Page 5 of 57 FirstFirst 1 2 3 4 5 6 7 8 9 15 55 ... LastLast
Results 141 to 175 of 1988
Thread: MK4Forum Offsets & Tire Sizes Request Thread
  1. Member Dubstatic's Avatar
    Apr 25th, 2007
    86oh
    05 gti , 01 cbr929rr, bicycle.
    04-26-2012 01:00 PM #141
    Quote Originally Posted by Clean PG View Post
    rofl
    kinda what happened when I bought them. I knew how they looked on my buddies gti so i was sold. plus I got them so cheap with 2 full sets of adapters I was happy
    Dubstatic
    REP860
    CornStatuS
  2. Junior Member
    Apr 2nd, 2012
    west texas
    mk4 gti
    04-26-2012 01:02 PM #142
    17X9.0 ROTA GRID WHEELS
    5X100
    35MM WHITEoffset
    with hub core is 73mm
    im also dropped on tein stech springs what do i need to make these fit n how much it will be
  3. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-26-2012 01:11 PM #143
    Quote Originally Posted by checho03gti View Post
    5X100
    35MM WHITEoffset
    15 and 20 mm spacers, go to www.42draftdesigns.com for spacers/extended lugs and you shouldn't have any problem finding everything you need.
    215/45s
  4. Junior Member
    Apr 2nd, 2012
    west texas
    mk4 gti
    04-26-2012 01:22 PM #144
    what about the hub bore size, is that an issue
  5. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    Car that looks good from afar.
    04-26-2012 01:26 PM #145
    you can get hub centric rings that will fit a 73mm wheel bore to a 57.1mm hub. or you could also look into getting spacers made with a hub centering lip on them to meet those specs (if you're going to be running spacers anyway).
    || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
    || Please don't PM me with offset questions, post in THIS THREAD instead ||
    Don't ever support KOCOUREK WAUSAU IMPORTS of Wausau, WI
  6. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-26-2012 01:39 PM #146
    yeah they only hubcentric rings we sell are the ones for adapters, but they aren't hard to find
  7. 04-28-2012 02:11 AM #147
    anybody have foto with 18"/10J with minimal ET 0 - 10 on rear golf or jetta mk4 ?
    My car http://www.drive2.ru/cars/skoda/octa..._tour/bobo911/
    Eibcah prokit -30 all around, Koni STR.T.
    FK front Strut bar, rear from Skoda Octavia RS + custom
    Engine - 2.0 8v stock
  8. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-28-2012 02:43 PM #148
    Quote Originally Posted by bob911 View Post
    this is 18x10 et13, lowest i could find. keep in mind there is some some pretty good camber in the rear. you could probably do it, but would for sure need to pull your rear fenders and add camber as well.
  9. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-28-2012 04:39 PM #149
    It's also an R and they can run way lower offsets due to the IRS. Those offsets would be way too low for a mkiv with a solid rear beam
  10. 04-28-2012 05:18 PM #150
    i just bought a set of avant garde's 18x8 in front an 18x9 in back i want them stretched but idk wat size tire to get!
  11. Member furr's Avatar
    Jul 3rd, 2009
    jerzy
    low 18t
    04-28-2012 08:04 PM #151
    Quote Originally Posted by SamminSammin View Post
    205/40/18 or 215/40/18 should be good
    Gravy
    instagram @furr21
  12. Junior Member
    Apr 3rd, 2012
    Olive Branch, Mississippi
    1994/Mazda/Miata 1999/Jeep/Wrangler 2001/VW/GTIVR6 1932/Ford/ModelA
    04-28-2012 11:42 PM #152
    18x8.5 et48 all around. with 205/35 tires?
  13. 04-28-2012 11:54 PM #153
    I want my wheels flush what spacers you recoment
    18x7.5 et45
    215/40/18
  14. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-29-2012 12:46 AM #154
    Quote Originally Posted by cking93 View Post
    30mm and 215/40
  15. 04-29-2012 12:53 PM #155
    hi im new to forums so please be gentle with me
    i have a mk4 gttdi and some 17x7.5 rotas wit an et45 offset, What size spacers/adapters do i need for a good flushed style fitment. please post pics of examples for my inspiration
    thanx guys
  16. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-29-2012 04:56 PM #156
    Quote Originally Posted by mk41904 View Post
    18x7.5 et45
    215/40/18
    20mm spacers up front and 25mm rear
    Quote Originally Posted by tdijay View Post
    thanx guys
    same as above, 20mm front and 25mm rear
    both of you will look very similar to this: http://forums.vwvortex.com/showthrea...1#post77076565
  17. 04-29-2012 10:11 PM #157
    Hi all, I'm new here. There is a ton of useful information here, thanks! I'm sure it's been brought up somewhere here, but I haven't found it, so...
    I have a 2000 MKIV Jetta. It's suspension is stock, and it's on the factory 15" steel wheels with a set of 195/65-15 tires that would make Mr. Bridgestone cry. A lot. It's my work car, and it wasn't taken care of before I bought it. That being said, it doesn't have to look like a complete turd. It's got 165,000 on it, so I don't want to put a TON of money into aesthetics, but if I'm going to get tires, I might as well try to sneak a decent set of wheels past my wife... I'd like get away with something that doesn't require spacers if I can (work car budget).
    A Craigslist search has located a few sets for $300-$350. The first is a set of SRT4 rims for $100. I know, blasphemy. I'm not a purist, and I've seen a couple of VWs on them that didn't look too bad. The first rim is
    17x6" with an offset of 45 compared to 35 stock
    I'm figuring 224/45-17 should move me inboard toward the strut an inch. I think that may be too much, but thought I'd ask you folks.
    The second is a set of
    xxr? 502 18x8.5 with an offset of 35
    With a set of 90% tread 235/40-18 for $350 obo.
    I havent done the math on this set, but I'm betting the stock offset isn't going to help me enough to get past needing spacers.
    Any decent looking wheels from other makes that swap onto a Jetta easily?
    Thanks in advance.
    Zach
  18. Junior Member
    Apr 3rd, 2012
    04-29-2012 11:20 PM #158
    I've got 18x8.5 et48 wheels with 205/35 tires I'm putting on my gti. The bolt pattern is 5x120. What size adaptor is best? I've found 15mm, 16mm, 1", 1.25", 1.5", and 2" adaptors. And the hub bore on the wheels is 74.1
  19. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-29-2012 11:24 PM #159
    since youre on stock suspension, most wheels will fit just fine on your car. be sure theyre 5x100 so you don't need to spend an extra few hundred on adapters though. the issue of rubbing comes into play when cars are lowered and the adjustable collars sit low enough on the strut body to possibly rub the inside of a high offset (35+ in most cases) wheel
    so basically, you'll be fine with anything 5x100 with an offset 45 or lower
  20. Member
    Sep 25th, 2011
    Earth
    MK4 BitchBucket
    04-30-2012 03:39 AM #160
    Raderwerks MTEN-80's
    18x8F (et35) with a 215/40/18
    18x9R (et35) with a 225/40/18
    i already have 8mm spacers in front and like how it looks, but i'm up in air about the rear. Right now i have a 20mm spacer in back but i don't like the amount of poke...stuck between a 15mm and 12mm. I want to be able to go lower (maybe half an inch of wheel gap) without rubbing terribly and destroying my tires after 20 miles. pics for reference would help Thanks!
    Unitronic Stage 2+ - 3" DP/Cat Delete/2.5" Custom Magnaflow -210/210 Eurospec Cams - Neuspeed P-Flo - Racelands -
    - BFI Stage 1 Dogbone Mount - Forge 007 DV - 42DD Shifter Bushings - Pwrhaus SAI Block-Off Plate - Forge Short Shifter
  21. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-30-2012 08:49 AM #161
    Quote Originally Posted by YoungDub9 View Post
    9et15 is a good amount of poke to run with 225/40 tires, i'd honestly go with no spacer or a 5-10mm in the rear. don't bother trying the 15 cus you won't gain much.
    the rear wheel shown in THIS Post would be what you'd get with a 10mm spacer. hell, maybe just mount em up with no spacers at all to go along with the little bit of tuck or flush that your front wheels have
  22. Member pim r32's Avatar
    Jan 13th, 2008
    New York
    04 TR R32
    04-30-2012 12:36 PM #162
    i orderd a set off ccw's classics for my mk4 r32. im still waiting for the wheels to made and shipped. Since im still waiting, im trying to decide the right tire size. I was told to run a 225/40 on the rear and 215/40 in the front.
    SPECS.
    front 18x8.5 et 25
    rear 18x10 et 19
    im thinking about running 215/40 in the rear because i dont want to run a -3 camber. i like the straight kind of poke on the rear, not to much camber.!So if I go with a 215/40, I wont need to go with a -3 camber? I was guessing with a 215/40, i wouldnt have to go withthat much camber because it gives me more clearence. Am i on the right track, if not, please correct me, and help me. I'm just trying to double check if I got the right idea or not.
  23. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-30-2012 12:48 PM #163
    you could go either way really. gonna have a good amount of uneven stretch with the 215 which always bothers me. I know pat ran 215/40 on his 18x10 et 13 (picure in this thread somewhere)
  24. Member pim r32's Avatar
    Jan 13th, 2008
    New York
    04 TR R32
    04-30-2012 12:55 PM #164
    will a 215/40 help by not having to camber -3, since 215/40 stretches a little more than a 225/40.
  25. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-30-2012 01:05 PM #165
    I don't think you'll need to max out the camber with that offset no. I don't really have any experience with R32s though
  26. Member pim r32's Avatar
    Jan 13th, 2008
    New York
    04 TR R32
    04-30-2012 01:11 PM #166
    This kid Aaron ran a -3 camber with 18x10et18, with a 225/40 tire. so i was thinking if i go with a 215/40, i wont need to go with a -3 camber because 215/40 will give me more clearence.
  27. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-30-2012 01:31 PM #167
    best bet would be to PM him about it honestly. I love his car
  28. Member pim r32's Avatar
    Jan 13th, 2008
    New York
    04 TR R32
    04-30-2012 01:39 PM #168
    Quote Originally Posted by alankitzmiller View Post
    i guess I'll have to that lol
  29. Member
    Sep 25th, 2011
    Earth
    MK4 BitchBucket
    04-30-2012 01:50 PM #169
    I threw a 7mm on yesterday and it looked wayy to tucked...i was thinking a 12mm so a final et23 on the 18x9
  30. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-30-2012 02:04 PM #170
    that's what my twists rears were
  31. Member
    Sep 25th, 2011
    Earth
    MK4 BitchBucket
    04-30-2012 03:21 PM #171
    Ok nice and it wasnt too tucked? I'm looking for a happy medium
  32. Junior Member
    Apr 3rd, 2012
    04-30-2012 04:43 PM #172
    I have some BMW wheels I'm putting on my gti. 18x8.5et48. The hub bore is 74.1 and I'm putting 215/40 falken 912's on them. The wheels are 5x120 and need to fit to 5x100. Which adaptor size is best? I've found 15mm, 16mm, 1 inch, 1.25 inch, 1.5 inch, and 2 inch. I'm thinking 1.25 is the closest the being flush, but want to be sure. Or would it be better to go with a smaller adaptor with a spacers also?
  33. Senior Member Clean PG's Avatar
    May 9th, 2005
    Wisconsin
    04-30-2012 06:18 PM #173
    you'd be good with a 20mm up front. could even run a 25mm and it'd look like THIS
    for the back i'd get 25 or 30mm. 30mm in the back would look like THIS
  34. Member alankitzmiller's Avatar
    Apr 14th, 2009
    Olive Garden
    black blob
    04-30-2012 06:27 PM #174
    It just barely poked
  35. Member
    Jun 21st, 2009
    MA
    01 MK4 GTi
    05-02-2012 08:21 PM #175
    Anyone run sawblades 9.5 all around 215 front 225 rear. 38mm all around adapters? Or 38mm 27mm? On gti? What problems will I run into.
