VWVortex.com - Replacing one head bolt?
    Results 1 to 5 of 5
    Thread: Replacing one head bolt?
    1. Member ohfllifer's Avatar
      Feb 9th, 2005
      Lake Tapps
      85 diesel jetta, 90 cabby 16v, 2004 jetta wagon
      04-06-2012 01:20 PM #1
      I have a 1.6 diesel, mechanical 12mm head. I was wonding if anyone has replaced just one head bolt without removing the head or replacing the head gasket? When I put the head on this engine everything torqued correctly but when I did the retorque the rear bolt on the passanger side was pretty easy to turn compaired to the rest. Now it is leaking a little bit of oil from the head gaket on that corner.
      So can I just replace that bolt or should I just live with it?
      Thanks
      ‘Those who hammer their guns into plows will plow for those who do not.’
      Mar 31st, 2008
      PNW - Oregon
      04-06-2012 02:29 PM #2
      Quote Originally Posted by ohfllifer View Post
      Thanks
      you didnt replace ANY head bolts when you put that head on this engine, did you?
      Sep 20th, 2010
      Salem, Oregon
      1977 VW Scirocco 1.8/Weber carbs, 1986 VW Golf Diesel, 1978 Rabbit 1.6
      04-07-2012 02:02 AM #3
      That's oil leaking at the gasket where it goes aroun dthe rear oil drain holes.....not even under pressure. (Other than crankcase pressure.) I'd do it over again, with all new bolts.....you probably over stretched that bolt and it's doing nothing.
    4. Member ohfllifer's Avatar
      Feb 9th, 2005
      Lake Tapps
      04-09-2012 11:09 AM #4
      Quote Originally Posted by Glegor View Post
      All the bolts were new.
    5. Member ohfllifer's Avatar
      Feb 9th, 2005
      Lake Tapps
      04-09-2012 11:12 AM #5
      Quote Originally Posted by rdezsofi View Post
      That is a good point, thanks.
