VWVortex.com - harness help
    Results 1 to 6 of 6
    Thread: harness help
    1. Member 1991corradog60's Avatar
      Sep 14th, 2008
      ephrata PA
      91 VR Corrado / 95 Jetta / 06 Jetta/ 06 Gti/ 98 Gti
      04-05-2012 06:43 PM #1
      just need some quick info. seems as if the PO hacked a harness coming out of the passenger side of the firewall. there are some plugs but most of them are gone and i have no idea what theyre for. planing on doing an aba swap and am not sure if ill need these. any input helps. thanks!
    2. Member mattrip's Avatar
      Sep 5th, 2005
      VA
      92' Corrado
      04-06-2012 03:33 PM #2
      Can you add some pics of the wires in question, or a better description of the location and wire color?
      Will need more info to be any help.
      "A sudden provocation does not make me an ill-tempered man. It shows what an ill-tempered man I am."
    3. Member 1991corradog60's Avatar
      Sep 14th, 2008
      ephrata PA
      04-06-2012 04:31 PM #3
      There's a whole separate harness that comes out of the passenger firewall maybe 10-20 wires ill try and get pics then.
    4. Member mattrip's Avatar
      Sep 5th, 2005
      VA
      92' Corrado
      04-06-2012 04:38 PM #4
      Form your user name and vehicle description I presume this is a VR swap into a 91 G60.
      Was, or is this an automatic transmission Corrado? Reason I ask is these is a pretty massive wiring harness that comes from the pass. side firewall on automatic models. If someone swapped in a 5 speed they may have cut the harness off.
    5. Member g60301's Avatar
      Aug 4th, 2011
      Maryland
      90' Corrado m62
      04-06-2012 08:13 PM #5
      Pics?
    6. Member 1991corradog60's Avatar
      Sep 14th, 2008
      ephrata PA
      04-07-2012 05:35 AM #6
      It was automatic before swapped 5speed turn swapped vr. So that would make sense. Ill try and get a picture of it today.
