VWVortex.com - MK4Forum Offsets & Tire Sizes Request Thread
    Page 9 of 137 FirstFirst ... 56789101112131959109 ... LastLast
    Results 201 to 225 of 3406
    Thread: MK4Forum Offsets & Tire Sizes Request Thread
    1. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      Car that looks good from afar.
      05-08-2012 03:50 PM #201
      Quote Originally Posted by dasdubway View Post
      OK so here is my question for you guys I'm looking to run some Mercedes wheels I need to know what size adapters to run and what size tires on a lowered 04 vr6 GTI here are the stats of the wheels:
      FRONT: Size- 18x8
      Offset - ET 30
      REAR: Size - 18 x 9
      Offset - ET 39
      Sent from my DROID RAZR using Tapatalk 2
      20mm adapters all around and it'll look just like THIS.
      for tires i'd go 215/40 on the 8's and 225/40 on the 9's.
      || Mk4 Wheel Offset and Stance Picture Index || ClearWaterDubs || ClearWaterDubs@VWVortex ||
      || Please don't PM me with offset questions, post in THIS THREAD instead ||
    2. 05-08-2012 04:05 PM #202
      Need Tire and clearance advice.
      18x8 ET48 Wheels
      Raceland Ultimo's (haven't installed yet)
      Just ordered 20mm (f) and 25mm (r) adapters for a final ET of 28 and 23
      Will I clear the Racelands up front, and will I need a fender roll if I go with 225/40/18 tires?
    3. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      05-08-2012 04:09 PM #203
      Quote Originally Posted by SOLDO325i View Post
      18x8 ET48 Wheels
      you'll clear just fine and you will want to roll your fenders eventually.
    4. Junior Member
      Jan 17th, 2011
      Glendale,AZ
      2004 VW GTI VR6
      05-08-2012 04:59 PM #204
      Quote Originally Posted by Clean PG View Post
      Thank you for the help!
    5. 05-08-2012 05:01 PM #205
      Thanks for the help
      I'm daily driving the car downtown and the roads are awful. I won't be dropping it as low as I'd like to so I can try and salvage my lip. Maybe keep things conservative at 25"ftg?
      Will I need to roll the fenders because I'll rub on the 225's? I would like to try and keep things without rolling the fenders, would a 215 keep me safe?
    6. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      05-08-2012 05:13 PM #206
      Thanks for the help
      225/40 is fine, you wont rub very much at 25ftg. if you do get free time though it never hurts to roll your fenders, because a month from now you WILL want to go lower i'd roll fenders before considering a smaller tire, it's not a very hard task and is cheaper than buying all new rubber, so stick with the 225/40 and that offset
    7. 05-08-2012 05:31 PM #207
      Awesome, thanks again! I haven't purchased the tires yet, so that's why I wanted to get all the info I could so the install is as painless as possible in terms of rubbing and clearance. I would LOVE to go much lower but it just won't work in the city for me and I constantly have passengers in the car. Hopefully I can eventually go air to solve that whole problem. This querstion might be a bit much, but are there any 225's more narrower than others? I know I had a pair of 235 Pirelli's and Barrums and the Barrums didn't bulge over the wheel as much.
      Would a 15mm adapter up front still clear the racelands and avoid any tire rubbing issues?
      I take it I won't have any issues with rubbing with the rear at ET23 then? When I had the Aristos on the car the rear looked like it could use a good 15mm spacer minimum.
    8. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      05-08-2012 06:35 PM #208
      in regards to ^^
      many tires have different sidewalls and they act different when mounted. a 225/40 on an 18x8 is pretty standard and your sidewalls will be pretty much straight, shouldnt have any buldge or stretch. you can check www.tyrestretch.com to see if any photos are listed in that size and get an idea of how it may look.
      you can drop to a 15mm adapter up front and still clear. i personally don't trust 15mm adapters so that's why i didnt recommend them either will look good though and the rear is fine since the strut setup back there is different and doesnt create an issue with getting too close to the wheel/tire
    9. Semi-n00b Oldschool-Boost's Avatar
      May 3rd, 2012
      Fredericksburg, Va
      2003 Jetta 1.8T
      05-09-2012 12:37 AM #209
      What about some 19x9 +38 Front & 19x10 +38 Rear on an 03 Jetta 1.8T? I have had the wheels for sometime now sitting in the garage & figured if they will work then why not use them.
      Current:
      1983 Mazda RX7 Limited Edition
      1986 Mazda RX7 GXL
      2003 VW Jetta 1.8T
      2006 MazdaSpeed6 Touring
    10. Member BrettNZ's Avatar
      Aug 27th, 2011
      New Zealand
      Imola S4
      05-09-2012 04:58 AM #210
      OEM E92 M3 wheels
      Without adapters
      F-8.5" 29p
      R-9.5" 23p
      Tyres and adapters size? Can get 5mm milled off each wheel to raise offset
      Disregard females. Acquire money
      Disregard money. Acquire car
      Disregard life. Acquire stuff for car
    11. Member As4urazz's Avatar
      Mar 25th, 2006
      mid-atlantic
      2013 Passat SE
      05-09-2012 06:24 AM #211
      Hey, I have some raderwerks 18x8.5f, 18x9.5r. Rocking 215-40-18 all around. What size tire for the rear do I need to get a more meaner stretch?? Thanks!!
    12. Member BrettNZ's Avatar
      Aug 27th, 2011
      New Zealand
      Imola S4
      05-09-2012 06:56 AM #212
      Quote Originally Posted by As4urazz View Post
      205/40/18
    13. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      05-09-2012 09:29 AM #213
      what brand/model of tires do you have on there now? 215/40 should already be quite a bit of stretch on a 9.5, but some tires don't stretch as well as others. do you have a lot of poke in the back where you need more stretch?
      here's a 205/40
      and here's a 215/40 for comparison
    14. Member As4urazz's Avatar
      Mar 25th, 2006
      mid-atlantic
      2013 Passat SE
      05-09-2012 09:42 AM #214
      here's a 205/40
      Awe man, perfect. I have frikken nakang! What brand do you suggest? Thanks!!
    15. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      05-09-2012 10:34 AM #215
      from what i've heard, Nankang NS2's do stretch pretty well but if yours don't look like the 215/40 pictured then you could consider just changing tires if you didnt want to drop down to a 205/40. but at the same time if you're going through the hassle of changing tires and you really want more stretch you may as well drop down 1 size. some popular tires for stretching are falken 512 (only available on discounttiredirect.com) and nitto neogens.
      it's really your call though with what you want to do though, i'd just think a 205/40 on a 9.5 is gonna feel pretty rough because there's such little rubber there. but it certinally has been done before
    16. Member
      Jun 21st, 2009
      MA
      MK7 GTI
      05-09-2012 12:23 PM #216
      Question
      35th anniversary wheels on a gti vmaxx coils spun all the way down rear perches pulled
      Tire size 215 45 17
      Tim width 9.5 all around
      Adapters 28 front 22 rear
      Will this be possible without rubbing suspension pieces? Or will the wheel hit my coil or adjuster in the front
      Wondering cuz I'm getting this setup from someone wondering If I have to do anything I don't want to adjust I want to stay low clearly
      Also I have a 8mm spacer but it's 5x100 there's no way to make that work with the adapter if I had to right? It's hub centric and has bolts. Can't I put the spacer on then the adapter? I've never used adapters idk.
    17. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      05-09-2012 12:31 PM #217
      Quote Originally Posted by imablackhat View Post
      Question
      Tire size 215 45 17
      you can't really go too much higher than 9.5et18 up front if you're on coilovers. i'm not sure if you meant in your post that "Adapters 28 front 22 rear" means final offset or not, but just know that 9.5 up front is going to limit you with the offset range you can be within. i also wouldnt recommend stacking a spacer on an adapter if it came down to it.
    18. Member
      Jun 21st, 2009
      MA
      MK7 GTI
      05-09-2012 12:35 PM #218
      Adapter sizes are 28mm front 22 rear
      Not sure of any offsets. Those are just adapter sizes.
    19. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      05-09-2012 12:41 PM #219
      oh ok, i need to know the offsets of the wheels then to figure out if they'll work.
      edit:
      didnt realize you were talking about corvette wheels, everything you need to know is in this thread --> http://forums.vwvortex.com/showthrea...wblades-Thread
      but to sum it up, run 38mm adapters in the front and 33mm in the rear with 215/45/17 tires
    20. Member
      Jun 21st, 2009
      MA
      MK7 GTI
      05-09-2012 12:42 PM #220
      http://www.rimtuck.com/setup/view/1220
      Found this thread on google. Seems rims are et +56? Offset and numbers confuse me -_-
    21. Member
      Jun 21st, 2009
      MA
      MK7 GTI
      05-09-2012 12:57 PM #221
      This is current owner showing clearance using the exact setup I'm talking about. Unsure of his coilovers. But mine are spun all the way down. Looks like it may just clear. Unsure.
    22. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      05-09-2012 01:56 PM #222
      when i had vmaxx coilovers i'm quite positive that the adjustable collars sat much lower on the front struts than the ones you have pictured (whatever brand those may be). mine were about level with the inner sidewall of the tire when i spun mine all the way down. meaning, if you don't have the right offset you can and will rub. you can try it, but i honestly doubt it'll clear.
      one thing you could do is ask the seller to measure the distance between the bottom adjustable collar to where the strut seats in the hub. then compare that to your coilovers and see if it's the same height or if there's a difference.
    23. Member
      Jun 21st, 2009
      MA
      MK7 GTI
      05-09-2012 01:58 PM #223
      What about using my current 8mm spacer and then putting the adapter on? Or what about something cheap. Maybe autozone spacer or something haha
    24. Senior Member Clean PG's Avatar
      May 9th, 2005
      Wisconsin
      05-09-2012 02:02 PM #224
      i'm just going off facts in the sawblades thread. many people run 9.5's all around and use the adapter sizes i listed (which i pulled directly from the thread). you can try what the seller is running, but based off other peoples experiences i think you'll end up needing a bigger front adapter in the end. if the seller is local, mount them up on your car and see. if it works, great. if it doesnt, then you know you need a bigger adapter.
      also, like i said before, i wouldnt stack a spacer on an adapter. but it's your car not mine
    25. Member n00bsauce's Avatar
      Feb 12th, 2012
      CT
      '03 Jetta Wolfsburg
      05-09-2012 06:25 PM #225
      wish I saw this before I put my sawblades on. I bought a 25 for the front and a 33 for the back with my coilovers and ended up playing musical adapters all night to not rub on my coils. even had to borrow a 5mm spacer from a friend.
