Page 1 of 4 1 2 3 4 LastLast
Results 1 to 35 of 114
Thread: Bierce IV's Thread.
  1. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    04-06-2012 11:31 AM #1
    Ok so long story short im finally leaving static for bags, But before i order everything i want to make sure i have everything and i have a few questions.
    But first here's some test fits of the wheels:
    DSC_0440 by Bierce IV, on Flickr
    DSC_0422 by Bierce IV, on Flickr
    DSC_0420 by Bierce IV, on Flickr
    DSC_0434 by Bierce IV, on Flickr
    Here is the order list: I would like to go with the V2 kit from bagriders.
    IMG_0759 by Bierce IV, on Flickr
    Now on to the questions:
    Will the ecs wheel centering plates work with bags? And this will be my daily driver, should i stay with the single 444c? Or should i get dual. And should i bother with a trap? I have read that some leak more than actually collecting water. And what else should i get while buying everything? I just want to be sure of everything so i can order ASAP, and do it all right the first time. Oh and the names DJ. Thanks
    Quote Originally Posted by mk4boost View Post
    If you don't want to break the bank you have the wrong hobby
    My Thread
  2. Member tmg1991's Avatar
    Jan 19th, 2011
    Dover, DE
    Bagged GTI
    04-06-2012 11:41 AM #2
    you should deff get a water trap.and i daily drive my mk4 and i have 444 single compressor and it does fine
  3. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    04-06-2012 11:47 AM #3
    this one should work fine correct? And would air line size would be best?
    http://bagriders.com/modlab/products...ATER-TRAP.html
    My Thread
  4. Member tmg1991's Avatar
    Jan 19th, 2011
    Dover, DE
    Bagged GTI
    04-06-2012 12:01 PM #4
    Quote Originally Posted by Bierce IV View Post
    i have the neumatics water trap and it works just fine for me. i cant say about the parker or avs traps but my friend has the smc and i like mine better.
    and i have 1/4 its not fast and its not slow. but you can always go with bigger lines and get flow control
  5. Member GreasySideDown's Avatar
    Mar 4th, 2011
    Oregon and the Carolinas
    95 Cabrio TDI, 01 Beetle TDI, 96 B4V TDI on air
    04-07-2012 10:02 PM #5
    I have a small bit of experience to share with water traps. I don't have any in my system and last night I had to pull the tank out (subwoofer died, tank is attached to sub enclosure). I got about 1/2 pint of water out of the tank. I've been on a roadtrip the past couple weeks and have laid down over 4000 miles. My trunk is full of crap so I didn't drain it like usual. Not very much water but I think I'll be looking for a place to put a water trap now. Like everything in this world (the VW world that is..), you learn as you go. I have an automatic water trap on my plasma cutter back home, I wonder if that'll work..
    I am Lord of The Crab People, bow to me.
  6. Member bryangb's Avatar
    Jun 16th, 2010
    Hanover, PA
    '08 GTI, '12 Beetle, '91 Passat
    04-07-2012 10:07 PM #6
    That one will work fine and the compressors leader line will thread directly into it (granted you plan on running the trap between the compressor and tank)
    I'd reccommend 3/8" lines. I think the v2 with 3/8" lines achieves the perfect air up/down speed
    If you go with 1/4" lines and it ends up being too slow.. You are stuck having to run new lines. If you go bigger and it's too quick for you you could always just add flow controls.
    // DROP // DRAG // DESTROY // beer
    // Open Road Tuning
    Instagram: @bryangb
    bags and wheels = build thread
  7. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    04-08-2012 12:35 AM #7
    thanks for the advise guys, and ill just run the bigger lines in the first place, id rather do it right the first time around. Starting to work on the trunk layout. I will post picts with updates. Wait till you see my theme
    My Thread
  8. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    04-08-2012 12:41 PM #8
    What do you guys think? i like the wheels i rebuilt, but there is suck a gap, and i dont want to have to pull my fenders THAT much to make it sit between the lip.
    Heres the specs:
    17x9.5 all around
    56mm offset
    33mm adapter rear, 38mm rear
    My Thread
  9. Member AndrewDaniels's Avatar
    Jul 2nd, 2011
    Annapolis, MD
    1991 GTI 2.0 16V, 1983 GTI 1.8 8V
    04-08-2012 08:19 PM #9
    Oh sh**, it's about get hot up in hurr
    16 with a bagged Mk2... Pretty sure I'm the only one at my school with bags...
  10. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    04-08-2012 10:25 PM #10
    haha, what do you guys think? Try it with current RS's, or trade for futuras and $$
    My Thread
  11. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    04-24-2012 08:06 PM #11
    sorry for the delays guys. Got extremely busy but im ready to order the kit. But im still stuck between analog and the v2. I would like to take advantage of the sale, but which would you guys say for a DD.
    My Thread
  12. 04-24-2012 09:53 PM #12
    go v2 if you have the $.
    USELESS
    WESTSIDE
  13. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    04-24-2012 09:55 PM #13
    well right now with the sale the analog actually cost more with everything lol
    My Thread
  14. Member Miotke's Avatar
    May 16th, 2010
    Tacoma WA
    2005 Jetta GLI
    04-24-2012 11:47 PM #14
    Quote Originally Posted by justmalpica View Post
    This.
    Custom Slapchop
  15. Member tmg1991's Avatar
    Jan 19th, 2011
    Dover, DE
    Bagged GTI
    04-25-2012 10:34 AM #15
    If you have the money go e level. I have v2 and wish I would have gotten e-level
    Instagram: trevorgrimes
  16. Member furr's Avatar
    Jul 3rd, 2009
    jerzy
    low 18t
    04-27-2012 12:01 PM #16
    will be watching
    Gravy
    instagram @furr21
  17. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    04-27-2012 07:59 PM #17
    Let the prep begin.
    IMG_0816 by Bierce IV, on Flickr
    My Thread
  18. 04-27-2012 11:21 PM #18
    Quote Originally Posted by tmg1991 View Post
    I don't understand why you wish you went e-level. I have v2 and its great. E level is a hassle from what I hear.
  19. Member tmg1991's Avatar
    Jan 19th, 2011
    Dover, DE
    Bagged GTI
    04-30-2012 12:17 PM #19
    Quote Originally Posted by MarkiVman View Post
    i like v2. but elevel is just way nice. its not pressure based its height based. so so you have a friend get it. it automatically adjust to the preset height. with v2 itll adjust but it will not be the same height you had it before your friend got in.
    to me it just seems way worth the extra cash to get it. IMO
  20. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    05-02-2012 06:47 PM #20
    Why not lol.
    IMG_0828 by Bierce IV, on Flickr
    Still deciding on trunk setup, i think i want to keep the spare (soon to be another RS)
    My Thread
  21. Member tmg1991's Avatar
    Jan 19th, 2011
    Dover, DE
    Bagged GTI
    05-02-2012 06:55 PM #21
    Why not lol.
  22. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    05-03-2012 05:48 PM #22
    Hey any way if could use to power wires from the sub that i used to have? Just swap out the fuse?
    My Thread
  23. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    05-04-2012 10:40 PM #23
    trunk setup and false floor is about done, i will take pictures when its cleaned. Also, new ideas for the exterior, time to get creative once again and stop following the "vortex image"
    My Thread
  24. Member Niagara_V_Dub's Avatar
    Sep 25th, 2007
    Las Vegas, NV / Lemoore, CA
    hoopty on air
    05-05-2012 12:35 PM #24
    Just run a separate power line, cause its just easier and I would rather have separate fuses for the amps and compressors so that if one blows you can figure out which one is messed up.
    Insert witty quote
  25. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    05-05-2012 05:29 PM #25
    gotcha, and i meant that i just have the amp wires, i disconnected the sub so the wires are just chilling there. Found out there 8 gauge so its a no go anyays
    My Thread
  26. Member Markg813's Avatar
    Jul 20th, 2010
    Townsend, DE
    Platinum Grey GLI on jackstands / 2004 Jetta TDI on CCW's
    05-05-2012 08:14 PM #26
    These are more for static cars.... go with IDF Drop Plates
  27. Member tmg1991's Avatar
    Jan 19th, 2011
    Dover, DE
    Bagged GTI
    05-05-2012 08:17 PM #27
    Quote Originally Posted by Markg813 View Post
    What mark said. And plus the ecs ones look super sketch compared to the idf drop plates
  28. Member vjg1215's Avatar
    Mar 23rd, 2009
    Townsend, Delaware
    Bagged Jetta VR6
    05-05-2012 10:40 PM #28
    What Trevor said.
  29. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    05-06-2012 12:47 PM #29
    Yeah I was looking at those, but quick question. Does it matter of both compressors are hooked unto the same side of the tank, or do they have to be on the opposite? Im trying to get the false floor done today
    My Thread
  30. Member tmg1991's Avatar
    Jan 19th, 2011
    Dover, DE
    Bagged GTI
    05-06-2012 01:18 PM #30
    it doesnt matter. but i feel like it wouldnt fill up as fast as it should going through one line into the tank
  31. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    05-06-2012 02:03 PM #31
    no im running 2 lines and watertraps, i meant like as in if both lines ran into the ports next to eachother on the left side of the tank instead of both ends
    My Thread
  32. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    05-06-2012 05:23 PM #32
    Just a rough idea i worked on, still gotta add some more wood. haha
    IMG_0841 by Bierce IV, on Flickr
    My Thread
  33. Member tmg1991's Avatar
    Jan 19th, 2011
    Dover, DE
    Bagged GTI
    05-06-2012 05:59 PM #33
    Oh yeah that's fine!
  34. Member Bierce IV's Avatar
    Apr 5th, 2010
    NY
    Bagged Blueberry
    05-15-2012 10:31 PM #34
    Long story short, got it all in, Still couldnt get the damn strut seated in the knuckle. Drove off a 4x6 nothing moved, so i backed it up and the strut spun and this happened.
    IMG_0867 by Bierce IV, on Flickr
    Whose got ideas to get those in WITHOUT grinding the protective coating out.
    My Thread
  35. Member MechEngg's Avatar
    Jan 12th, 2009
    Calgary, AB
    05-16-2012 12:19 AM #35
    Sorry can't quite tell what happened, did your tire peel off your rim?
    And you put the car down with the strut halfway in the spindle?? If so you are crazy/stupid, sorry to say. The weight of the car will cause the strut to bind and will actually prevent it from sliding down into the spindle.
    My suggestion still stands, 3/4" COLD chisel pounded in 90% of the way, lube, jack under car
    Cold chisel:
