Yeah. I have zero leaks in all of my lines and it is glorious.
MechEngg's lesson of the day
As long as there isn't a huge temperature difference it is usually very close to the pressure the day before. Temp increase = pressure increase.
P1/T1 = P2/T2
temp is in kelvin, pressure doesn't matter.
say you had your tank at 150psi and it was 20C out
P1/T1 = 150psi/293k
The next morning it is colder, say 10C outside. What will the pressure in the tank be?
P2 = T2 * P1/T1 = 283* (150/293) = 145psi
Now a lesson on why pressure relief valves (safety valves) are useful. In the morning on the way to work your compressor kicks on because you are screwing around with it. A brisk summer morning at 2C (happens here in canada eh). You have your tank set to 200psi like i do. You park your car out in the sun all day and inside the car reaches 60C (easily done in the sun). How much pressure would be in your tank?
Answer: 242psi. That is quite a bit over the rated pressure of the aluminum tank you happen to have (150psi working pressure rating). So having a safety valve of 205psi will save your life/trunk setup in this case if your tank were to explode
