Easter Bump
#1
My Gti is no longer a Feeler.
Would like to either trade + cash (500 max) or straight swap.
Or sell outright 2000 with rack FIRM or 1800 without
Clean title in hand
For trades, Mk3 Jetta's ONLY
Prefer Green or Blue in color NO BLACK
MUST be 5speed and and have a Vr6 in it.
Now for the info.
Good
Just over 100k
Interior is MINT
Everything works..everything.
No CEL
Will come with Thule roof rack
Just installed some new fogs(OEM)
Has Neuspeed upper Stress bar
Lowered on a cup kit not sure of the brand,rides phenomenal,but not to low at all only drag.
Has aftermarket software not sure what kind,i just found the stock chip inside the car.
And as for an exhaust it has a side exit,it doesn't sound that bad but it is somewhat loud.
And has working Keyless entry fob that i love(OEM)
Now the BAD
Leaks some P/S fluid,its coming from a line connected to the back of the rack(Pressure line) ghetto rigged now
Could use shift linkage.First and reverse are very close,I can explain more detailed if actually interested
Chains make some noise,nothing horrendous.(only at idle)
Needs a valve cover gasket
Also i think it needs a headlight switch
Have to hold the RPM's at 1k on cold starts for 15 to 25 seconds.
Has some rust on hatch (repairable)
More on rear wheel well and a few little random spots
Horrible dent in the rear(see pics) and a couple other little dings here and there
Car has not been cleaned in over a month.
Pure filth.
Pics
#7
bump. will consider buying![]()
for sale: stock rear bumber and valance, thunderbunny rear, front bumper 2 broken tabs, front bumper with shaved sidemarkers and molded gti lip, ebach lowering springs, with or without stock struts. pm me
#8
#12
Can u explain more about the shift link
I am here: http://tapatalk.com/map.php?aztmux
mj
#13
You have to push and over down to get it into first somewhat like reverse just not as much ,that's really about it.
It's just takes some getting use to,I'd just replace it if you want smooth 1st gear entry everyother gear is fine
#15
I wouldn't think it's the shift link I would think its the gear sync wouldn't u
I am here: http://tapatalk.com/map.php?eybxiq
mj
#20
