Post
    I'm putting Jeep Sahara Wheels on My AE, the specs are 18x7.5 ET 44 all around 5x5 lugs with 71.5 center bore and 215/40/18 tires. I'm looking for pretty much this exact fitment can someone help me out with what the specs on my adapters would be?
    Not trying to repost but I really need to order these ASAP, Any one with any help?
  6. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-19-2012 02:13 PM #76
    if you want that exact just pm rat4life and ask what he was using
  7. Member heartisall's Avatar
    Nov 14th, 2010
    Virginia Beach, VA
    04-19-2012 02:50 PM #77
    Quote Originally Posted by alankitzmiller View Post
    Thanks,I just Pm'd him. I didn't know whose car it was just found the pic on Google Images.
  8. Semi-n00b
    Jul 5th, 2011
    Columbus, IN
    2000 Jetta Vr6
    04-19-2012 06:21 PM #78
    Will this fit on my mk4 jetta?:
    16x7.5 et 25
    16x9 et 25
    205/55 all around.
    Sizes and offset can be played with. I have 8mm spacers up front right now, but they don't need to be used. I'm not wanting poke really, just flush with the fender.
    Thank you!
  9. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-20-2012 08:29 AM #79
    Quote Originally Posted by mattman4494 View Post
    16x7.5 et 25
    16x9 et 25
    205/55 all around.
    Thank you!
    that'll work fronts will be almost flush, just a tad bit tucked and the rears will poke only a little bit.
    also, if you look at the Mk4 Wheel Offset and Stance Picture Index you can see a 9 et25 listed. that will show you a picture of what yours will look like in the rear, except for the fact that your wheels are 16's.
  10. Junior Member __Rac3T!g3R's Avatar
    Aug 10th, 2008
    Quebec, Canada
    vw jetta glx vr6 12v 2000
    04-20-2012 08:08 PM #80
    9.5 widened longbeach
    ET63.4
    What's the best thickness of spacer i need to fit little poke rear, more flush than poke front (little poke)?
    Well, What's the perfect offset for 9.5 inch wheels on a mk4 Jetta?
    Thinking of 35mm rear for an final ET28.4 et maybe 25mm in front for final ET38.4?
    215/45 should fit perfectly for the stretch?
    Thank you all!
  11. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-20-2012 09:10 PM #81
    215/45 will be fine but you are going to want to have your offsets be around 20ish. I'm pretty sure 22 is the highest you can go with it clearing your coil.
    Not gonna lie it all just sounds like a bad idea
  12. n00b
    Mar 19th, 2010
    Sacramento, NorCal
    2002 VW Gti 24v Vr6
    04-20-2012 11:35 PM #82
    17x7 all the way around
    et+52 Spacers:15mm/F 17mm/R
    Mk4 GTI on coilovers w/ rolled fenders
    What size of tire would you recommend, dont wanna poke just keep flush
    Thank you in advance
  13. Junior Member
    Mar 16th, 2012
    Iowa/South Carolina
    2004.5 GLI
    04-21-2012 09:23 AM #83
    looking to buy some ultimos and looking to run 18x8.5 ET30 or 18X8.5 ET35.
    thanks!
  14. 04-21-2012 12:08 PM #84
    Hello ! form Kazakhstan
    Soon I will get my XXR 522 18" 9.5J et 38 all around.
    tires will be 225/35/18.
    which spacers i must install all around ? 20 mm or more ?
    Do I need to roll out my wheel arches?
    sorry for my bad english
    My car http://www.drive2.ru/cars/skoda/octa..._tour/bobo911/
    Eibcah prokit -30 all around, Koni STR.T.
    FK front Strut bar, rear from Skoda Octavia RS + custom
    Engine - 2.0 8v stock
  15. Member bdubsmk4turbo's Avatar
    Aug 14th, 2008
    Long Island NY
    B6 S4, textured & plaid mk4 jetta.(R.I.P, for now)..
    04-21-2012 04:43 PM #85
    Hey . Picking up new wheels tomorrow.
    18x9
    18x10
    Et 38
    20mm adapters
    Final.et.18
    I was thinking
    205/40 for The front
    215/40 for the rear.
    Most likely yoko s drives or nitto neo gens
    I'm already low and fenders rolled.
    What do u guys think?
  16. Junior Member dubbin27's Avatar
    Oct 24th, 2011
    SOOcal
    mk4 GTI
    04-21-2012 09:22 PM #86
    buying wheels
    how to run 18x8.5 wheels +44
    lowered on streetlines?
    want to be flush
    thanks for the help
  17. Member vwgolftwo.slow's Avatar
    Feb 16th, 2012
    cape cod MA
    99 vw golf mk4 02 f250 7.3 diesel
    04-21-2012 09:56 PM #87
    18x8.75 all the way around et 20....will these work on a golf?lowerd on spring at the moment ultimos sooner than later trying to get flush
  18. Junior Member __Rac3T!g3R's Avatar
    Aug 10th, 2008
    Quebec, Canada
    04-23-2012 12:29 AM #88
    Quote Originally Posted by __Rac3T!g3R View Post
    ET63.4
    Thank you all!
    I checked about this info and the highest i can go is near 28mm.
    So, i decide to make two of them 8.5 inch, which will probably give me more facility for the final setting for the front axle.
    So, 40mm spacers for rear wheels (9.5) for final ET23.4, and 33mm spacers for front wheels (8.5) for final ET17.7
    That's ok i think?
    But, because now i'm not going to ride a squared setup, what's the correct size of tires i need to have an almost perfect overall diameter between front and rear?
    215/45/17 rear
    205/45/17 front?
    215/40/17 front?
    Would like to run 205/45, but want to be sure it's going to fit well...
    Need approbation plz!
    Thank you!
  19. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-23-2012 08:41 AM #89
    Quote Originally Posted by gliiving View Post
    thanks!
    yup, those will clear your coilovers. will want to roll your front fenders though
    Quote Originally Posted by bob911 View Post
    you can get away with a 20mm up front. for the back 15-20mm will work well. and yes, definitely roll your front fenders!
    Quote Originally Posted by bdubsmk4turbo View Post
    18x9
    18x10
    Et 38
    20mm adapters
    Final.et.18
    I was thinking
    the rear is gonna poke quite a bit, but if you want to get into a little fender work or can learn to just deal with it you shouldnt have issues managing that. everything else looks good, tires sure are going to be nice and stretched
    Quote Originally Posted by dubbin27 View Post
    buying wheels
    want to be flush
    thanks for the help
    15mm up front, 20mm in back
    Quote Originally Posted by vwgolftwo.slow View Post
    yup, that will work but the fronts are going to poke a little, they won't be flush. is that final offset of 20 with or without spacers? if you can get a smaller spacer, it wouldnt hurt for achieving the look you want
  20. Junior Member __Rac3T!g3R's Avatar
    Aug 10th, 2008
    Quebec, Canada
    04-23-2012 11:35 AM #90
    No idea for me?
  21. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-23-2012 12:38 PM #91
    No idea for me?
    sorry about that, i didnt see your 2nd post about changing to staggered 8.5f and 9.5r. those will work for sure, i'd even consider going with a slightly smaller adapter up front. 8.5et35 is somewhat of a magic number for being flush up front so you could drop to even a 20-25mm adapter if you wanted. rear will poke a little bit but in a good way.
  22. Member vwgolftwo.slow's Avatar
    Feb 16th, 2012
    cape cod MA
    04-23-2012 12:58 PM #92
    yea the final off set of 20 is with out spacers its the off set of the wheel itself
  23. Junior Member __Rac3T!g3R's Avatar
    Aug 10th, 2008
    Quebec, Canada
    04-23-2012 01:06 PM #93
    Thank you so much!
    And for tires? 205/45 front will be ok if i ride 215/45 rear?
  24. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-23-2012 01:22 PM #94
    Thank you so much!
    that'll work
  25. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-23-2012 01:24 PM #95
    ok, well then that's kinda what youre stuck with but it'll still work fine.
  26. Member vwgolftwo.slow's Avatar
    Feb 16th, 2012
    cape cod MA
    04-23-2012 03:31 PM #96
    alright cool i haven't got the wheels yet, just getting a deal thats too good to pass up! how will the rear wheels sit ?!
  27. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-23-2012 03:46 PM #97
    rears will look almost identical to this, a little bit of poke.
  28. Junior Member
    Jan 5th, 2012
    Keswick, Ontario, Canada
    Golf MK4 1.8T,4 door
    04-23-2012 04:18 PM #98
    since you'll need adapters, go with a 20mm on all 4 corners. this will poke a little so if you feel safe doing so, you can run a 15mm adapter up front and a 20 in back.
    in regards to being hubcentric, you can likely find adapters that have an inner bore (the part that sits on your cars hub) of 57.1mm and with an outer bore (the lip the wheel will sit on) of 74.1mm. if you can't find adapters with the outer bore you need, that's where you'll need to install hubcentric rings. ecstuning or adaptitusa should have what you need for adapters though, if not try posting in the classifides. i know some people will custom make adapters to your specs
    Thanks alot! Looking to order adaptors this week. Will loom into ecstuning and the other brand and see what they offer!
  29. Junior Member JoeR32's Avatar
    Sep 4th, 2010
    Houston, TX
    2004 Volkswagen R32
    04-23-2012 05:21 PM #99
    Sorry about the repost just pick up some sawblades nothing fancy stayed in the budget, need help with tires for r32.
    Front 17x8.5/33mm
    Rear 17x9.5/38mm
    Offset +56
    .:R
  30. Member bdubsmk4turbo's Avatar
    Aug 14th, 2008
    Long Island NY
    04-23-2012 06:33 PM #100
    thanks clean pg
  31. Member Kuncle20's Avatar
    Jan 21st, 2009
    Greenville SC
    05 GLI
    04-24-2012 12:53 AM #101
    Picking up a set of wheels pretty soon and curious to see if they will fit...
    18x8 et35 audi pattern. Going to run 5x100-5x112 15mm adapters.. Which should give me a final of et20 all the way around.. Is that going to look like total ass or? I really want to run these wheels but them starting with et35 offset its not giving me much of an option.. Thanks Guys
    Syndicate________________________________TheChive _______________________________DriveWayBuilds
    _____________________________________Follow Me @Kuncle
  32. Member vwgolftwo.slow's Avatar
    Feb 16th, 2012
    cape cod MA
    04-24-2012 07:52 AM #102
    thanks for pic reference! if i run a 18x8.75 with a et35 up from will i have less poke ? i don't want the front to poke more than the rear ! new to the scence still trying to figure stuff out haha thanks for the help so far tho !
  33. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-24-2012 09:07 AM #103
    yes, you will have about 12mm less poke than that picture up front. i posted that photo as a reference for how your rear wheels would sit
  34. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-24-2012 09:13 AM #104
    Quote Originally Posted by JoeR32 View Post
    Front 17x8.5/33mm
    Rear 17x9.5/38mm
    Offset +56
    205/45 on the 8.5's and 215/45 on the 9.5's. oh and feel free to give this a browse: 2011 Sawblades Thread
    Quote Originally Posted by Kuncle20 View Post
    that will work, you could even go with a 20mm adapter up front if you wanted to. this would be exactly what your fronts would look like with a 20mm:
    and your rears with a 20mm would poke 5mm less than this photo:
    so you'll be fine running 15-20mm adapters with those audi wheels. for tires i'd do 205/40/18 if you havent made up your mind on that already (that's the size in those pictures)
  35. Junior Member
    Jul 20th, 2011
    Embrun
    2000 1.8t Jetta
    04-24-2012 09:42 AM #105
    I bought BBS CH's
    18x8 ET40 w/ 18mm Bolt Pattern adapters
    18x9 ET35 w/ 18mm " "
    my 00' 1.8t's dropped about 3.5 inches..
    i currently have 2 225/40's for the 18x9's
    and buying 215/40's for the 18x8's
    how's it gunna look?
    will i have like..tons of poke or whaaa?
    im new abit to the whole poke/flush look since before i never had any of that since i ran 17x7.5 audi a8 ET35 without spacers or nothing.
    and if anyone has any pictures of what it might look like dont be shy! lol
    2000 1.8T Jetta | ChrissTapp Eurodyne Chipped(20 PSI) | Single Gutted Cat To Magnaflow Muffler | RK Coils Dropped 3.5 | Stage 2 Bully Clutch | Blacked Head & Tails | AEM Cold Air | Badgeless Grill |17x7.5 ET35 Audi A8 Replica's |
    [Staggerd' BBS CH Black W/ Polished Lip (New) 18x8 ET35/18x9 ET40]
