Page 4 of 58 FirstFirst 1 2 3 4 5 6 7 8 14 54 ... LastLast
Results 106 to 140 of 1997
Thread: MK4Forum Offsets & Tire Sizes Request Thread
  1. Junior Member JoeR32's Avatar
    Sep 4th, 2010
    Houston, TX
    2004 Volkswagen R32
    04-24-2012 10:14 AM #106
    Thanks a lot
    .:R
  2. Junior Member vdub_4life@live.com's Avatar
    Jan 12th, 2011
    springfield vt
    97 vw golf gl
    04-24-2012 10:16 AM #107
    im thinking on gettting ccw @17x8 front 17x9.5 rear but i have not orderd them yet i want it to hellla flush with some poke and sttreched its going on a gti mk4 if that matters plzzz help feel freee to change the sizes
  3. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    Car that looks good from afar.
    04-24-2012 10:31 AM #108
    Quote Originally Posted by ddstfleurr View Post
    I bought BBS CH's
    18x8 ET40 w/ 18mm Bolt Pattern adapters
    18x9 ET35 w/ 18mm " "
    my 00' 1.8t's dropped about 3.5 inches..
    i currently have 2 225/40's for the 18x9's
    and buying 215/40's for the 18x8's
    how's it gunna look?
    fronts will sit near flush, just a tiny bit of poke. rears will poke a bit more but it's definitely manageable. may want to consider going down to a 215/40 for the 18x9's
    THIS is what your rears will look like:
    || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
    || Please don't PM me with offset questions, post in THIS THREAD instead ||
    Don't ever support KOCOUREK WAUSAU IMPORTS of Wausau, WI
  4. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-24-2012 10:38 AM #109
    Quote Originally Posted by vdub_4life@live.com View Post
    for fronts to be flush with the 17x8, look into something around a final offset of 29. give or take a few mm won't make a huge difference, so a nice round number of 30 would be good.
    for the rears with the 17x9.5, i'd go somewhere around the same final offset of 30 +/-. this will give you a little bit of poke identical to the rear wheels in this photo: (you can go with a higher or lower offset if you'd like depending on how you want them to sit)
  5. Junior Member vdub_4life@live.com's Avatar
    Jan 12th, 2011
    springfield vt
    97 vw golf gl
    04-24-2012 10:49 AM #110
    Quote Originally Posted by Clean PG View Post
    soooooo what about spacers it do i not neeed because of thr offest of wheels and what about streched tires
  6. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-24-2012 10:57 AM #111
    since you said you were getting CCW's and didnt provide me with offsets, i assumed you were going to get them made to the offset you wanted. if you know the offsets of the wheels, post those numbers up and i can let you know what size spacers to get. or if you want to school yourself a bit, take the offset of the wheel and subtract your desired final offset of 30 from it. the result is how big of a spacer you'll want. (ex. wheel offset is 45. so, 45 - 30 = 15mm spacer)
    for tires, 205/45 on the 17x8 and 215/45 on the 17x9.5
  7. Junior Member vdub_4life@live.com's Avatar
    Jan 12th, 2011
    springfield vt
    97 vw golf gl
    04-24-2012 11:07 AM #112
    i thank you sir
  8. Member vwgolftwo.slow's Avatar
    Feb 16th, 2012
    cape cod MA
    99 vw golf mk4 02 f250 7.3 diesel
    04-24-2012 01:30 PM #113
    alrighty sweet thanks !
  9. Junior Member
    Jul 20th, 2011
    Embrun
    2000 1.8t Jetta
    04-24-2012 03:08 PM #114
    thanks !!
    ad yeah i was suppose to do 215 for the 9 wide and 205 for the 8 wide but the 225's were given to me and im abit short on cash cause i blew my clutch and jumped my tranny like 4 days ago :/
    2000 1.8T Jetta | ChrissTapp Eurodyne Chipped(20 PSI) | Single Gutted Cat To Magnaflow Muffler | RK Coils Dropped 3.5 | Stage 2 Bully Clutch | Blacked Head & Tails | AEM Cold Air | Badgeless Grill |17x7.5 ET35 Audi A8 Replica's |
    [Staggerd' BBS CH Black W/ Polished Lip (New) 18x8 ET35/18x9 ET40]
  10. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-24-2012 03:18 PM #115
    thanks !!
    if the 225's are in good, or new, condition you could try to sell them for cash to pickup a pair of 215's instead, but it's really not that crucial. you'll be able to run the 225's if you need to.
  11. Member Kuncle20's Avatar
    Jan 21st, 2009
    Greenville SC
    05 GLI
    04-24-2012 08:28 PM #116
    Thanks for the quickness on the reply Clean PG. I think it will be on the money once I get there.. They wheels come with like a 225/40/18 whatever the factory size was but they Pilot Sport PS2's so I may go with "Meaty fitment" for the time being and ride those out.. We will see. Thanks again man
    Syndicate________________________________TheChive _______________________________DriveWayBuilds
    _____________________________________Follow Me @Kuncle
  12. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-24-2012 09:06 PM #117
    Quote Originally Posted by Kuncle20 View Post
    nothing wrong with that, may as well use up the rubber that's already on there. if you're rubbin pretty bad then you know you can either go with smaller tires or do some minor fender work
  13. 04-24-2012 10:23 PM #118
    hey guys, looking at getting raceland ultimos, looking for about 24ftg, i already have 18x8 +35 et wheels, just wondering what adapters, if any, i will need to clear the front helper springs, currently have 225/40r18 for tires, and still have plenty of tread left too so im hoping that ill be able to use this up then go with a 205 or 215
    thanks guys
  14. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-24-2012 11:02 PM #119
    Quote Originally Posted by jmichzx6r View Post
    thanks guys
    your current wheels and tires should clear the coilovers just fine, wont need to get spacers
  15. Member Kuncle20's Avatar
    Jan 21st, 2009
    Greenville SC
    05 GLI
    04-25-2012 05:45 AM #120
    Im thinking a roll for sure and maybe a slight pull. I hope to go on air before the end of the year so I dont want to do anything that will be so extreme that it looks goofy air'd out..
    Thanks again man
  16. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-25-2012 07:49 AM #121
    they're 8 inches wide. don't "pull" anything.
  17. Member Fundaze's Avatar
    Apr 20th, 2011
    Kelowna, Canada
    2003 Jetta GLI 24v VR6
    04-25-2012 01:09 PM #122
    Looking at doing wheels 9" all around
    Lemme know if this will work, or if not what spacers will I need?
    Wheel specs are:
    18x9 et 35 all around,
    I have 10mm and 15mm spacers right now and would prefer to use them if possible. Will the fronts clear 18x9 final et 25? I am on streetline coils about 24 ish ftg prob will go lower once i get the wheels. Looking at doing 215/40s all around too.
    Thanks in advance!
    VR Alliance #38
  18. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-25-2012 01:20 PM #123
    that will clear and you should be fine using both sets. everything sounds good
  19. Member Fundaze's Avatar
    Apr 20th, 2011
    Kelowna, Canada
    04-25-2012 03:54 PM #124
    Quote Originally Posted by alankitzmiller View Post
    thanks
    VR Alliance #38
  20. Junior Member dubbin27's Avatar
    Oct 24th, 2011
    SOOcal
    mk4 GTI
    04-25-2012 04:03 PM #125
    barely saw your reply thanks clean pg for the tips
  21. 04-25-2012 07:43 PM #126
    thanks for the response
  22. Member CJVR6508's Avatar
    May 20th, 2011
    Cape Cod, Mass
    bagged pos jetta
    04-25-2012 08:38 PM #127
    thinking about getting some vette 35th anni's 17x9.5 all around et56 I think. they come with 225/45's already stretched.
    my question is...would I be okay running the 225's or will they be too beefy? maybe at least run them for the rears and get 215's up front? I'd rather not have to get 4 new tires. and what would be a good adapter size for the 225's? 33mm? let me know thanks!
    Quote Originally Posted by zrau17 View Post
    buy vw. mod vw. claim vw is gay. make thread for all to see. sell vw. buy m3/s2000. start new thread and bask in glory.
    DUSTY / Instagram: @ayo_cpavao
    mk4 parts for sale! air ride/wheels etc.
  23. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-25-2012 10:11 PM #128
    225s are gonna be pretty beefy for you for sure. these are your same wheels with 215/45 et 18 all around
  24. Member Dubstatic's Avatar
    Apr 25th, 2007
    86oh
    05 gti , 01 cbr929rr, bicycle.
    04-26-2012 09:37 AM #129
    have a question
    I got my futuras beat up from a buddy of mine that had them on a mk4. he had long forgotten the offsets but I knew how they sat on the car so I didnt worry. Im trying to get a rough idea of the offset. the fronts are 17x8 and the rears are 17x10 they are porsche fitmen so I fugure most porsche wheels have an et in the low 50s. the front adapters are 30mm and the rear are 22(also have 25mm spares)
    I was going to figure out the offsets but I couldnt wait to get the wheels on the car
    this is how the car sits
    Dubstatic
    REP860
    CornStatuS
  25. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-26-2012 11:15 AM #130
    i'd guess both front and back wheels have offsets in the 55-59 range. cant you take a wheel off and look at the stamp? you should, because i'm curious how close my estimates are
  26. Member
    Apr 11th, 2011
    jersey
    bagged mkiv golf- SOLD bagged mkv jetta
    04-26-2012 11:45 AM #131
    what size spacers can i run to have the wheels flush with the fenders, im on air too.
    arietta 17inch wheels 38mm offset all around
    (not to good with offsets and all that jazz)
    BTA
  27. Member Dubstatic's Avatar
    Apr 25th, 2007
    86oh
    04-26-2012 11:47 AM #132
    theres nothing stamped into the back of the wheel.
    Dubstatic
    REP860
    CornStatuS
  28. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-26-2012 11:51 AM #133
    Quote Originally Posted by Hustle-DubS View Post
    are they redrilled? there should be a stamp under the center cap
  29. Member Dubstatic's Avatar
    Apr 25th, 2007
    86oh
    04-26-2012 12:00 PM #134
    they have type 2 center caps. but theres nothing under them, the havent been redrilled. there still the original porche bolt patters. they have been refinshed a few times so maybe the stamp got sanded off?
    Dubstatic
    REP860
    CornStatuS
  30. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-26-2012 12:02 PM #135
    you should do this if you get a chance:
    Quote Originally Posted by Calculating the offset of a wheel
    First, measure the overall width of the wheel (remember, just because a wheel is 18x7.5, does not mean that the OVERALL width is 7.5”. It means that the measurement between the outboard flange and the inboard flange is 7.5”). Next, divide that width of the wheel by two; this will give you the centerline of the wheel.
    Overall width/2 = Centerline
    After determining the centerline, measure from the hub-mounting surface of the hub to the edge of the inboard flange (if the wheel were laying flat on the ground – face up – your measurement would be from the ground to the hub-mounting surface). This is your back spacing.
    Centerline - Back spacing = Offset
  31. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-26-2012 12:06 PM #136
    I mean under the center cap on the face itself, not hte actual center cap but its possible it got powdered over as they are lightly stamped on mine.
  32. Member Dubstatic's Avatar
    Apr 25th, 2007
    86oh
    04-26-2012 12:11 PM #137
    nothing there. I looked when we had the wheels apart. im pressure sure the markings are gone. at one point the wheels were chrome so Im so it was a bitch to get it all off so thats prob why there is no marking. I guess I just got to take the wheel of and calculate. doesnt matter now casue the wheels sit well but for selling reasons it helps to know what the offsets are.
    Dubstatic
    REP860
    CornStatuS
  33. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-26-2012 12:51 PM #138
    17x10 etgood
  34. Member Dubstatic's Avatar
    Apr 25th, 2007
    86oh
    04-26-2012 12:52 PM #139
    17x10 etgood
    hahaha. i had someone on instagram ask me my offsets, thats what I should have said
    Dubstatic
    REP860
    CornStatuS
  35. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-26-2012 12:56 PM #140
    17x10 etgood
    rofl
