VWVortex.com - 83 CIS to Full MSD w/Single DCOE swap. Wiring help needed
    Results 1 to 7 of 7
    Thread: 83 CIS to Full MSD w/Single DCOE swap. Wiring help needed
    1. Member GLiwant a vr6's Avatar
      Apr 25th, 2007
      Mt Shasta
      72 510, b5 avant
      04-06-2012 06:43 PM #1
      Ok ive been using BigCaddys wiring diagram.
      well ive become a little confused with running into the idle stabilizer which is tied into the ICM.
      where would be the best place to splice in? or do i get rid of it?
      wiring is not my strong point, so just some general wiring help with this would be much appreciated.
    2. 04-08-2012 09:38 PM #2
      no need to cut anything. hook the small red from msd to your original coil positive (terminal 15 from ignition) and the white from msd to your original coil negative (terminal 1 from icu). that's all you need.
    3. Member GLiwant a vr6's Avatar
      Apr 25th, 2007
      Mt Shasta
      72 510, b5 avant
      04-09-2012 06:06 PM #3
      the wiring diagram says to not have the red wires for either msd to pick up from coil?
      do i leave the idle stabilizer in place?
    4. 04-10-2012 06:02 AM #4
      correct. you are not connecting to the coil. you are connecting to the OLD COIL WIRES. good luck. yes, leave the stabilizer.
    5. Member GLiwant a vr6's Avatar
      Apr 25th, 2007
      Mt Shasta
      72 510, b5 avant
      04-10-2012 11:29 AM #5
      Oooooo
      got it. i hope
      thank you.
      Mar 31st, 2008
      PNW - Oregon
      04-10-2012 12:23 PM #6
      really should install that 4th bolt in your alternator bracket..
      the 3000 rpm vibration it makes, will be gone after you make up a bracket for that bolt hole..
    7. Member GLiwant a vr6's Avatar
      Apr 25th, 2007
      Mt Shasta
      72 510, b5 avant
      04-10-2012 06:58 PM #7
      Quote Originally Posted by Glegor View Post
      it already has 4 points of mounting. thats just a different mounting location for a different motor
